Right sub selection for SPL?
Posted 11 June 2012 - 01:58 PM
Car that there going into is a 2007 Toyota hilux extra cab.. So I have about 10 cubic feet to play with for box give take..
I was considering 4 Orion hcca 10's or 2 Soundstream xxx 15's. What I want to do is get somewhere close to 150db if not be able to crack it...
"But am open for suggestions for good SPL subs"
Please let me no what you think will be able to get me there..
Posted 11 June 2012 - 05:04 PM
Posted 11 June 2012 - 05:53 PM
Posted 11 June 2012 - 06:00 PM
Nakamichi NSX 15" in a TRWC15 prefab box off 800~wrms I did a 140.7dB @ 44Hz off unboosted non bass edited music
Nakamichi NSX 12" in a TRWC12 prefab box off 2000~wrms I did a 143.3dB@41Hz, again off unboosted non bass edited music
Both of those numbers were in a 1996 Holden Nova (aka Toyota Corolla) in full daily setup, all seats up, box against the back seats
Hope thats helpful
Edited by Damologist, 11 June 2012 - 06:01 PM.
Posted 11 June 2012 - 06:26 PM
And thoughts on...
-Re audio xxx 15
-Orion hcca 15?
I'm not steering away from the NSX just want some feedback on others also that iv considered putting in..
Thanks for the feedback so far
Posted 11 June 2012 - 06:46 PM
i would burp them, no sweat, music, high freq it put 3-4k, low freq lucky take 3k without getting stinky (my box peaks at 38hz so no bottom out lol) iv blown 2 and now my last has 1 coil out of 4 left... altho they where billys first copping similar power to me, they where all in working order when i baught them..
what power you gonna run? i wouldn't try burp anything with a 4" coil (maybe the nsx better?) but going from smaller 3" subs on same power i went up .5-1.5db louder each time, if your gonna throw 10k per sub, id look at say DD maybe DC or import some FI btl n2, if only playing with low power look at lower end subs..is this burp only setup or daily? street b in db drag remember is only 2 batterys iirc, so can't daily put big power..
#7
Posted 11 June 2012 - 06:58 PM
#8
Posted 11 June 2012 - 07:33 PM
#9
Posted 11 June 2012 - 07:40 PM
personally i wouldn't even consider doing a build with 2x 15"s on that much power if you want any kind of daily listening... 4x 10"s would be my choice, more voice coils to disperse the power over, better daily usability...
if your looking for strait out burps then thats another story, but considering the car and class choice you've gone with i'm guessing you want a loud enjoyable system...
the XXX woofers may be rated at 8500rms, but i'd pay good money to see one take that daily in a musical setup... as woodzy has said, they'll take it for a burp, but thats about it...
the NSX woofers, altho completely beasty, i would be hesitant to recommend running 2 off that kind of power daily, as they just haven't been tested on that kind of power YET... add in the single 4ohm coils and they most likely won't work out for you,
the HCCA's on the other hand, are available in a 10" so that could work well for you...?
unfortunately there just isn't many options...
#10
Posted 11 June 2012 - 07:44 PM
#11
Posted 11 June 2012 - 08:13 PM
#12
Posted 11 June 2012 - 08:19 PM
4ohm 5500 x 1 channel
2ohm 7500 x 1 channel
1ohm 10,000 x 1 channel
And I have 2 of these amps so yea wanted to get a pretty high rated sub hence why I was leaning to the xxx cause there where at 8500rms rated..
I bought these amps quite cheap "ish" bout 4months ago and have had big plans but due to selection of car and so on... Plans on the build set me back cause I couldn't get info from commen stereo stores cause they would obviously push there own brand over the competition and win you over.. Again this is why I have posted this topic to find out with other consumers could offer on info..
And is great info I might add.. And opens my choices a lot.. Do you think in any of these options that you have offered would get me to or over the 150db rating?
#13
Posted 11 June 2012 - 08:34 PM
Edited by Damologist, 11 June 2012 - 08:37 PM.
#14
Posted 11 June 2012 - 08:54 PM
I only have MAX 13cub ft that's sort of why either 2 15's or 4 10's... Even that's maxing it out I'd think
#15
Posted 11 June 2012 - 08:59 PM
but thinking away from woofers themselves, what are you looking at doing install wise? as you say 10-13cf in an extra cab ute i'm assuming you're planning to wall the ute? what are you doing for battery power to supply the XXX's....? as your going to want a TONNE of battery power...
also, you wouldn't happen to be the guy who rocked up atthe Bass Race event on Saturday night with the swift would you?
#16
Posted 11 June 2012 - 09:09 PM
I don't think I will have enough room for 4 12's plus ported box in a space cab hilux...
Ahhh, yes, there is the space issue.... Hmmmm, my bad... I instantly picture optimal sized hatches when thinking SPL, lol
With that size have you factored in battery size requirements? Or will you have them in the tray?
Because I'm just thinking with a space cab hilux, if you're trying to squeeze the batteries and the two amps in the cab will there really be much room for a box at all?
#17
Posted 11 June 2012 - 09:10 PM
Iv got 2 odyssey pc2150's
#18
Posted 11 June 2012 - 09:20 PM
Annnnyway!! The box I had was head height 10cubic ft ported 100kgs bolted to the back of the cabin and only run one pc2150 with still a little leg room so I'm hoping to squeeze another batt in there.. But the Navara does have a larger space cabin though I think..
#19
Posted 11 June 2012 - 10:18 PM
Na I wasn't.. Did he have a similar setup that I want to try do?
nah it's just that he had a XXX10,000 and a HCCA 10", it's just odd that all these XXX10,000s are coming out of the wood work atm, this is the 4th i've seen pop up in the last couple of months... the HCCA was just a coincidence as you mentioned them earlier...
the 2150's are a fantastic batt, but with that much power i'd still be looking at maybe a 3rd or 4th to go along with them... either way you've got some GREAT gear listed so far!! i'm very keen to see a build log of some kind!!
#20
Posted 11 June 2012 - 10:30 PM
Yea those batts I can't go past them!!
As soon as I get my stuff together and install is closer then what it is now ill start taking photos and stuff and show you how things are going..
But looking at it now I'm leaning more to 2 15's
Either Digital designs 9515's, xxx 15's, re audio xxx, sundowns, fi btl n3 or 2... Or even the NSX are going to be sufficient on getting to that 150db mark...
#21
Posted 11 June 2012 - 10:56 PM
DD 9515/9915, Atomic APX/APXX, HCCA etc...
#22
Posted 12 June 2012 - 10:22 AM
#23
Posted 12 June 2012 - 12:15 PM
That's why I didn't really wana go over 2 batts... Contemplating not using both 10k amps now due to that... No use having that much power when every 15" sub I have seen in that brands that have been dropped in this topic isn't over 2000-3000rms..
Na I was thinking musical aswell
#24
Posted 12 June 2012 - 12:55 PM
BASS Battle doesn't have box size limitations, however if the enclosure is seen to be a "wall" then it will be bumped up int the ultimate classes
"Wall"- If the enclosure extended to the roof of the vehicle via the use of trim panels or enclosure edges it will classified as a 'wall', regardless if it is sealed or not. Subwoofer enclosures are permitted to extend beyond the window line however judges discretion will apply as to the determination of a 'wall'.
my personal opinion has always been to build whatever it is that YOU want to build, and then worry about what class it fits into later, as 95% of the time the system is being used it will be at your own pleasure, not at a competition...
#25
Posted 12 June 2012 - 02:29 PM
if after music grab some fi sp4, im gonna run 2 off my 9k amp, not sure how they would go on so much power tho LOL only seen 2 subs on a single 10k amp, a dc level 6 or dc neo (both cost over 2k over states) and the smd 18"..but all got stinky and warm after more then 30 seconds.. someone wanna custom make some 6" coiled subs to help him? LOL
#26
Posted 12 June 2012 - 03:11 PM
OHH i didn't no bass battle had same name classes (the fusion events and i think frankies both got in trouble or warned for using the same name, street a/b, super street ect)
only for the street classes, as at the end of the day there is simply no better name for those classes,
i've actually been quite interested in those SP4's myself, they seem like a rather beasty woofer!!
#27
Posted 12 June 2012 - 03:25 PM
#28
Posted 12 June 2012 - 07:17 PM
But in saying that I'm sure any brands that both you guys and I have asked about could do the same... I'm gonna look into these subs abit more and also the fi btl n3's
Considering the sundown NS v.2 are not out till summer 2012..
Should I be looking at dual 1,2 or 4ohm subs..??
#29
Posted 12 June 2012 - 07:22 PM
look into the sp4s altho they not rated high they will take 5k and LOVE 4th orders if got the room for a 3:1 ratio..could also look at AA mayhems, as i think the smd woofer is being redesigned..there was a guy over WA who has 2 tsns dunno what he ever did with them tho.
could look into DD but i dunno how the 9515's would like 5+ on music, iv never used them on music, if wanna spend big buy a DDZ,
.hmm what other large subs are there...
looking at fi n3, you have get custom spider pack ect, not recommended for daily they have HUGE motor fource, will be very peaky, but then again will be freaking loud, db don has 4 in a wall doing 60s on music, and another guy iv talked to had 3 15's on about 12k doing 55's no wall on music..
#30
Posted 12 June 2012 - 07:35 PM
i think your gonna need 4" coils to take the heat off of 10k lol 2 level 5 would take a single 10k tho..but expensive ima guess 1800-2grand or so a sub.. would have use xamplar or what ever to buy them, unless buy from someone over seas used (or if know people lol)
id say 2 IA wardens would take it..if walling and 2 21" subs would be sick! think AQ had 4" coils aswell..
yeh i have a thing for watching subs being pushed to their very limits..its damm expensive tho lol
