Imaging, driver location, staging and spending
55 replies to this topic
#46 Matt VIP
    Got loud yet?.....nope...
  • 4,090 posts
  • State:ACT
Posted 12 September 2007 - 06:18 PM
what should I try, proclass? reducing them both to 12db/oct slope? or overlapping the mid a bit higher?
That aside, I have made some major progress in the sound and hopefully in my understanding as well. when I had the mids in phase there was no harshness at 250-800hz, but out of phase there was. I had to reduce the EQ's in this area by heaps...
but then I tried reversing the phase on each of the mids (ie left normal, right reverse) and the harshness disappeared. EQ's came up, much better.
I havent really messed around with the mid-tweeter crossover point + slope much in the last couple of days, been mainly concentrating on the mid-sub(midbass) point. I'll have a mess around and see what it does...
thanks dude..
Matt
Quote
The only excuse for passive crossovers is their low cost. Their behavior changes with the signal level dependent dynamics of the drivers. They block the power amplifier from taking maximum control over the voice coil motion. They are a waste of time, if accuracy of reproduction is the goal.
my vibe tastes like hedgehog slice
#47 ~thematt~
  • 3,306 posts
Posted 12 September 2007 - 07:17 PM
ProClass, on Sep 12 2007, 03:09 PM, said:
Is it just me? The underlap in XO points right smack in the middle of 3K explains the image issue. With 24 DB slopes this seems rather odd to me.
I would start with XO points and reduce slopes. It is my experience that 24DB slopes have proven themselves as a tough road with respect to image.
Seas Lotus tweeters, 24db 3.15kHz crossover
Boston Z6 mids running 24db, 63Hz - 2.5kHz crossover
I thought that was a bit weird initially too, but we moved on pretty quick!! :P
And I'm currently using 36dB/oct on my mids/midbasses and Ive found its sharpened the lower end of my image. Its also decreased 'stress' at higher volumes. Worked for me!
#48 Matt VIP
  • 4,090 posts
  • State:ACT
Posted 12 September 2007 - 08:59 PM
what would your suggestions be, ~thematt~? and why does having an underlap around 3k with steep slopes affect the image? whats the technical reason?
Quote
#49 Damon
    Audio Journalist
  • 6,085 posts
Posted 13 September 2007 - 07:41 AM
I don't know if this has been mentioned yet but I thought it was worth adding.
The offset position between left and right speakers in a car environment creates both a TIME and INTENSITY imbalance. I'm mentioning this because the Pioneer time alignment system (on my P-80RS, I'm assuming you have the same unit) is a little tricky to set up.
This is because you must set the 'SEATING POSITION' function first to then allow the time alignment system to be activated.
Importantly, if you set the seating position to 'DRIVER' the P80RS will also adjust the balance level of the driver's side speakers to be louder than those on the passenger's side.
Make sure you begin with the driver position set for both front seats, then go into the crossover setting and check the levels for left and right to make sure they are set equally.
Once this is done you can 'push' the driver's side away to improve the arrival times. If the balance levels aren't sorted this can skew the results.
Damon Dupriez
Car audio editor Hot4s & Car Stereo Australia 1995 - 1999
Car audio editor Street Machine 2000 - 2002
Car audio editor Auto Salon Magazine 2002 - 2004
Car Audio editor Hot4s & Car Stereo Australia 2005 2008
Car Audio editor 2DMAX Magazine 2005 - 2006
Car Audio editor Fast Fours, Street Commodores 2007 - 2008
Car Audio contributor Incar Entertainment 2008 onwards
Car Audio contributor MOTOR Magazine 2008 onwards
Car Audio contributor Street Machine Magazine 2008 onwards
Car Audio Editor MEA Online Magazine - Jan 2010 onwards
#50 Matt VIP
  • 4,090 posts
  • State:ACT
Posted 13 September 2007 - 10:59 AM
awesome. thanks damon, however in order to access the time alignment you have to set the front seating mode to "driver" only. When I set the centre position for the tweeters i actually used a combination of decreasing the gain on the RHS tweeter and moving the balance until it more or less centered itself. However, using just the balance only, the whole image (when I put all the speakers back on) is skewed to the left by about 10-15cms from the middle of the dash. Just to check, I put on the balance test "bips" again, and sure enough, the "bips" were right over the middle of the dash.
weird...
anyway, we press on!
What are your thoughts on the P80RS unit damon, SQ and tuning wise?
Quote
#51 Damon
    Audio Journalist
  • 6,085 posts
Posted 14 September 2007 - 07:05 AM
Yeah, I knew there was the strange sytem where the seating position had to be set before the TA would work and this automatically adjusts the balance, but I wasn't sure exactly off the top pf my head if you had to have driver or front selected.
Aside from this stupid set up for the TA (which forces you to screw around with balance to readdress it) I really like my P80RS. The only other bug bear is the positive/negative display, which you can remove by again frigging around in sub menus.
I like the knob control system once you get used to to, and I find the iPod access quite fast.
All in all a great source that could be improved with a further pair of RCA pre outs to allow a 3-way crossover plus rear fill all at once ala HXD2. Still, for $849RRP it was the best value SQ soure on the market for a time. This mantle now goes to th CDA-9887 in my view.
Damon Dupriez
#52 Matt VIP
  • 4,090 posts
  • State:ACT
Posted 14 September 2007 - 09:19 AM
makes running a 3-way system with a sub a little tricky..
I'm yet to work out how my combination of JL slash amp crossovers, RCA pass throughs etc with the Pioneer HU will do it. Not that its a problem at the moment, as my subs are playing up to 200hz.
Anyway, on a more broader point, I'd just like to say a massive THANKYOU! to all those that have contributed to this thread! I'd like to think that I'm at a point now that I really need someone who knows stuff to have a listen and sort out some of the remaining problems. I think I've gotten almost as far as my ears will carry me for the moment : )
I'm MUCH MUCH happier with the sound however! The image exists, even if it's a little left-sided...I'm still not sure if inversing the phase of one of the mids is a good idea yet or not..the science is there, but the jury is still out until I can implement a proper 3way+sub system
So yeah, thanks MEA, hope to see you all possibly at wagga, and will endeavour to post pics of the trophy after the next comp :P
Peace
MAtt
Quote
#53 Pulse-R
    Digital is only on or off
  • 11,176 posts
Posted 15 September 2007 - 10:20 AM
not wanting to throw a spanner in the works - but have you tried using a 12dB slope on the crossovers?
with the mids on-axis like that, I think it would work just fine.
and the Invisabass down to 100Hz.. to keep the harmonics out of the sound stage.
http://www.aes.org
TEAM Floor-Pods
#54 muzzy66
    Alfarophile
  • 5,109 posts
Posted 15 September 2007 - 11:10 AM
Bastard!!
I must get a P90 combo one day...it annoys me that I cant go steeper then 18db/oct :(
Edited by muzzy66, 15 September 2007 - 11:10 AM.
Source: Clarion HX-D2
Subwoofer Amp: Celestra VA210
1998 Ford EL Fairmont
Source: Eclipse CD8455
Amp: Helix HXA-500
#55 Matt VIP
  • 4,090 posts
  • State:ACT
Posted 15 September 2007 - 12:29 PM
well the upper xo has been changed:
now at 3.15kHz 12db - 3.15 12db from mid to tweeter
and 200Hz 24db - 250Hz 24db from sub to mid
Pulse-R: I'm meeting up wth Sierra during the week for a quick test and tune one night, wanna come along?
i'm going to listen to it for about a week where it's at at the moment, then start changing it back to a more 2 way + sub system. see how we get on.
Thanks though!
Matt :clapping:
Quote
#56 Pulse-R
  • 11,176 posts
Posted 15 September 2007 - 12:57 PM
sounds like a plan - keep in touch
http://www.aes.org
TEAM Floor-Pods
