Staging, how to achieve it...
Posted 17 December 2006 - 11:29 PM
ive been reading aorund and it seems that when u tlak abotu sq u always mention staging, how do i knwo if i have good staging in my car..
i ask simply because im soon to be takign delivery of a boston pro 12.5lf and ive heard they have good sq charecteristics, so i thought why not have a crak aat caasq next year,
so now im tryign to get into it and trying to understand hwo to get my car sq comp worthy... any tips for starters??
JVC/DLS/ALPINE/BOSTON/AERPRO
Trusted traders:
-Advanceaudio- distros, relays and terminals
EBAY: -sv5g- ALPINE MRV T500
catz auto - KICKER IX252
(s-e-d-s) - JL 12w3v2
CAA: Acejas- Bought misc. items, good buyer
Wh33lz- bought above JL, very good buyer :)
Posted 18 December 2006 - 12:03 AM
Thats what it should sound like. With good imaging you should be able to tell where each band member is on that stage
4.5L of turbochaged, Quad cam V8 goodness
HU: Alpine 9855R
Front stage: Peerless HDS 6.5" mids and Vifa XT25 tweeters
Front Stage Amp: Schneider SPA-4
Rear Fill: nil
Sub: XTANT 12" hex Sub Amp: E-Audio 1000D
Posted 18 December 2006 - 06:22 AM
-==//Clarion :: OZ Audio :: Phoenix Gold :: Vifa :: Peerless :: Dynaudio\\==-
Posted 18 December 2006 - 07:52 AM
This is the sound we're gunning for in CAASQ. Imagine your dashboard as a 3 dimensional stage. Vocalist front left centre, guitar behind him/her, drums, keys, bass etc etc. The more we can identify each individual instrument and how much space and ambience there is within the mix, the better you will score. This trait is known as sound staging, and you'll hear judges refer to it often.
Consequently, a poorly tuned system should sound loose, muddy, and compressed. Instruments arent well placed and fall over the top of each other, and you lose that 3 dimensional image.
Hope this has helped. The judging discs we use are extremely high end reference recordings designed to bring the best out of systems worth many thousands of dollars. By all means pickup a copy and use it as a benchmark for tuning, but there are also plenty of well recorded CDs out there. The music & recording threads on CAA are full of examples.
Posted 18 December 2006 - 12:55 PM
Posted 18 December 2006 - 01:19 PM
firstly to clarify what a stage is.
basically, your staging is how wide and the placement of your soundstage, Like is it on top of the dash, and far forward like almost on the bonnet? or is it way down low around your feet, and coming out of the gearbox?
in terms of imaging, your staging and imaging have to work together, imaging refers to the placement of objects within the sound stage, such as the singing singing in the centre of your soundstage, and possibly instruments coming from different places across the soundstage from left to right, and also depth wise within the soundstage.
it's not tremendously difficult to achieve a good soundstage, and imaging but a few things should be considered.
1. placement of speakers.
Try to place your speakers as far away and as high as possible, Many people prefer kickpanel locations because they are "far" away from the listening position, but often means the requirement of "ambient" tweeters playing 10khz upwards, to help bring the soundstage up ontop of the dash.
alternatively, placements of the tweeters and sometimes midranges in the a pillars above the dash, are also popular, but generally have not quite as wide a soundstage to offer, but still plenty respectable.
Personally I prefer my Midrange midheight in the door, I prefer this position as it means I can use Cone style midranges, which can play a wider range, and then using the A pillar mounted tweeter works well in my vehicle (in some cars this just doesn't work) Midbass positions vary from Midway up the door, to the bottom of the door to the kick panels, kick panel positions can help widen the soundstage, but if you place a midrange in the kick panels, then usually you'll need to put the tweeter there too, or suffer from separation issues.
Each car is different, you will need to try different arrangements in your car.
2. Time Alignment,
Time alignment can dramatically effect the positioning and placement of your stereo image, as well as helping localize your staging. However, proper use of time alignment is sometimes tricky.
3. X/overs
The crossover points you choose will make a difference depending on locations of speakers,
you can shift your soundstage around slightly, by making adjustments to crossover slopes and points.
4. Equalisation,
your Staging width and Imaging locations can be modified with the EQ, certain frequencys will be more directional that others, where some will ambiently localize and widen or narrow your stage, others will specifically localize and define your stereo imaging.
Juls
Alpine 9965E + PXA-H701
#7
Posted 18 December 2006 - 07:53 PM
Trusted traders:
#8
Posted 18 December 2006 - 08:45 PM
mazda626, on Dec 18 2006, 06:53 PM, said:
I don't see any reason not to have a go,
your head unit might be letting you down in the adjustments dept,
but if you don't know how to use the adjustments, then a higher end deck probably won't help.
Juls
#9
Posted 18 December 2006 - 09:29 PM
#10
Posted 18 December 2006 - 09:50 PM
Trusted traders:
#11
Posted 18 December 2006 - 09:54 PM
#12
Posted 18 December 2006 - 10:27 PM
KickerCat, on Dec 18 2006, 10:54 PM, said:
My factory front speakers did well this year .... so don't be scared to compete with what you have, no one will laugh at you
EF XR6 Manual - Link to Install Thread
Head Unit - Pioneer DEX-P99RS
Front Stage - 5.25" Oz Audio Matrix Elite 130CS - Passive
Front Stage Amp - Butler Tube Driver Blue 2150
Sub - Image Dynamics IDMax D2 12"
Sub Amp - Audison LRx 1.1k
MEASQ - Australian Champion Intermediate Class 2006
MEASQ - Victorian Champion Intermediate Class 2007
MEASQ - Australian Champion Intermediate Class 2007
MEASQ - Australian Champion Expert Class 2008
MEASQ - Australian Champion Advanced Class 2011 (Shared)
#13
Posted 18 December 2006 - 10:30 PM
KickerCat, on Dec 18 2006, 02:55 AM, said:
- no air around each instrument
- music sounds like its all meshed together in one big clump
- this in turn affects imaging and staging, ie there is none
- and yes you are right, the stage appears more 2D
#14
Posted 18 December 2006 - 10:32 PM
now to sort out my amp problems
oh yeh... where are sq events in nsw usually held? and is there any act events?
Trusted traders:
#15
Posted 18 December 2006 - 10:34 PM
