Okay, the subwoofer takes care of around 2 octaves of music, below and up to around 80-100hz.
Your front speakers, usually 6.5" split (components, ie a woofer and a seperate tweeter) play everything upwards, between them.
midbass is between 100 to roughly 500hz, from memory. thus, your front speakers are ENTIRELY RESPONSIBLE for mid-bass.
For SQ, you all your speakers to blend together naturally. In a properly setup SQ system, you shouldnt really be able to hear the subwoofer as a seperate, overpowering speaker. It blends in, and fills out those lower 2 octaves of music.
The high end part is the tweeter, this takes care of upper vocals, cymbals, etc etc. the larger woofer takes care of the "kick" of drums, wood instruments, etc. Keep in mind that nearly every sound will have frequencies across the spectrum.
Also, mid-bass is directional. Your brain can tell what direction sounds are coming from when they are between about 100hz and...something like 2000hz....or somesuch. Anything below 100hz, like a subwoofer, and your brain doesnt know which direction the bass is coming from. This is one reason why a subwoofer mounted in the boot sounds fine in the cabin, your brain doesnt really know the sounds coming from behind.
However, set your subwoofer frequency to high (say, let it play up to 300hz), and go sit down and listen again. You will definently feel as though theres a muffled speaker in your boot, because your now playing directional sounds through the sub. Its easy to test/prove.
A subwoofer produces deep bass, the "whump". Your front speakers provide the "kick" in your chest, provides detail to the bass.
Think about it.
Would a bass drum beat sound crap if it was muffled?
Yes. You'd only hear low frequencies. THIS IS WHAT your sub makes!
Would a bass drum beat sound crap if there was no bass, but just the holllow kick?
Yes, you'd only hear that sharp, detailed kick, no low bass. THIS IS WHAT your front speakers do.
Get any great sounding bassy system, and turn of the front speakers. It will sound muddy and crap.
Get that same system, and turn off just the subwoofer. It will kick you in the chest, but sound hollow and weak.
so. For SQ, its all about making them blend nicely together.
Both the performance of a subwoofer, and that of the front speakers, is entirely dependent upon installation.
A set of $600 speakers, mounted craply with one screw, leaking air, to your doors, will not have nearly as much SQ (midbass "kick", overall richness to the sound) as a $150 pair of speakers that are well installed.
A $800 subwoofer in a box totally unsuited to it will get its shiny ass creamed by a $300 one in a built-for-the-sub, $200 custom box.
So, to answer your questions directly.
No, subwoofer bass isnt "more important". Sub-bass and mid-bass are very different creatures, and each are equally important. Jump in any car with a system, and try listening to it with just the fronts on, then just the sub on, and you'll see what i mean. Sure, some people like to turn the sub up more than others, and perhaps have a "sub heavy" sound, but the sub itself cant play all of what you will percieve as "Bass".
IF front speakers have been properly mounted/installed, and they are of a decent brand/make/price (say, $200 to $500) they should be fine. If they arent installed properly, its not the speakers fault. That said, each companies speakers sound different, some are more bassy, some are smoother, some are "brighter"....this is why you should always audition speakers before buying them.
Now...last but not least, i should address something.
Many people choose to mount small woofers/subwoofers directly in their doors. One per side. In such a case, yes, a subwoofer can play much higher than one in the boot...it doesnt matter if you get directional frequencies from sub's in the front doors, does it? You want all the sound up front anyway!
BUT
a door mounted sub still wont play midbass as clearly as a smaller speaker dedicated to doing this.
Oh, and one last thing.
If you've heard of crossovers?
A crossover is the point at which music goes to different speakers.
say i set a crossover point for my sub, at 100hz. All music below 100hz would go to my sub, all other music would crossover to the front speakers...thats a very basic explanation, but playing with crossovers (how high the frequencies are before they go to a different speaker) can also hugely affect how a system sounds, and how good/clear/loud the bass can get.
So....theres some light reading for ya.
edit : and damn, when i started writing that, nobody had replied
edit : hmm, i might even polish this up a fair bit and submit it as a tute/sticky
Edited by Liquidity, 29 September 2005 - 11:15 PM.
