curious to find out what other scanspeak 12m owners have these drivers crossed over at? LPF and HPF
mine are pillar mounted
http://i128.photobuc...rn/929d5a99.jpg
the reason Im asking is, I tested the Frequency response of mine last night (no HPF) and found they start rolling off around 4khz and these are mounted more on axis
(tested each side individually and summed)
looking at the spec sheet
http://www.scan-spea...12m-4631g05.pdf
correct me if im wrong, but in the chart they start rolling off around 6khz? at 30 degrees off axis
also a side question - after a quick RTA check on iphone, i Noticed I had 2 massive peaks in the 400 and 500hz bands, im assuming this has something to do with my pillars/enclosures? (I had them sealed before at around .3 L but now have removed these so they are venting into the dash)
would deflex pads or anything similar help tame this area without having to cut those bands so much? (midbass drivers turned off when testing this)
Edited by s4turn, 25 January 2012 - 11:11 AM.
