2 x pp-sw150 in a vx wagon
2 replies to this topic
#1 sostok
  • 211 posts
Posted 23 January 2012 - 10:58 PM
Gday guys
wondering if you could lend some advice slash idea's....im new to spl design im gunna be running 2 x pp-sw150 subs and 2 x da12250 amps(1100wrms ea sub /amp ), as stated its going in a vx commo wagon and was wondering what box idea's would work for some decent numbers..im a fan of fusion pp and have access to gear hence why im running it...i did some calcs and came up with around 120ltrs ported box but seems a bit boring lol
look forward to any words of wisdom ,thanks in advance...basic specs below
PP-SW150
Max Power Rating 1500 Watts
RMS Power Rating 625 Watts
Frequency Response 20Hz - 1.5kHz
Impedance 2 x 2 Ohms
Sensitivity 91 dB
Compliance (Cms) 91.005
Cone Area (Sd) 754.77
D.C. Coil Resistance (Re) 3.6 (1.8 x 2)
Electrical Q (Qes) 0.397
Force Factor (Bl) 21.715
Free Air Resonance (Fs) 33.620
Linear Excurson (Xmax) 30
Mechanical Excursion (mm) 9
Mechanical Q (Qms) 2.643
Total Loudspeaker Q (Qts) 0.345
VAS (L) 73.618
VAS (CuFt) 2.6
Ported PP-SW150
Volume (litres) 60
Volume (cu.ft.) 2.2
Port diameter 101mm/4”
Port length 350mm / 13.75"
Tuned frequency (Hz) 38.5
Sealed
Volume (litres) 45.5
Volume (cu.ft.) 1.6
Tuned frequency (Hz) 80
Edited by sostok, 23 January 2012 - 11:03 PM.
..vx wagon with plans
#2 RAD
    I ♥ Dents
  • 2,113 posts
Posted 23 January 2012 - 11:27 PM
A low, flat box with ports and subs facing up would get you numbers. Perhaps 7 cubic feet NET, tuned @ 42hz. Or, a nice rear firing ported enclosure for music + OK numbers.
#3 sostok
  • 211 posts
Posted 23 January 2012 - 11:35 PM
ok cool thatd work being low would keep it under back seat and window height which always helps from window shoppers too lol..although i do need it to be a little musical since the boss n kids would use the car also
thanks again
Edited by sostok, 23 January 2012 - 11:36 PM.
