whats the best box for these?
31 replies to this topic
#1 sostok
  • 211 posts
Posted 25 January 2012 - 11:09 PM
subs are pp-sw150Max Power Rating 1500 Watts
RMS Power Rating 625 Watts
Frequency Response 20Hz - 1.5kHz
Impedance 2 x 2 Ohms
Sensitivity 91 dB
Compliance (Cms) 91.005
Cone Area (Sd) 754.77
D.C. Coil Resistance (Re) 3.6 (1.8 x 2)
Electrical Q (Qes) 0.397
Force Factor (Bl) 21.715
Free Air Resonance (Fs) 33.620
Linear Excurson (Xmax) 30
Mechanical Excursion (mm) 9
Mechanical Q (Qms) 2.643
Total Loudspeaker Q (Qts) 0.345
VAS (L) 73.618
VAS (CuFt) 2.6
PP-SW150
Volume (litres) 60
Volume (cu.ft.) 2.2
Port diameter 101mm/4”
Port length 350mm / 13.75"
Tuned frequency (Hz) 38.5
Sealed
Volume (litres) 45.5
Volume (cu.ft.) 1.6
Tuned frequency (Hz) 80
..what would be the best box for volume but also music...
each will have its own amp 1100wrms ea
the vehicle is a vx wagon
Edited by sostok, 26 January 2012 - 09:05 PM.
..vx wagon with plans
#2 D34M0N.inc
    Team.inc
  • 2,133 posts
Posted 26 January 2012 - 02:23 AM
And????
Setup:
Clarion Digital Mechless HU
PPI 4ch 110wrms x 4
JBL GTO 608C 6.5" Splits
Bonecrusher 2 4000w rms @ 1 ohm 12v
4 150ah Exide Sealed Batteries
6 Elevation Audio SQx 12"
Shok Industries 0gauge
Stinger RCA's
#3 Tiger
  • 6,962 posts
Posted 26 January 2012 - 08:52 AM
^^^ x 2
So... i'm under the impression you WANT to use these subs for a project, yes?
They have the T/S parameters to have some fun with for a groundpounder. How many subs have you got/wanting top purchase? Car it is/there are going in? Have you matched it/them to an amp? And what do you want it to bang out.... get low? Or get loud?
1990 Toyota Camry SV21/2002 Proton Satria GTi/1982 Holden Jackaroo
No licence.... no fun... :( Back in action Novemeber 2012
#4 ubernoob
  • 971 posts
Posted 26 January 2012 - 10:35 AM
I'm guessing at the box volume he has three subs, but yeah the post isn't the clearest. :crazy:
Volvo 2001 S60T5
HU- Blaupunkt Bremen
Front Midbass- CDT ES06
Front Mid- CDT HD2
Front Tweeter- CDT ES010
Nothing good ends in phile.
#5 Carr
  • 190 posts
Posted 26 January 2012 - 12:19 PM
The problem I see in the image is that it shows the box volume as 7 litres. You will need to put the measurements in mm not cm. That will change everything.
The other info that Tiger mentioned would also be helpful.
Car: 2002 Daewoo Nubira CDX Limited Sedan
Head Unit: Alpine CDA-9887
Front: Currently being upgraded
Rear: Removed
Sub: Fusion Comp FCW-15
Sub Amp: Epsilon EA-5000D
Battery: Absorbed 100ah in boot, 75ah under hood
Wiring: 2 runs + and - of 70mm2, 2 runs to amp
PB - 146.3dB - Street B
Team Manual Shed
#6 D34M0N.inc
    Team.inc
  • 2,133 posts
Posted 26 January 2012 - 12:29 PM
It says 2 15's in the program so it's not 3, but guessing he is just asking if the box is ok for the 2 15's most likely he meant cm's and its 70L
Setup:
PPI 4ch 110wrms x 4
Stinger RCA's
#7 ubernoob
  • 971 posts
Posted 26 January 2012 - 01:13 PM
Ahhh yes so it does, sorry.
Volvo 2001 S60T5
Front Mid- CDT HD2
#8 sostok
  • 211 posts
Posted 26 January 2012 - 04:34 PM
sorry guys posted late..my brain had already gone to bed...its 2 subs and 2 amps 1100wrms ea( 1 amp per sub) its supposed to be 7 cu ft.....its in a vx wagon..i left alot out of edited post sorry guys
thanks for your help and patience
geez what a great start...what a dork lol..sorry again guys
#9 D34M0N.inc
    Team.inc
  • 2,133 posts
Posted 26 January 2012 - 11:15 PM
Isn't 7 cubes a bit big with that sort of power?
Setup:
PPI 4ch 110wrms x 4
Stinger RCA's
#10 sostok
  • 211 posts
Posted 26 January 2012 - 11:19 PM
yeah thats what i thought..as i say im new to this sorta thing in the sense of not goin by supplier spec boxes....in my head 120ltrs was more toward what id need for a dual ported box....hence the cry for help lol
#11 D34M0N.inc
    Team.inc
  • 2,133 posts
Posted 26 January 2012 - 11:59 PM
I'd prob go 3cubes per sub max myself.
Setup:
PPI 4ch 110wrms x 4
Stinger RCA's
#12 sostok
  • 211 posts
Posted 27 January 2012 - 09:34 AM
ok cool ill work on that then ..thanx
#13 sostok
  • 211 posts
Posted 27 January 2012 - 10:59 AM
Attached File  fusion 15 x 2 ported box.docx   32.09K   11 downloads ...perhaps this would work
#14 D34M0N.inc
    Team.inc
  • 2,133 posts
Posted 27 January 2012 - 01:34 PM
Looks good, is this for SPL only? Or do you want to play music to? As the port is tuned rather high. For the best of both worlds your best with a 35hz tuning i have found.
Setup:
PPI 4ch 110wrms x 4
Stinger RCA's
#15 sostok
  • 211 posts
Posted 27 January 2012 - 02:51 PM
ok ill change ports to suit 35hz ..your'e the man thanks for your help and patience
