I am currently about to upgrade the stock system in my MY10 VE SS Ute.
I wouldn't have the slightest idea when it comes to car audio so any opinions would be greatly appreciated.
I already have a set of hertz HSK 165's , but am clueless on amp and sub options.
I would be looking at
-2 or 4 channel to power the fronts
- 12" SUB
- mono for the sub
looking to spend about $1000 for the two amps and a single 12" sub no idea on what brand or options to go with.
I listen to all genres of music but i do occasionaly like crank it with some pretty serious bass.
Thanks in advance
-Cam
VE SS UTE Install Options?
Started by japjet, Jul 09 2012 08:29 PM
3 replies to this topic
Posted 09 July 2012 - 08:29 PM
Posted 10 July 2012 - 08:33 AM
I had a VE SSV ute so I no the minimal space behind the seat you have lol but there is still a lot more space there then most utes..
I was gonna put 2 reference r1 12" subs behind seats in custom boxes with only 1 really good set of focal krx3's up front just to try get up over the bass... And a Soundstream xxx 4000d to run both subs under seat and still have a 4 channel If I ended up getting another set of splits..
My opinion for you "MAYBE" in 12" subs.. Due to what you wana spend:
Alpine type R
Kicker L7
Soundstream T6
Jl w6....
Theses are just a fue generic subs you can look at just have to watch the depth in the sub itself cause you don't have a great amount of room.. Other then that you can blow it out with other high end brand the list goes on!!!!!
Make sure you check eBay as well I got a bargain on a kicker L7 for $150.. I was over the moon and smiles all round..
Compadable amps to run these subs I'm sure a dealer will help you with that, and those subs are compadable with anything 1000rms.. Check your local audio store and maybe post here what they have in stock in options and I'm sure anyone on here can help you as they have helped me heaps of times.
Your stereo is your stereo not anyone else's was a good quote I got from here just remember that.
Have fun
Alpine type R
Kicker L7
Soundstream T6
Jl w6....
Have fun
Posted 10 July 2012 - 04:12 PM
cheers for the info.
Im pretty keen after looking at the L7 Sub ( 2 0r 4 OHM?)
Iv'e had a quick look at some reasonably priced amps.
Would these options suit the L7 and My HSK 165's ?
Kenwood KAC-9105D
500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
Kenwood KAC-7205 Car Amplifier
Also would a capacitor be required for this setup?
Cheers.......
Kenwood KAC-9105D
- CEA Rated: 170W X 2 (1.0% THD+N) (4Ohm/2Ch)
- 250 Watts x 2 (2 ohm)/500 Watts x 1 (4 Ohm Bridged)
Cheers.......
Posted 10 July 2012 - 05:40 PM
The L7 is good for 750+ rms handling.. I'm sure there would be a fue people on here strapping 1000+ Rms to that sub
1ohm for the amp to it should be fine if it producing 900 to it, and 4 ohm I hear is the way to go to put abit more power into it
2 x 250 is that 125 per channel? Or 250 per channel..... Cause you can get sometimes
E.g 4 x 800 = 4 x 200watts per channel..
I haven't run a capacitor yet if you have a good battery that doesn't lose a lot of voltage you should be good..
In saying all this I have to watch what I say cause in the end im still learning also.. But I'm guessing it won't be long now till the other blokes on here that no there crap back to front to also put the 2cents in and everything will be much easier
