Running power wire for amp (2004 Barina )
Posted 30 January 2012 - 02:04 PM
I have a 04 barina, xc model, and I am putting in a nice sound system for the wife. couple of 10 inch subs, and some splits run off a couple of amp I have lying around. I am also going to be using a Hi/Lo converter of the stock head unit, which i should upgrade in the future.
I am just starting wiring the power cable and I have had a look and can't find any decent grommets in the firewall that will fit a 0 gague cable through it. The only place I can see is to go into the front guard and then come out in the kick panel.
Is this the best place to run the power wire for the barina?
also i'm noticeing there is not alot of room for the 0 gague wire the whole way from the kick panel to the boot. does any one have any tricks to make extra space for bigger cableing? There is square plastic cable holder tubes from front to back with factory wiring, would it matter if I removed cable holders and just used cable ties to hold the wiring in place? This would make just enough space to run the cable.
Cheers, Grant
Headunit: Clarion HXD2
Sub: Focal Utopia 33WX (Old school)
Splits: Focal Utopia Be Kit no 7
Amps: Arc Audio SE2150, Arc Audio SE2300
EQ: Arc Audio MEQ30
Cabling and Other: Stinger, Dynamat
Progess needed:1/2 Stereo Install, put in a Super charged V8 Stag engine
Posted 30 January 2012 - 02:21 PM
http://www.mobileele...age__hl__barina
Edit: there it is.
Wanky uninstalled gear that I need to install in my 200sx this year:
Source: Alpine 9887
Front: 2 x SB Acoustics SB17 per door
Front Amplifier: Digital Designs S4a
Subs: 2 x Hybrid Digital Designs/PSi 99F series
Sub Amp: Digital Designs M2a
Posted 30 January 2012 - 03:16 PM
Others cut into the plastic housing that the loom runs through but either way it's squeezy, you'll need a grommet, and it's hard to pull into the car from under the dash. But you'll get there!
Posted 30 January 2012 - 05:04 PM
EQ: Arc Audio MEQ30
Posted 01 February 2012 - 04:14 PM
I also ran the cable in the cable holders to the back of the car. It just fit in with the stock wiring for the lights and such. (was a very tight fit)
I'll post some pictures of what I done later in the week.
now that the majority of the wiring is done, the next step is to build the sub box and amp rack, going to paint the sub box which wll be my first attempt at spray painting. I might start a build topic if I get enough pictures.
Cheers Grant
EQ: Arc Audio MEQ30
