dual 2ohm. single 4ohm. dual 8ohm subs.
4 replies to this topic
#1 jazig.k
  • 237 posts
Posted 24 April 2006 - 08:03 PM
iv got 1 two channel amp for 1 subs X 2 [2 amps for 2 subs]
each amp puts out 200rms with a 4ohm load bridged and 100rms with a 2ohm load on each channel.
dual 2ohm and run one channel for each voice coil? or bridge the amp for a 4ohm load [series]?
single 4ohm bridged...
dual 8ohm run in parallel for a 4ohm load bridged.
which ones will show what results in all areas [spl sq durability].
im thinking towards the dvc2 for the options of power when the amps get upgraded
#2 ISRAEL
  • 56 posts
  • State:Other
Posted 24 April 2006 - 08:08 PM
What are the amps rated to?
I would run one sub per amp at 4 Ohms bridged meaning that you need a SVC @ 4Ohm or a DVC @ 2 Ohm.
#3 fats212
  • 99 posts
Posted 24 April 2006 - 09:42 PM
or a DVC 8ohm (wired in parallel)
#4 jazig.k
  • 237 posts
Posted 25 April 2006 - 11:30 PM
mmm i know that they are options but i was more refering to which one would produce the best SQ or SLP or what other differences there would be.
the amps can handle 1ohm [ran them that way for a few months no problems. 2 4ohm subs in parallel bridged on one amp.] but id pefer to stay at 2ohm to keep the amps alive a little longer.
#5 mosoto
    Audioslave
  • 1,277 posts
  • Interests:Family, Musician,Cars, Computers.
Posted 26 April 2006 - 12:17 AM
8 Ohm is generally better SQ from a speaker than 1 Ohm.
If you have an amp that will give you what you want at 8 or 4 Ohm (volume + clarity)
then I would take that over a smaller amp with a 1 ohm load coppin a floggin' :lol:
Sub frequencies or not. (some would argue SQ doesn't matter below 250hz)
If you have to compromise due to lack of wattage then don't go lower than 2 ohm if you can
Edited by mosoto, 26 April 2006 - 12:23 AM.
SIGNAL PATH - PIONEER P99 - MOGAMI 8CH INTERCONNECT - 2 X ZED LEVIATHAN - CANARE STAR QUAD CABLE - HYBRID AUDIO L631 - EARS
V35 SKYLINE 350GT.
MY BUILD
