1m RCA = $14,000
Posted 31 August 2007 - 08:52 PM
1 x DynAudio Esotec System 362
2 x IDMAX 12" D4
2 x u-Dimension 20VS amplifiers
1 x u-Dimension u-ProX2K.1D Comp amplifier
Posted 31 August 2007 - 09:06 PM
Some cable from Altronics, coupled with some of their decent quality RCA terminals will be ample.
BA XR6 - HERE
Want to fit a deck to your BA? Click Here
Posted 31 August 2007 - 09:08 PM
Having said that, there are some very good reasons to use good quality RCA cables.
How mcuh should you spend? I would be more than happy with the quality of a cable costing $20 per meter and $60 for connectors. More if budget permits.
CAASQ Judge
Posted 31 August 2007 - 10:45 PM
Quote
On threads such as this I have set down the challenge.
Beat 75 ohm coaxial cable. ($1.50 per metre, plus terminators.)
The challenge?
Replace that cheap coaxial cable carrying MHz (Not the minor up to 20 KHz of an ordinary audio cable) with those "fancy" twisted pair, or those expensive RCA coaxial.
Where?
Your antenna cable, going through the "noise capital" of your car (the dash)
Guess what?
No-one has been STUPID enough to try.
Perhaps easier, replace the monitor cable (coaxial with 75 ohm terminators) with one of those "fancy" cables. Watch the picture....
Point
75 ohm coaxial cable and terminators will EAT twisted pair, and those expensive cables alive. Better for carrying signal, better for noise rejection.
Disagree?
Take the challenge.
Watches as the cable merchants run for cover.
Quote from another thread.
Please, pretty please, with ice cream and cherries on top, take the challenge.
Posted 01 September 2007 - 09:57 AM
since when is 75ohm radio cable gonna make better audio?
we all know that, at audio frequencies, it's a lot of the cross-sectional area that makes the difference in the bottom end, and the stranded construction that work in the upper... materials used and overall build quality and consistency of the cable is what makes a good cable.
I've tried cheap 75ohm coax and it stinks for audio.
http://www.aes.org
TEAM Floor-Pods
Posted 01 September 2007 - 11:19 AM
First point
If twisted pair etc are so good at noise rejection, then they should be better for antenna cable. (Goes through the noisiest part of the car, the dash)
Second point
If they are so superior at carrying audio signals than 75 ohm coaxial, then they should be better than 75 ohm at carrying MHz, unless of coarse you think 20 Hz to 20 KHz is much harder to carry than MHz?
Yep didn't think so.
Take the test, unless you know that 75 ohm cable is going to set the standard.
#7
Posted 01 September 2007 - 07:20 PM
http://wireandcable.thermaxcdt.com/item/hi...9-?&seo=110
http://www.greenwood-electronics.co.uk/Cab...riaxQuadrax.asp
Luke
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
F Midbass Morel HCW8's
Subbass JBL W15Gti
Powered by ZED Leviathan
#8
Posted 01 September 2007 - 10:17 PM
Quote
I've tried cheap 75 ohm coax and it stinks for audio.
A cable is a simply defined by RLC network.
Its like using a 12 gauge and comparing it to 01 gauge wire at 1 metre length to carry 100 amps at 12 volts DC duty cycle.
Point
The 75 ohm coaxial with genuine 75 ohm terminators is over built for the job of handling audio frequencies, it can transfer MHz through the noisiest part of your car with ease.
Since this is too technical for most to grasp, I put out a basic challenge.
Please put your superior audio cables in the antenna application, or monitor.
I note that none a prepared to take it.
Until your prepared to do so, I am going to set the BS meter to full alert.
#9
Posted 03 September 2007 - 01:12 AM
EF XR6 Manual - Link to Install Thread
Head Unit - Pioneer DEX-P99RS
Front Stage - 5.25" Oz Audio Matrix Elite 130CS - Passive
Front Stage Amp - Butler Tube Driver Blue 2150
Sub - Image Dynamics IDMax D2 12"
Sub Amp - Audison LRx 1.1k
MEASQ - Australian Champion Intermediate Class 2006
MEASQ - Victorian Champion Intermediate Class 2007
MEASQ - Australian Champion Intermediate Class 2007
MEASQ - Australian Champion Expert Class 2008
MEASQ - Australian Champion Advanced Class 2011 (Shared)
#10
Posted 03 September 2007 - 01:39 PM
antisven, NowHearThis, bob^, Tiger, Tony Yayo, Marc, Damo95, dirtykia, eek, BlackIce, TEGBOY, IM.10.WR, MRSTEK, Midol, Fhrx, martydaman
#11
Posted 03 September 2007 - 02:09 PM
Dealer of | Fi Car Audio | Ascendant Audio | Sundown Audio | Powermaster |
152.6 dB = 4kW, Datasafe HX400, 2x RE MT18s and a Wall in a Lada Niva @ 56hz
141.2 dB = 4kw, Datasafe HX400 1x RE RE8 and a 1 cu ft box @ 51hz (yes we killed the RE8 on 2kw hahaha)
#12
Posted 03 September 2007 - 02:35 PM
Yes I use 75 ohm cable, with genuine 75 ohm terminators (canare)
RG60 is 8 mm diameter, probably the one your thinking of.
RG59 is 6 mm diameter
Like most cable you can get solid core or multi-strand. Multi -strand is easier to bend around corners etc.
It is "industry standard", so you know it is tried and proven. Any 75 ohm cable is over rated for the job.
With most terminators (I would guess even the $14000) have terminators that can only exhibit 20 ohms impedance. So a 75 ohm cable is well above specification.
A 50 ohm is more than adequate.
But for MHz you need a minimum of 75 ohms impedance, think radio and TV antenna, and monitor cables. For cables designed to this, 20-20 kHz is like "falling off a log".
You note NONE of these guys (cable merchants) will take the test.
Thats why 75 ohm coaxial cable is the STANDARD, which all other have got to meet or exceed. I could take the time to explain, resistance, inductance and capacitance (RLC) but this never gets anywhere.
#13
Posted 03 September 2007 - 02:42 PM
hmmm
CAASQ Judge
#14
Posted 03 September 2007 - 02:49 PM
What standards or specifications do the cable merchants meet? :clapping:
#15
Posted 03 September 2007 - 09:08 PM
There is still careful consideration needed to select the right cable for your needs, but it is not purely a $$$/result relationship.
All of the people who push those high-cost cables with exotic names, "technology," and price tags, NEVER mention these vital specs. However, look at any quality cable brand (canare comes to mind) and you can always track down the specs that matter.
