Anyone used these LED push button switches
8 replies to this topic
#1 pillowpants
pillowpants
  • 168 posts
Posted 07 August 2012 - 08:27 PM
Attached File  !BctyMuQCGk~$(KGrHqEOKjUEq3-GyigbBK1tC)U8Hg~~_12.jpg   14.32K   6 downloads
I have 3 to be wired up. What resistor do i need for each one.
It has 6V stamped on the side of it.
Ive looked online and managed to find some other similar switches that say the LED's are 15mA
#2 Magnum9
Magnum9
  • 95 posts
Posted 08 August 2012 - 03:21 PM
Not sure how they are six volts, LED's like that are normally 2.1 - 2.5 volts forward voltage. The formula is input voltage - forward voltage / current. So if they are 6v then 13.8 - 6 / 0.015 = 520 ohms. I would err on the side of caution and assume they are 2.5v so would need a 750ohm. Just buy both and try the bigger one first. Only $0.40 for pack of 8 at Jaycar. Oh and make sure they are 1/4 watt
Edited by Magnum9, 08 August 2012 - 03:24 PM.
#3 TMM
TMM
    OEM+
  • 920 posts
Posted 08 August 2012 - 04:11 PM
They could have two LEDs inside hooked up in series which would get around 6v.
Agreed with the above though, try the 750ohm first and measure the voltage across the LED terminals with a multimeter. If you get a reading around 5-6v then you are right. If its 2.5-3v then you can try a lower value resistor for a bit more brightness.
#4 mihai
mihai
  • 116 posts
Posted 08 August 2012 - 09:37 PM
Jaycar and Altronics sell the same push button switches in a 12V version.
I bought one of those and wired the LED straight to my light circuit. Works like a charm!
#5 pillowpants
pillowpants
  • 168 posts
Posted 09 August 2012 - 12:05 PM
cheers guys. I managed to get in touch with the seller and they recomended between a 300-1k resistor. Seems a bit too much of a variable there.
Will start high and work down. I dont want them bright, so will prob stay high.
#6 RHI-SEE
RHI-SEE
    It's Rainin' Sidewayss
  • 250 posts
Posted 09 August 2012 - 03:32 PM
I Have them in my car.
I Think when they were wired up, they required 2 relays per switch to make them go from Blue (turned off) to Red (turned on)
They are definitly worth it tho.
#7 Hez
Hez
    SHOKIN'
  • 459 posts
Posted 10 August 2012 - 12:47 AM
I much prefer the ones designed for PC's. 24V/50mA (LED 3-12V/20mA) and can get them in a momentary(hold) or latching(on/off) versions. Also in Silver.
Posted ImagePosted Image
Grab em from Performance-PCs pretty cheap.
Just for those who are interested :)
#8 Marc ♫
Marc ♫
    3kW Power House
  • Admin
  • 18,352 posts
Posted 10 August 2012 - 09:19 AM
There is these ones also:
http://www.kustomimp...ttons/c_12.html
#9 SQXPRT
SQXPRT
    Digital is only on or off
  • 12,008 posts
Posted 11 August 2012 - 11:01 AM
Look neat switches.
I'd go with 750 ohm
