New system in the ute, two choices, need your thoughts.
65 replies to this topic
Poll: To go Active or not to go Active? (21 member(s) have cast votes)
Which setup below would you get. See full descriptions below.
  1. Passive (8 votes [38.10%])
    Percentage of vote: 38.10%
  2. Active (13 votes [61.90%])
    Percentage of vote: 61.90%
Vote Guests cannot vote
#1 268669♫
    expert in my own lunchbox
  • 2,640 posts
Posted 03 January 2007 - 03:00 AM
Hey guys,
Going to be installing some higher end equipment than i've currently got and selling the old stuff(see below in sig) in the not to distant future and don't know if I should go active or passive.
The passive system would comprise of
Speakers
Rainbow Reference CS 360.30
Attached File  Rainbow_CS_360.30_Reference231779.jpg   22.57K   3 downloads
Subs
Rainbow Vanadium 12" (x 2)
Attached File  Rainbow_12_Vanadium_231597.jpg   17.77K   0 downloads
Amplifiers
Sinfoni Desiderio (for front stage)
Attached File  desiderio_resize.jpg   57.24K   1 downloads
Sinfoni Amplitude 150.2X (x2 one for each sub)
Attached File  Sinfoni_amp150.2x_resize.jpg   38.81K   1 downloads
And the Active system would be
Speakers
Rainbow Reference CS360.30 active (no crossovers included)
Attached File  231780.jpg   18.86K   2 downloads
Subs
Rainbow Vanadium 12" (x2)
Amplifiers
Sinfoni Amplitude 150.2X (for the woofers)
Sinfoni Amplitude 90.2 (for the mids)
Attached File  amp902xresize.jpg   24.15K   1 downloads
Sinfoni Amplitude HD 60.1 (for the tweeters)
Attached File  amp601hd_resize.jpg   35.63K   1 downloads
Sinfoni Amplitude 150.2X ( x2 for each sub)
Would are your thoughts, opinions. what would you get and why.
The head unit and processor remain unchanged.
Antony
Previously:
SStealth
Antony
#2 ultim8DTM5
    1500 - 3000w RMS
  • 2,294 posts
Posted 03 January 2007 - 03:21 AM
Ant, with either of those setups I'm sure you'll appreciate most of the comments on here will involve drool :)
With active, you will be going with six amplifiers with what you have listed there. There is quite a premium on the passive 3way References as opposed to the active 3way references, however, taking cost out of the equation I would go with less than six amplifiers on semi-active :)
Quote
Andy Jones, IASCA Street X SQL is code for "I half ass everything." Basically you are saying you are not loud enough to do SPL, and have no idea what it takes to do Sound Quality. So you meet in the middle with a quiet system that sounds like ass. Good job at being mediocre.
#3 CVBASS
    pimpin
  • 1,028 posts
Posted 03 January 2007 - 07:26 AM
I think one of the main problems with active is fitting all those amplifiers in the ute... aswell as 2 x 12"s
I think pete has the right idea with semiactive..
I'm sure all options will sound great with that list of gear :)
JVC KD-AV7008-><-Dynaudio Esotec 242-><-Eclipse PA5422 EA3422 88100Ti-><-Stinger HPM-><-Cadence ZRS9
IPB Image
#4 Juls
  • 1,222 posts
Posted 03 January 2007 - 05:57 PM
If your using the H701, definatly go Semi Active,
Passive on the mid/tweet (on the high output on your H701) and Active for the midbass to midrange setup.
in regards to the subs, if your in a ute, and SQ is your goal (obviously with those speakers and amps) I honestly would suggest going 10" or 8" subwoofers, in there largest possible enclosure, rather than 12" subs in cramped enclosures. 10" sub in a roomy enclosure will play much deeper and way more linear than a 12" in a compromised sized enclosure every time.
2 10" subs should be more than enough output, I would question the use of that quality of gear if your looking for a boombox system.
Juls
-----> New Install Thread <-----
Alpine 9965E + PXA-H701
#5 micka
  • 237 posts
Posted 03 January 2007 - 06:17 PM
I vote passive as it gives you the ability to concentrate on the proper installation of the speakers removing the many variables that inevitably come with an active setup. Admittedly, I am a fan of keeping things simple.
Personally I'd get things right passively, then if you have an issue with midbass have a look into semi active. I believe once you start getting into higher end equipment it should be more about getting things right; rather than experimentation for the experimentation's sake.
I'd probably only consider active if the rainbow crossover was deemed to be a weakness in the component set; there's probably a hint of "arrogance" in going active with a high end set of components suggesting you can do better than the manufacturer of the speakers.
QUOTE (Marc)
The "best" flavour of the month on these forums is not always the "best" :thumb:
#6 268669♫
  • 2,640 posts
Posted 04 January 2007 - 08:45 PM
Hey guys, thanks for the responses.
Space isn't a concern for the gear, either is installation quality as its being installed by the best. My main aim is tuning and the ability to keep tuning into the future as my knowledge and experience grows. I don't really want to be changing the system in a few months after I work out how to tune everything and want to customise the sound to suit me more. The head unit will also be changed when my experience grows to a Alpine DVI-9990 and a in dash foldout screen, most probably the TMI-M990.
I'm leaning more towards the active system but maybe not the exact model amps listed, maybe smaller sinfoni's for the midbass and midrange. However the subs will be 10inch, not 12 as a misquoted above. The sub box I have currently is for a ten so I will only need an identical one on the passenger side to accomodate both vanadium 10's.
Previously:
SStealth
Antony
#7 Reza
  • 660 posts
Posted 04 January 2007 - 09:06 PM
Passive that big must have something special in them. Passive for me, keep it simple and those Desiderio is effing sexy :)
MB C180
Wald bodykit
19" Lowenhart LD1
Denon DCT-R1
Nakamichi SP-5
Dynaudio MW160
SoundSplinter RL-p 12
Valveaudio SQ Reference by D.Lumanauw
Tru Tech Hammer H-1
Installed and tuned by Alex Minassian
IPB Image
#8 abmolech
  • 399 posts
Posted 04 January 2007 - 09:25 PM
might consider a couple of these?
http://car.rainbow-audio.de/products/detai...&art=271029
#9 2LOUD2OLD
    1500 - 3000w RMS
  • 2,650 posts
  • State:ACT
Posted 05 January 2007 - 08:08 AM
umm ........... all i can say is ........ Drool......
Alpine 9887 / Alpine PXA-H800 / Alpine RUX-C800 / PPI P900.4 x2 / e-audio 1000D
Scanspeak R2004-602000 / Scanspeak 10F / CSS Trio8 / AE IB15A x2
2009 Intermediate ACT State Champion
2010 Show ACT State Champion
2010 Advanced 1
ACT State Champion
2010 Advanced 1 National Champion
2011 Advanced ACT State Champion
2011 Advanced National Champion (shared)
Trusted Sellers: 37WREFGLi, brown202, niteflyer, fury, DJOLYB, muzzy66, aazn, UnsettledHawk, RHI-SEE, 268669
Trusted Buyers: S3X1T1M3, hecate, Streatz, mmingin, ktime70, Mr_Bob, peaandham, hsvmonarogen3, Cleutin, ryzaa, MR M.R., abuyahoo, V6VITO
#10 268669♫
  • 2,640 posts
Posted 05 January 2007 - 08:28 AM
That rainbow pre amp is nice, but if i was going to use one i'd go the sinfoni phaserpro
Attached File  phaserproresize.JPG   12.04K   1 downloads
Previously:
SStealth
Antony
#11 Poisoner
    My Dynamat is borrowed
  • 4,131 posts
  • Interests:gotta love a V8 with a big set of turbos on it.
Posted 05 January 2007 - 10:09 AM
id probably go passive, the rainbow passives would be a good bit of gear, and if space is limited theres no need to add more amps.
got a rough price between the 2 setups. even retial. to me the active looks more pricey(depends how much rainbow will knock off the price if u dont buy the passive)
2007 CAASQ NSW AMATEUR STREET STATE CHAMPION
2007 CAASQ National AMATEUR STREET Runner Up
Components:
///Alpine CDA-98153 Pair 4V RCA out
Audiosystem F4-380 4x95wrms @ 4ohm
Boston RC620 6.5" Woofers active
Rainbow Cal27 Tweeters active
Audiosystem F2-500 460wrms@8ohm 1250wrms@2ohm
Hertz HX250D 10" Sub 450wrms Dual 4ohm coils
#12 Ferry
  • 526 posts
Posted 16 April 2007 - 10:47 PM
~droll~ huehuhehueuehe :D I'd go with passive, as above mentioned, the xover is HUGE, must be the best picked components inside :good:
BUT either way the system would sound exquisite mate..Good luck!
#13 Pulse-R
    Digital is only on or off
  • 11,176 posts
Posted 16 April 2007 - 11:10 PM
I vote multi-amped passive.
using the 701 in 3-way+sub mode.
and mmmm, drooooool
although, with all that nice gear, you'd need to upgrade the 701 for sure.
no sense putting ethanol-laced fuel into your sonic ferrari.
http://www.aes.org
TEAM Floor-Pods
#14 JoeB
  • 31 posts
  • Interests:SL Swing Pimp
Posted 18 April 2007 - 12:29 AM
ditto.
#15 MRVJ
    HAZMAT MONITORED
  • 1,673 posts
  • Interests:HEMI! Chryslers,Dodge,Plymouth<br />Car Audio, Computers, Digital Media
Posted 18 April 2007 - 01:29 AM
but why buy a ferrari?
IPB Image
