What load on factory head unit running line level to two amps?
5 replies to this topic
#1 b-rad86
    0 - 25w RMS
  • 5 posts
Posted 30 January 2012 - 12:19 AM
The situation is I have a ve ute which currently I am running a 2 ch amp via high level inputs. Being an 08 the loom does not have 4 channels of speaker cabling coming out of the head unit, only the two channels for the doors.
Now I have a mono waiting to go in also. I am hoping that if I connect the mono via high level input I can use the RCA passthrough to send signal to the 2ch. I have a funny feeling it will not be the case.
Failing that I could run a separate loc and then be guaranteed the RCA pass through would work but I would rather not have to. My other option is to run two sets of high level inputs in parallel off the factory speaker wires, however I am concerned that not knowing what the loads are on a high level input on an amp is that it may create a load too low for the factory head unit and damage it....
Any thoughts or input for my dilemma??
Brad
#2 MAS Andrew
  • 434 posts
Posted 30 January 2012 - 10:34 PM
You can run the other amp as you mention, it's the same as y-splitting RCA leads, you're using the speaker outs as signal in to the amps. The impedance load will be on the amps depending on the speakers you are using.
mobile audio solutions
Australian Distributors for:
ARC Audio - DLS - Dynaudio - Image Dynamics - Hybrid Audio Technologies - Micro Precision - Monster Cable - StP - Tru Technology
www.mobileaudiosolutions.com.au
#3 b-rad86
    0 - 25w RMS
  • 5 posts
Posted 02 February 2012 - 03:04 PM
I understand the impedance load on amps in relation to speaker arrangement but what about the impedance load on the head units internal amplifier in regards to running two amps in parallel off the 2 channels coming out of the head unit via speaker level in on the amp?
#4 syd-monster
  • 3,905 posts
Posted 02 February 2012 - 04:30 PM
input impedance on amps is ussually a very high figure (ie about 10Kohms) so they draw little current. I say you should be right to split the signal as per above.
I do suggest though that you instead put in an LOC close to the amps then RCA Y-split the output into the amps.
Edited by syd-monster, 02 February 2012 - 04:33 PM.
_____________
syd-monster
#5 b-rad86
    0 - 25w RMS
  • 5 posts
Posted 02 February 2012 - 06:33 PM
Whys that?
Thanks for the info btw :)
#6 57upd
    0 - 25w RMS
  • 4 posts
  • Interests:Photography, Automotive Sports,
Posted 24 May 2012 - 12:18 AM
Just so you know the rear speaker output is still there. To turn it on just turn deck off--push track up and disc up and keep it pressed - push on button once and keep the other two buttons pressed for a while..you will see service appear. Scroll down to speaker and select 4/5 then turn off and on.
You just need to find the right pins in the plug going into the headunit(in other words the pins are empty, Holden just hasn't run any wire from them) and with the right little terminals you can just run the wires out of the plug.
Hope this helps
