So I have a pair of RE SXX 15D4's and will be running 2500 RMS @ 1ohm.
I want a box that will have that .... if you will "impress your mates" factor lol SQ is not really that imprtant, but if I can get it at the same time I wont complain.
I just want it to give you that internal chest vibration that we all love!
Now I have read alot about "frequency" that the box will be tuned at ... but dont truly understand what it means nor what I should aim for ...
RE recomends 34hz 4.0+ PD? Not sure what the PD means ... does it just mean 4.0+ cubic feet in a different term? Sorry guys im new at this lol
Its going in a Hummer and I have a massive amount of room for the box. I added a pic of the trunk area with dimensions.
If possible id like to fire the subs up, and have either one central port and 1 port on each end (not 1 port on one side) i want the box to look even.
I dont really want to come above the top of the rear seat if possible but I will if I have too.
Id like to mount the amp on the back of the box if possible ... (back side meaning when ya open the rear cargo door you can see amp.) I may try and build the amp so its under clear perspex like a window to see the amp. So the box will have to be shortened up a few inches I guess if I wanted to do this ...
Any ideas, help or design pictures would be wonderful, I hope my photoshop skills are ok for you guys to understand the dimensions .... only one I couldnt really draw an arrow for was for the distance between the top of the rear seat to the back door when it closes, so I just put that in text.
I also added one to many arrows in the pic, an extra one that wasnt needed as its 1050mm same as the bottom of the cargo area lol
hmm, I could have takien the yellow defect sticker off the front windshield for the pic lol the cops dont like my 28" rims ... meanwhile a Honda civic drives past while im being defected with a door hanging off with rust, 4 different rims, and no exhaust flange gasket .... but "my" car is un road worthy ... amazing right? lol
*edit*
I actually just found this pic ... and to be quite honest this is almost exactly what I was after .... except I wanted subs facing up ... but after seeing this ... I might face them back toward the rear door ... damn what do you guys think I should do? Would one make more bass then the other? and see how the box flares out at the top following the side of the interior ... i really like that .... but it may be over my head .... hmm
Edited by Dumpedon20s, 13 July 2012 - 10:46 PM.
