Focal 27V1's off 5th channel on a FP5.500
14 replies to this topic
#1 Darkness_GR
  • 706 posts
  • Interests:Car Audio, Rugby Union, Triathalon, Computers
Posted 05 May 2007 - 01:55 PM
Hey Guys,
I Got my new Ute yesterday and decided to go with the full Focal Kit 7 Be, now i have to decide with the subs and amp,
what i was thinking was 2 x 27v1's, and run the Be's and the 27v1's off a FP5.500
my question is do you guys think that the sub channel on the 5.500 (300wrms @ 2ohms) will be enough power to run the 2 27v1's?
also the dealer i was talking to said that running the two subs so 4 + 4 ohms for 2 ohms to the amp (which is right, but he also said that the subs would see 300wrms each when running at 2 ohms, this is wrong isn't it, they would only see 150wrms each wouldn't they.
the subs are rated at 250wrms and are single 4ohm
cheers, Grant
Project: Beasty Triumph 2500 PI mk2 (Long term Project)
Headunit: Clarion HXD2
Sub: Focal Utopia 33WX (Old school)
Splits: Focal Utopia Be Kit no 7
Amps: Arc Audio SE2150, Arc Audio SE2300
EQ: Arc Audio MEQ30
Cabling and Other: Stinger, Dynamat
Progess needed:1/2 Stereo Install, put in a Super charged V8 Stag engine
#2 Damo95
    Team Tennent
  • 7,180 posts
  • Interests:Car audio & Architecture
Posted 05 May 2007 - 03:25 PM
yes, the subs would be seeing 150wrms each..
not sure how they'd sound being underpowered but a little more than rated goes a long way.. plus they arent as efficient as the larger diameter V1's..
imo, its hard for me to say..
Power by: Phoenix Gold
#3 Darkness_GR
  • 706 posts
Posted 05 May 2007 - 04:09 PM
or do you think it would be better for me to run the utopias off the FP2.150 i allready have and get 2 x 27v2's and run them off a FP1.800
EQ: Arc Audio MEQ30
#4 Shreknos
    Its hammer time!
  • 1,682 posts
Posted 05 May 2007 - 06:07 PM
get the 1.800 m ate..
when you load all the channels on a 5 chan down, it puts enourmess strain on the power supply, and the output may suffer...
RS Sport "SQ Edition"
Clarion HXD2
Crescendo Opus 8.6
Fi Audio Q 12"
JL Audio 300/4
JL Audio 500/1
#5 Darkness_GR
  • 706 posts
Posted 05 May 2007 - 06:21 PM
if i used the 5.500, id probably bi-amp the utopias. so it wouldn't be loading it down too much but yeah probably will go the 800
EQ: Arc Audio MEQ30
#6 Shreknos
    Its hammer time!
  • 1,682 posts
Posted 05 May 2007 - 06:29 PM
Quote
bi ampiing would involve using all 4 channels for speakers at 4 ohm, aand 2 ohm for the sub,
all channels loaded means fk all power
Clarion HXD2
Crescendo Opus 8.6
Fi Audio Q 12"
JL Audio 300/4
JL Audio 500/1
#7 Fury♫
  • 4,422 posts
Posted 05 May 2007 - 06:36 PM
Why not get a 4ch for the splits, and bridge the 2ch for the sub(s)?
#8 Damo95
    Team Tennent
  • 7,180 posts
Posted 06 May 2007 - 10:09 AM
seeing you've already got the FP2.150, i'd use that for the utopia's run passive.. c'mon, focal make good crossovers that work, use them..
and get the FP1.800 for the sub(s)..
#9 Pulse-R
    Digital is only on or off
  • 11,176 posts
Posted 06 May 2007 - 12:40 PM
Fp dual monitor for splits and fp1.800 for the subs.
http://www.aes.org
TEAM Floor-Pods
#10 Darkness_GR
  • 706 posts
Posted 06 May 2007 - 06:40 PM
Great idea if i had the money to afford both those amps at the minute.
And also how would i explain to someone that if you hooked up two of the 27v1's (4ohm SVC) in parrallel to the sub channel on the FP5.500 (rated 300wrms @ 2ohms) that each sub would only get 150wrms not 300wrms each?. and in technical terms too. if possible like calculations. and stuff
cheers, Grant
EQ: Arc Audio MEQ30
#11 mooingchicken
    mr moo
  • 1,039 posts
Posted 06 May 2007 - 06:45 PM
the amp puts out a total of 300wrms, so if there is two subs the power is divided in half, so each subs see 150wrms
Edited by mooingchicken, 06 May 2007 - 06:45 PM.
/////ALPINE . Audiosystem . Morel . Digital Design . OPTIMA . Stinger . Dynamat
Previous VL Install - Current Lexus IS300 Install
#12 Darkness_GR
  • 706 posts
Posted 06 May 2007 - 06:52 PM
i told them that, but they don't seem to belive me
EQ: Arc Audio MEQ30
#13 mooingchicken
    mr moo
  • 1,039 posts
Posted 06 May 2007 - 07:01 PM
well some people you just cant help...lol
#14 Darkness_GR
  • 706 posts
Posted 06 May 2007 - 07:35 PM
yeah very true, But does anyone know how to scientifically prove it so i can show them, like using ohms law or somehting like that.
just so i can proove im right, :D
EQ: Arc Audio MEQ30
#15 Pulse-R
  • 11,176 posts
Posted 06 May 2007 - 08:02 PM
300 watts into 2 ohms = 24.5 volts [P=IV, I=V/R :: P=V^2/R]
24.5 x 24.5 / 2 = 600/2 = 300
since the subs are in parallel, they each get 1/2 the current, and therefore 1/2 the power (same voltage applied at the terminals, into 4 ohms.. P = V^2/R = 24.5x24.5 / 4 = 600/4 = 150)
Edited by Pulse-R, 06 May 2007 - 08:04 PM.
http://www.aes.org
TEAM Floor-Pods
