For those of you who want real world solutions.
39 replies to this topic
#1 abmolech
  • 399 posts
Posted 03 October 2007 - 01:58 PM
Every so often we sit back and ponder over what we might do differently to the many "failed" installs gone before.
Failed? :(
We use a stereo signal, and our stage is no wider than our drivers, and not much more than our bonnet.
Welcome to the world of panned monophonic. Moving the drivers still limits us to their positions, as the defining space.
I will mention ONE possible alternative to this madness.
Ambiphonics.
This is a viable listening format.
Try before you buy?
Hopefully at home you have stereo system. What is required is a repositioning of the speakers to the centre of the listening, facing apart by 30 degrees. (15 degree azimuth) Next is a suitable recording, or re-master.
http://www.ambiophonics.org/Ambiofiles.htm
Which vehicles might be suitable for ambiphonics?
Vans, any car with an over large centre console, or perhaps one without a centre console at all.
http://www.angelofarina.it/ASK/home.htm
Quadraphonics is simply ambiphonics with an ambiphonics rear channels.
#2 Big_Valven
    MEASQ [SA] Coordinator
  • 6,887 posts
Posted 03 October 2007 - 02:25 PM
It's an interesting technique although I think it is still less suitable than regular stereo for use in a car. The problem is the driver / listening position is still positioned to one side of the speakers, putting it directly in line with one of the speakers, which, at a rough guess, would completely destroy imaging. At least with conventional stereo, both speakers are still facing the listener, whereas what you've described would have one speaker optimally facing the listener and one facing the other direction.
Don't take this as closed minded conversation, more as technical discussion.
#3 Matt VIP
    Got loud yet?.....nope...
  • 4,090 posts
  • State:ACT
Posted 03 October 2007 - 02:26 PM
setting up an ambiophonic system is a little more tricky than that, though, abmo.
a car-pc with the right software (all in beta versions) is the bare minimum, and from what I've seen it takes a little bit of knowledge to understand how to use it all, especially when there are no "car ambiophonics for dummies" books going around. All the stuff written about it that I've found is audiophile/acoustic engineer level.
secondly, dont you have to be seated in front of the two speakers (ie have the left and right speaker at 10 degrees from where you're sitting) like this?
I'm not suggesting for an instant that its not worth looking into and trying out, but achieving a crosstalk free playback on the fly, coupled with correct speaker placement and tuning to gain the full effect seems quite complicated.
i'm enjoying reading about it though!
http://www.filmaker.com/2dsurround.htm
[jk]I reckon it might just be easier to buy a JBL MS-8 when they actually bother to release it...:P [/jk]
Edited by VIP318, 03 October 2007 - 02:31 PM.
Quote
The only excuse for passive crossovers is their low cost. Their behavior changes with the signal level dependent dynamics of the drivers. They block the power amplifier from taking maximum control over the voice coil motion. They are a waste of time, if accuracy of reproduction is the goal.
my vibe tastes like hedgehog slice
#4 abmolech
  • 399 posts
Posted 03 October 2007 - 03:46 PM
Quote
Do you completely destroy imaging on a stereo setup by not having the speakers in an equilateral triangle?
Unless the acoustic crosstalk matches the position of the speakers the answer is yes.
The question for ambiphonics is what tolerance can there be?
As long as you are within the sweet spot area, then the illusion will still work.
We know sound radiates in spheres, the question arises therefore, at what azimuth will the illusion collapse?
I suggest a simple test at home will answer this test.
I might point out that there are only two types of live concert genres.
Monophonic (or perhaps panned monophonic) is by FAR the most common.
Ambiphonics and quadraphonics is its only other competitor.
Note stereo does not feature, nor its variants, IE 3.1 , surround sound, logic7 etc.
How is it that ambiphonics can create a successful stage over such a wide listening area?
Clue
Ambiphonics has a VERY large sweet spot.
Quote
You could pre record your Cd's
Edited by abmolech, 03 October 2007 - 03:51 PM.
#5 SCorpion
  • 977 posts
Posted 03 October 2007 - 04:14 PM
i will give this a try this weekend if u can point me in the direction of how to pre record my cd's. is there a program that does it and then burns, or is it a requirement from the mike placing point of view
EDIT: found something http://www.ambiophonics.org/Ambiofiles.htm dunno whether i have gotten it to work yet. be persistent, im gonna try a few different things and then wack em on a new cd and try it this weekend!!
Edited by SCorpion, 03 October 2007 - 05:25 PM.
Please note: Any technical discussion of a topic by myself implies that your ears will be the ultimate measurement and that enjoyment of a system is the ultimate goal!
Also, chances are what I am talking about is absolute rubbish and that the reader shall derive his own conclusions from the above comments!
#6 Iceman_jkh
    Group: sex
  • 899 posts
Posted 05 October 2007 - 10:49 PM
CarPc's ?
Thats the stupidest idea ever! :P
What software would you suggest? Abmo - pity ur not in Vic, could demo you some things I have :).
Car: Holden VY Berlina
Progress: 90% Complete
Source: Fully Active Core2Duo CarPC (90%)
DAC: E-MU 1820M [24Bit, 120dB SNR, 120dB Dynamic Range]
Amps: JL Audio 450/4 + JL Audio 1000/1
Tweeter: ScanSpeak D2904/600000
Midrange: Hertz Mille 165MLK
Sub: Peerless XLS 350500
Doors: Dynamat Extreme - 4Kg/door & Absorb Pads
Battery: 750CCA Orbital Deep Cycle
Wiring: Modified Stinger "Hyper" Interconnects + Stinger 0AWG 'Platinum' Power Kit
#7 Pulse-R
    Digital is only on or off
  • 11,176 posts
Posted 06 October 2007 - 11:44 AM
The car PC would run any of the selection of plugin drivers - Angelo Farina has a beta of a realtime filter.
as for listening to stereo in a non-optimal position: If the system is truly high-end enough, I have heard now two (relatively inexpensive) systems which image perfectly from anywhere in the room. To transpose this into a car, you'd have to reduce the reflections, and would certainly need to be far-field at all frequencies above 80Hz.
http://www.aes.org
TEAM Floor-Pods
#8 SCorpion
  • 977 posts
Posted 06 October 2007 - 06:11 PM
i had a fiddle just with that program i linked and with my computer speakers and i think this may warrant some serious investigation in car!!
im curious ambolech, do u use ambiophonics in car?
#9 Wh33lzz
    Im Back BABY!!!!
  • 753 posts
  • Interests:Poontang.
Posted 06 October 2007 - 07:31 PM
Would re-mastering the Chesky 10 Best disk for ambiophonics, for use in competition, be against the rules? Im assuming only re-mastered signals will work with this type of speaker placement.
Still I like the idea of this and it's certainly worth some serious investigation.
Over-engineering is FUN
#10 austin-towers
  • 118 posts
  • State:ACT
Posted 06 October 2007 - 07:44 PM
As mentioned above, there is software for real time crosstalk removal, if you have a carputer.
Nice thread abmolech. :good:
Trusted Sellers:
Woob, Quasi, brown202
#11 ~thematt~
  • 3,306 posts
Posted 06 October 2007 - 07:52 PM
Not as difficult as it may seem. In a commodore or another large car, its almost too easy!!
#12 abmolech
  • 399 posts
Posted 07 October 2007 - 02:02 AM
To be honest I am a Monophonic fan boy. :P
I wished to show that their "other possibilities", than stereo.
Stereo relies on the "right amount" of acoustic crosstalk to give the illusion of the image being behind the speakers. This is time based, unfortunately it cannot prevent acoustic crosstalk in the intensity locational frequencies, and suffers because of this. It can produce an acceptable stage in the right room, and a small listening position.
I simply believe stereo is a poor solution for a car, because it cannot address the most pressing issue. SPACE
Ambiphonics has a much larger listening position, as pointed out earlier. If the centre console is large enough, or perhaps none at all, it maybe the "ideal solution".
It is distressing that a large acoustically innovative group, are so closed minded for sound reproduction.Especially when one can try at home without much of a time and cost prospective. I guess it may take someone "winning a car competition" to open some peoples perspective.
Congratulations SCorpion, you are one of the few intelligent people. (In my day intelligence was rated as how curious you were, rather than how much information you could regurgitate) Now if I could get some of the magic cable crowd to swap the antenna cable, that would REALLY be a feat.
I suggest you discover how wide of a listening position you can obtain with ambiphonics, changing the angle between 10 -15 degrees may be beneficial in the nearfield. If you REALLY brave, or perhaps open minded, try Quadraphonics. this is another set of delayed ambiphonics speakers directly behind you. This setup would achieve the best sound stage possible in such a poor room (car)
Ambiphonics has a similar weakness to stereo, in that it has no mechanism for vertical cues. Still the dash may present a much better option than "A" pillars, or if your keen, the interior mirror. If you use the interior mirror for small format tweeters, the illusion will trump ANY car stereo system. There is no way (OK monophonic) that stereo could possibly compete.
Quote
You are listening to panned monophonic, if you understand stereo limitations, there is no possibly of maintaining an image beyond the speakers. Yes panned monophonic is a step up from stereo.
A single monophonic setup would trounce this. Remember, the recording studio would have similar reflections.
#13 SCorpion
  • 977 posts
Posted 07 October 2007 - 10:18 AM
if it has any chance of working @ around 15 degrees off centre than im laughin. just have to work it out.
its certainly going to get serious attention. i believe that it is going to be substantially easier to install and much easier to tune. we shall see how we go, i just have to pull the dash out of the car which i have to do anyway.
:lol:
dont start on the magic cable guys, im still trying to convince ppl that the POWER cables dont make a difference
#14 abmolech
  • 399 posts
Posted 07 October 2007 - 10:36 AM
Try a mock up in your computer room.
Gauge how close you can sit to the speakers, and how far off axis the listening position can be without serious loss in imaging. It should give you some idea of ambiphonics limitations. I would suggest that it should easily surpass stereo.(It isn't exactly hard to beat stereo :P )
#15 SCorpion
  • 977 posts
Posted 07 October 2007 - 10:46 AM
done that, thats why im getting serious as i *think* it can do it.
