Different class amps
Posted 11 October 2005 - 06:12 PM
now im only new to understanding how these sort of amps work. BUT. it has occured to me that they have similar distortion levels to a class AB for lower frequency but at frequency's above 6kHz they have the potential to be significantly better than the class AB.
my question is that if i run my tweeters off the class A amps and say use a class AB amp for the mid bass drivers (ill be running the 3-ways bi-amped at least) will their be phase issues? and if there is will i be able to rectify this using TA?
i think i may have answered my own question but ill still put it to u.
thx.
if this doesnt make sense just yell and ill see if i can write the post up a bit better
Also, chances are what I am talking about is absolute rubbish and that the reader shall derive his own conclusions from the above comments!
Posted 11 October 2005 - 07:07 PM
You will have phase issues if you mess up your polarity but this can occur on any amp. (eg +'ve and -'ve swapped around)
The class of the amp wont affect this though.
Is this what you were after? Or did you want to know whether the additional distortion through half of your setup will affect the SQ noticeably?
Posted 11 October 2005 - 07:52 PM
Posted 11 October 2005 - 09:35 PM
Posted 11 October 2005 - 10:03 PM
these amps were purchased for 4 grand back in 1991 and had to be imported. as far as we can figure it out only 4 ever hit australian shores. they are JVC digifine amps. my uncle used to win SQ comps bak in the early 90's with em.
i cant think of any possible issues except for power supply. i think i can overcome this with the dual battery, bigger alternator setup. can neone else think of any possible issues?
Posted 12 October 2005 - 12:58 AM
Rainbow SLC 265
Zapco 500.1
Mach 5 MAW-12
#7
Posted 12 October 2005 - 11:56 AM
#8
Posted 14 October 2005 - 01:18 PM
but for a car, it aint worth it, that whole at most 25% efficiency aint all that worth it. in a car
#9
Posted 15 October 2005 - 02:15 PM
good - cleaner sound
bad - more power at low volume
as for phase issues, you might find that the phase linearity of the class A and AB amps are different, but this will make only a small difference in the car environment.
much harder is to stop the inside of the car from resonating at 30 or more different frequencies, and resonance is much more noticable than phase distortion or phase linearity.
http://www.aes.org
TEAM Floor-Pods
#10
Posted 16 October 2005 - 08:56 AM
there constant current, so they drain the same power no matter the volume.
#11 Guest_Liquidity_*
Posted 16 October 2005 - 05:13 PM
#12
Posted 16 October 2005 - 06:13 PM
Thanks Pulse-R. its a pretty tough topic to discuss as it really goes into the circuitry of amps. i was unsure as to whether the linearity was going to cause a problem.
besides. the total draw of the amp isnt going to be significant wen compared to the whole system. my front stage alone comes in at 1000wrms.
but anyway I was thinking of either:
A) run all my tweeters off the amp if i go fully active setup
or
B) just run the center channel and rears off em wen using 5.1.
