Will my 4ch Amp power my 4ohm Splits + 2ohm Sub?
Posted 04 February 2012 - 11:29 PM
I've got a noob question regarding my proposed new system - I've searched and searched and am yet to find an answer for my query.
I've got a Fusion fp4-1000x Amplifier which has been rock solid for 8yrs - here are some specs:
- 125watts x 4 @ 4 Ohms
- 500watts x 2 @ 4 Ohms
- 250watts x 4 @ 2 Ohms
Will I have any issues running my 4ohm JL Audio Splits from Ch1&2 and my 2ohm JLAudio W3v3 Sub bridged from Ch3&4?
Can the amp support the mixed ohm output, or will it only run at 4ohm OR 2ohm at any one time.
Thanks in advance!!!
Miker84
Posted 05 February 2012 - 12:50 AM
My VY Berlina
http://www.mobileele...rlina-sq-build/
H/U - Alpine 9855r
Speaker Amp - Alpine MRV-F545
Sub Amp - RF T1001bd Power Seires
Front Stage - SB Acoustics SB17 Midwoofer
/SB29 Neo Tweeter
Subwoofers - 2 x Polk MM 10"
Optima D34 YellowTop, Stinger & Aerpro Wiring
Posted 05 February 2012 - 10:24 AM
Does this change the situation?
Posted 05 February 2012 - 10:29 AM
therefore if you bridge 3/4 at 4 ohm it runs each channel at 2 ohm, which your amp is stable for
and obviously if you bridge it at 2 ohm it runs each channel at 1 ohm which not many amps other than misconi's that i know of are stable at 1 ohm per channel, basically your wiring the amp down at too low ohms and will kill it, might be good looking for a 4 ohm sub or maybe a mono block with good power at 2 ohm
hope this helps
Posted 05 February 2012 - 10:46 AM
I used to run a 4ohm sub from 3&4 with no problem - I now understand how this worked.
My new 2ohm sub will turn 3&4 into 1ohm each which in turn will probably fry the amp. DAMN!
Thanks for the help guys
Edited by miker84, 05 February 2012 - 10:47 AM.
Posted 05 February 2012 - 01:17 PM
with a 4ohm sub installed.
Instead I've receive the enclosure that contains the 2ohm version of the sub.
Not Happy Jan!
I'll be getting intouch with the reseller tomorrow to rectify the mistake.
So once I get the correct 4ohm sub, my fusion amp should do it's job nicely
2 x 125w to front splits @ 4ohm
1 x 500w to sub bridged @ 4ohm
Thanks again guys for the help!
