Which slim (underseat) Active subwoofer would you recommend?
Posted 04 May 2012 - 06:19 PM
Well I've come to the conclusion that if I want a sub(s) in my Hilux, I will need to either compromise front passenger legroom or go for an under seat solution. Now I've looked around and I'm considering the following slim active subs:
DNA - http://www.ebay.com....=item27c3546622
Phillips - http://www.ebay.com....=item2a12999b12
Alpine - http://www.alpine.co...php?item_id=161
MBQ dual - http://www.ebay.com....=item1c206df40d
It seems that the MBQ one is the best value for money and the alpine you get the least value for money however is it better to get something thats a good brand name over something that has more to it but is get a lesser known or unknown brand? ie. would the alpine end up being better than the MBQ?
Posted 04 May 2012 - 08:20 PM
/thread!
Posted 05 May 2012 - 10:40 AM
Vibe do one that is much better than both.
LITEAIR8CUA
http://www.vibeaudio...eair-optisound/
300W RMS mono amp built in. $349 RRP
Posted from my portable device.
Posted 06 May 2012 - 08:55 AM
Posted 06 May 2012 - 02:49 PM
Talk to Marty at FHRX, I think he had a special on the Focal recently.
Posted 06 May 2012 - 04:22 PM
http://www.ebay.com....=item4164f61c70
#7
Posted 06 May 2012 - 06:18 PM
cause I can't find the ibus20 on the focal aud site, but can find the bus20...
#8
Posted 06 May 2012 - 06:24 PM
#9
Posted 06 May 2012 - 06:28 PM
What is different between the ibus20 and the bus20?
Hmm true I didn't pay attention to that. But the power handling does seem to be a bit higher on the ibus20. Maybe a new version/edition?
#10
Posted 06 May 2012 - 06:30 PM
#11
Posted 06 May 2012 - 07:00 PM
#12
Posted 06 May 2012 - 11:41 PM
Edited by Hiluxman, 07 May 2012 - 12:00 AM.
#13
Posted 07 May 2012 - 04:56 AM
#14
Posted 07 May 2012 - 07:31 AM
Judging by focal Australia's website, doesn't look like they have the iBus 20 yet, they only have the Bus20. Looks like I may still have to source it from overseas.
^^^ The Focal iBus20 is available in Australia (as are the new speaker ranges). The Focal AU website just hasn't been updated yet.iBus20 is the new revised model. Try the international Focal website for specs etc.
I'd advise having a chat to Marty from Fhrx Studios - he's used a whole range of different underseat subs in a variety of applications, so will be able to advise appropriately on whats good and whats not!
#15
Posted 07 May 2012 - 07:48 AM
The big Question that will dicatate how well a behind the front seat install will sound is how tall are you? If you need the seat the whole way back, you may be limited to shallow mount drivers which isn't too bad. Just your subwoofer choices are far less and generally dont perform as good as a full sized sub. IMO providing it is installed in a large enough enclosure it will perform better than these plastic underseat subs. A lot of people make the mistake of buying shallow subs and choking them in a far undersized box and then complain how poorly they perform. A good example ive seen was 2 twelve inch pioneer shallow drivers being replaced buy a single 10 with the exact same enclosure.. It sounded far better and played lower (maybe not quite as loud)
In my case, I decided to go for the lack of passenger footspace as I wanted the best possible SQ sub I could fit and that was the ONLY place I could keeping my dual cab a 5 seater.
#16
Posted 07 May 2012 - 02:27 PM
Why not build an enclosure behind the front seats? Yes there are limitations in a ute (trust me i've been there, done that) but these slimline active and usually plastic encased solutions are not a complete replacement for a decent well thought out "proper" sub install.
Well my Hilux is a dual cab man so can't do anything behind the FRONT seats. Nor can I do anything behind the rear seats either as there is literally about 1-2inches of room behind them. Also with the 2005-onwards hilux dual cabs, you can't retract the backrest of the rear seat down without modification so. As for under the seats, I was going to order a custom enclosure for under the seats for a 10 inch sub however it required there to be 160mm under the seats. I only have 100mm under the passenger's seat and with the driver's seat adjusted up I get a maximum of 130mm. There would be only one more option, to comprise front passenger legroom. I guess the front passenger could still put their feet on it if I get a strong grille for the sub. What do you guys think of that idea? Would this be very practical?
#17
Posted 07 May 2012 - 03:48 PM
http://www.ebay.com....=item2a15f3b465
This is the enclosure: http://www.ebay.com....=item4164f3d4e4
How would that combination sound with a good mono class D amp or a 4 channel (also hooked up to components in the doors)?
#18
Posted 07 May 2012 - 10:28 PM
However I have a few question about this.
1) Will this set up sound better than a slim active sub under a front seat?
2) Do you think it is practical to put the sub on the centre hump at the rear of the car?
Edited by Hiluxman, 07 May 2012 - 10:40 PM.
#19
Posted 08 May 2012 - 04:45 PM
#20
Posted 09 May 2012 - 06:38 PM
Have you looked under the back bench seat for space? Imo you need a proper enclosure and sub if you want the best from your music.
I'm starting my own build w/Rockford fosgate IB-200's under the front seats which I've done loads of research about! I'm also having a small enclosured sub in the luggage area. My post is here: http://www.mobileele...80#entry1301780
#21
Posted 09 May 2012 - 07:08 PM
#22
Posted 09 May 2012 - 07:18 PM
Pioneer TSWX77A on the back wall possible?
Can't do that one mate. Like I said before I have literally 1.5-2 inches behind the rear seat. It also becomes less (more like 3/4 to 1.25 inches) when u retract the bottom of the rear seat up. This is because the backrest moves closer to the back wall when you do this.
#23
Posted 09 May 2012 - 07:23 PM
I had a 1991 Hilux D/cab so my knowledge of the 1997+ later models isn't so good, but IMHO subwoofers need air to make the best sound, restrict the air compromise the subs ability to play.
Yeah I've had a bit of a look there mate. There are two tiny storage boxes under the bench at the rear. One has the wheel spanner and jack and the other has barely enough to fit a phonebook (and thats the smaller type phonebook, not like the yellow pages). Maximum height I could have for the sub box is around 350-400mm as any higher would intrude the rear centre passenger too much. I also cant have it anymore than 250mm wide as this would go over the hump. And I can't have it anymore than 180-200 long as the cup holders would be useless.
#24
Posted 11 May 2012 - 12:52 AM
bugger
#25
Posted 15 May 2012 - 06:28 AM
http://www.avhub.com...once-again.html
#26
Posted 16 May 2012 - 09:44 AM
Just FYI mate, here is a review of the ibus20. It's by Marty so as Rick said, they are available in Aus
