i'm thinking of using an 8inch woofer with a set of 6.5 inch splits for the mid and tweeter.
i was going to use a jaycar crossover with xover points at 800hz (LP) and 5000hz (HP), but was told it may not sound as good as if i built my own. i haven't built xovers before so i'd like to aviod this.
the speakers i planned to use were these:
http://www.soundlabsgroup.com.au/pc/V-4720/Visaton-8/Sound (woofer)
http://tinyurl.com/zsr9v (mid/tweeter)
before you knock the prosonics, i have a set of their lower market ones and they sound great. i like mostly rock AC/DC type stuff, and they play it really well, so i thought the competition ones would be even better. what xover points do you think suit these speakers? would 800/5000hz be good for it (i can't tell i'm new to this) or would something more like 1200/5000hz be better? should i look at different speakers?
i thought of using the standard prosonic crossover like this, adding an inline LP filter for the 8in woofer.
i don't know if this would overload it though or sound off.i will be running them off a home theatre amp, so they need to provide a 6-8ohm load. how can i wire up the 4ohm drivers to do this? i think i heard if they are in series it doubles the ohms, parallel halves it.
how can i do that and wire them up to the xover? if someone could find or make me a wiring diagram that would be much appreciated.
thanks in advance
