2 ARC 12's VS 1 IDMAX?
6 replies to this topic
#1 matt619
matt619
  • 38 posts
Posted 11 April 2012 - 03:01 PM
Ok, this is my third thread about this system..
We have already put down a deposit on some gear. However i have come to re-think a little.
My question is, Would 1 IDMAX sound better then 2 ARC 12's in a VE sedan?
1 ARC 12 is rated at 350 rms and a 1 IDMAX is rated at 1000 rms.
We are running 1200 watts to the pair of ARC 12's but if we went with 1 IDMAX sub and ran the same power would it sound better?
I only ask because I know the IDMAX12 has such a great reputation.
Thanks guys
#2 Damo95
Damo95
    Team Tennent
  • 7,649 posts
  • Interests:Car audio & Architecture
Posted 11 April 2012 - 03:16 PM
I would recommend the IDMAX without a doubt, but 2x Arc's may be louder..
all comes down to what you have available in terms of volume/install limitations as well as output requirements.
#3 2013FOCUS
2013FOCUS
    ->Approach from the Right->
  • 2,645 posts
Posted 11 April 2012 - 03:40 PM
As Damo has said, too many variables come into this to be able to recommend one over the other.
You are not comparing apples with apples.. if all you want is louder, then 2 subs of just about any kind will be more-so than any single sub.
If you want proper SQ and you have the necessary equipment within the system, then 2 subs can be made to work
You need to get out and listen to these subs to be able to make the decision based on what you hear and prefer.
Mark
Edited by Frankston Car Audio, 11 April 2012 - 03:40 PM.
#4 ~Spyne~
~Spyne~
    SQN00B
  • 10,954 posts
Posted 11 April 2012 - 04:10 PM
What box have you got the Arcs in? Is it a prefab, DIY or shop/DIY built to specifically suit the T/S specs of the Arcs?
The rated power handling of each sub will tell you nothing about whether one will sound "better" than the other. Not to mention that sounding "better" is entirely subjective.
I would hazard a guess that all things being equal, the 2x Arcs would be louder than 1x IDMAX - just. The IDMAX does have a lot of excursion potential.
If the subs were in ideal boxes, and gains/crossovers/EQ were all set for optimal performance, I think you would seriously struggle to tell the Arcs from an IDMAX. However, one set-up might be easier to 'get right' than the other.
#5 matt619
matt619
  • 38 posts
Posted 11 April 2012 - 04:24 PM
we haven't officially ordered the ARC subs as of yet.. i was just re-thinking thats all.
From all your guys information, I will stay with the ARCS. Thanks guys.
#6 Magnum9
Magnum9
  • 94 posts
Posted 11 April 2012 - 06:01 PM
Or you could go one Arc black series 12" for the same sort of cash, which is what I have in my VE ute.
#7 Woody
Woody
    PURE SQ
  • 1,637 posts
Posted 11 April 2012 - 09:07 PM
Save a couple of extra bucks and just go 2 IDmax's. Run them off the Arc amps. Very nice combination....
Wood
