Sub Advice
4 replies to this topic
#1 jitesh_88
jitesh_88
    0 - 25w RMS
  • 6 posts
Posted 27 May 2012 - 01:13 PM
i need some help regarding choosing the best aub+amp combo
i have done some research and chosen to go with kicker zx4001. amp working 400rms@2ohm and 200rms@4ohm
i have shortlisted a few subs can someone recommend me which will be the ideal sub to match with the amp making sure its not underpowered
i know i should be matching the rms for the amp and the sub. but the ohm factor makes the difference. not sure how that works
i mostly listen to RnB music if that helps
1) jl w3v2-4 300RMS@4ohm
2) jl cp112W0-4 200RMS@4ohm
3) kicker compvr CVR122 400RMS (not sure about ohm value) website says 2/4 DVC
4) jl w3v3 available in 2/4ohm @500RMS
#2 Tritty
Tritty
    Moar Esquezz!!!
  • 1,305 posts
Posted 27 May 2012 - 06:57 PM
The kicker CVR122 will sound the loudest off the Kicker ZX400.1 if its run at 2ohm, the kicker boxes are tuned to around 44hz and is more suited to hip-hop/ R&B music IMO. But the jlw3v3 is a better sounding sub IMO, won't be quite as loud as the kicker though :/ hope this helps
#3 Equilibrium1990
Equilibrium1990
    Mr. Buy 1st think l8r
  • 406 posts
  • Interests:Computer Technician. Love cars, car audio, Music, Creating random stuff that is of some use to me :-D
Posted 28 May 2012 - 08:50 AM
From those, jl w3v3 :-)
#4 VR028
VR028
  • 166 posts
Posted 28 May 2012 - 11:20 AM
definately the JL w3v3, if possible in its factory High output box with the silver bars across the front. you wont be disapointed
#5 DrBoom
DrBoom
  • 1,245 posts
  • Interests:Car audio, home Hifi, movies.and playing with my kids and fixing stuff!!
Posted 29 May 2012 - 04:13 PM
From your choices, the Kicker if you want more volume, but if you are leaning towards SQ, then definately the JLW3V3
