Mobile Electronics Australia: Strongest Spray adhesive - Mobile Electronics Australia
Strongest Spray adhesive anyone know a good brand of spray adhesive, carpet on carpet
Posted 09 March 2010 - 11:46 PM
Haven't had to use spray glue at any stage for any of my installs as im normally a staple gun kinda guy. But im re-trimming the factory molded boot carpet on the side walls of my boot (Holden VT sedan) and im just after some good spray glues that will hold the new carpet, on top of the old carpet. Any help is much appreciated.
- OA power house
- JBL noise makers
- Earthquake band
= Rattle
Posted 10 March 2010 - 05:15 AM
try supercheap auto or bunnings they would have something or a ruff idea or even try your local automotive trimmer he might be able to sell you what you need for a decent price
Posted 10 March 2010 - 06:32 AM
Maybe try thinning down some normal contact adhesive, or ask an autotrimmer.
Gl mate
HU : Alpine CDA-7998R
Amp Front : Phoenix Gold X200.4
Midbass : Dynaudio MW180's
Highs : USD Waveguides
Amp Sub : Eclipse DA7122
Sub : JBL GTi MKII 15"
Cables and Acc. : Stinger Helix, Audison Connection, PG
Car : 1972 Holden HQ Premier
Posted 10 March 2010 - 09:54 AM
Personally, I prefer paint-on contact adhesive out of a tin, for high-strength applications. It's only downside is with very thin materials (eg: thin cloth or felt) which can show up any minor lumps and clumps of glue. But for most vinyls and carpet it's fine.
MEASQ Expert Class & Show Class - Runner-Up National Finals 2009
Alfa Romeo 155 Galleries (daily driver): Car Gallery I Gallery II Gallery III Gallery IV Gallery V Gallery VI | Stereo Stage I
/////ALPINE F1 . morel . sinfoni . OPTIMA . Stinger . Dynamat
Alfa Romeo 156 Galleries (2001-2006): Stereo Stage I Stage II Stage III Stage IV Stage V
Posted 10 March 2010 - 01:04 PM
my trick is:
be sure the surfaces are clean.
spray a generous layer on the carpet which will be enough to colour it.
carefully spray a nice even layer on the other surface (the metal)
the time taken to do the second spray will help the carpet glue turn tacky
once thats done, wait another minute or so. touch the metal to ensure its very tacky, but not slippery at all.
bond your materials and away you go.
the time taken for the second spray is vital to the additional time needed for the heavy first layer. if the glue is ever gooey on either surface when bonding, it will not work or will require pressure until dry. my method has never failed me. i also use the marine floor carpet from bunnings so its its not the most flexible or materials to work with, and still keeps strong.
and adding to shiny's comment about paint on adhesive. kwik-grip is my preferred product.
Posted 10 March 2010 - 03:00 PM
One of it's main advantages is it has a very high temperature rating so you will never have issues with heat causing the glue to fail.
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
F Midbass Morel HCW8's
Subbass JBL W15Gti
Powered by ZED Leviathan
#7
Posted 10 March 2010 - 04:19 PM
GTi-FTW, on Mar 10 2010, 02:04 PM, said:
I prefer fast grip...... only cos it is slightly cheaper :P
Trusted Sellers: 37WREFGLi, brown202, niteflyer, fury, DJOLYB, muzzy66
2009 ACT Intermediate State Champion
#8
Posted 11 March 2010 - 01:45 PM
On a side note I used a can of 3M 90 spray adhesive (recommended by the autobarn sales rep, yeah I know) to retrim my hood lining and it was absolute rubiish for sticking the foam backed material to the roof panel. I ended up fixing it with the cheap supercheap SA.
Source Eclipse CD7200 MKII
Processor/Eq Audiocontrol DQX
Front Stage
Midbass - Morel Hybrid 8's = Bridged Eclipse PA5422
Midrange - Tangband W3-832SE's = Rear Eclipse PA5422
Tweeter - Arvus 1.25 Dome = Front Eclipse PA5422
Sub Bass
JBL w15GTi = Eclipse DA7122
#9
Posted 11 March 2010 - 08:21 PM
I have used both for carpeting AND hood lining / trimming and there is simply no substitute.
Painting contact adhesive on is fine... once... but messy and a pain in the ass if you want to do it often or in wierd situations.
VX Commodore - Build thread | CRO5DUP Racing KE70 Corolla | Always disconnect your battery before working on your system!
#10
Posted 11 March 2010 - 09:26 PM
It cost me $40 a can but it does do a large area.
I run out with only a small area to do so i went and bought some bostik.
What a mistake,like comparing sony to morel.
front stage crescendo opus 9.6 active
speaker amp rockford fosgate p400-4 power series
Sub morel ultimo 12
sub amp rockford fosgate 500-1tbd power series
cable rca`s stinger pro
sound deadener dynamat extreme
#12
Posted 11 March 2010 - 10:29 PM
Try a local trimming supplies, they will normally sell it as well but it will be cheaper then somewhere like Clarks rubber.
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
Subbass JBL W15Gti
#13
Posted 12 March 2010 - 12:22 AM
thought about making up some 3 or 6mm panels around the boot?? easier to trim, and could do it in a nicer material...
pm me if interested mate...
BRAD..
#14
Posted 24 March 2010 - 08:49 PM
This post has been edited by Woob: 24 March 2010 - 08:50 PM
#15
Posted 28 March 2010 - 01:27 PM
Trusted Sellers: icacha daimojay Stooge007 Sw1ft-Bass
TE Magna
http://www.mobileele...ndham-te-magna/
Sign In
Register
Help
MultiQuote
