Anyone had experences with the Audiocontrol epic -160 or epi-center? I just bought a epic-160 as I'm using two Phoenix Gold Cyclones running 45hz down to 11hz and two Eclipse titainum 10s 45hz and up. Because of this setup I should be able to really crank it low. Does it degrade the sound any, or dose it still keep it clean? Who esle out there is using one?
epic-160 bass restoration curcuit
Started by really******loud, Oct 10 2005 11:33 AM
No replies to this topic
Posted 10 October 2005 - 11:33 AM
If you buy a new GM Holden and drive it into a wall, do you go back to Holden for a WARRANTY ? So why do they try it with a burnt woofer ?
Some say if a car/install was a turd, if you mould it and shape it into something great. They say its still a turd. I must be a turd polisher then!!!
"Yes, a Jedi's strength flows from the Force. But beware of the dark side. SPL, DB, ; the dark side of the Force are they. Easily they flow, quick to join you in a fight. If once you start down the dark path, forever will it dominate your destiny, consume you it will, as it did BRAD TAYLOR "
