The Latest from the Australian Mobile Electronics Industry Celebrating 10 years ... 2000 - 2010
Mobile Electronics Australia: Daytime running lights - Mobile Electronics Australia
Advertisement
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Daytime running lights Rate Topic: -----
#1 User is online   peaandham Icon
  • Why don't you go back to your home on Whore Island?
  • Group: Members
Posted 29 July 2010 - 09:05 PM
Hey guys i am wanting to get 2 LED strips to put under the headlights (or on the front bar) of my magna and i want them so they turn on with the car but turn off with the headlights.
I was thinking about running power from the cig lighter (maybe with a fuse) to the switch and then grounding the switch.
Should this work? Otherwise does anyone have any simple suggestions ?
Trusted Sellers: icacha daimojay Stooge007 Sw1ft-Bass
TE Magna
http://www.mobileele...ndham-te-magna/
View PostTiger, on 25 August 2010 - 10:58 PM, said:
Play that gif in reverse..... she's bouncing OUT of them jeans! WOOOOOOOOOOOOOOOH!!!
#2 User is online   Tobyrose12345 Icon
  • 25 - 250w RMS
  • Group: Members
  • Interests:Motorbikes and Car Audio :D
Posted 29 July 2010 - 09:52 PM
Just run wires from positive of battery to a switch in the car, then to the positive of the lights. Then ground the ground of the lights. You can turn the lights off manually when you turn the headlights off by the switch. That would be the easiest way. Doing it this way means you can also turn them on when the car isnt on (great for camping) :D
Definition: Maturity - The realisation that the volume knob also turns to the left.
#3 User is offline   artuc Icon
  • 25 - 250w RMS
  • Group: Members
Wannabee Audi... :thefinger:
Well do you want some sort of in cab control or just let them do their thing ?
Should be as easy as a run of cable from the battery to the front, there's your positive, ground it near the front somewhere. Have it go through a relay that is triggered by a cable spliced off a headlight loom that should be nearby... ground the coil somewhere nearby.
Something along those lines If I'm making any sense.
2004 Ford Courier Spacecab TD
#4 User is online   peaandham Icon
  • Group: Members
Posted 29 July 2010 - 09:55 PM
im not fussed whether i have control over them from the cabin or not but im thinking if instead of having them come on with the car and do what they are meant to i think it might be just easier turning them off and on from the switch.
TE Magna
#5 User is online   Tobyrose12345 Icon
  • 25 - 250w RMS
  • Group: Members
Posted 29 July 2010 - 09:56 PM
Then do what I said :D I did my Leds that way
#6 User is online   peaandham Icon
  • Group: Members
Posted 29 July 2010 - 10:20 PM
I came across a diagram of how to wire them without a switch,
http://img153.imageshack.us/img153/315/drivinglights1.jpg
By peaandham at 2010-07-29
Does anyone see a problem with doing it this way ?
TE Magna
#7 User is online   Tobyrose12345 Icon
  • 25 - 250w RMS
  • Group: Members
Posted 29 July 2010 - 10:23 PM
Not at all..but then you wont be able to turn them on/off at will!
#8 User is online   peaandham Icon
  • Group: Members
Posted 29 July 2010 - 10:27 PM
That doesnt bother me too much, i would prefer not to have a ricer button in my dash lol.
TE Magna
#9 User is online   Tobyrose12345 Icon
  • 25 - 250w RMS
  • Group: Members
Posted 29 July 2010 - 10:36 PM
Thats ok then :) That will work perfectly!
#10 User is offline   Big_Valven Icon
  • Voltage drop is a lifestyle.
  • Icon
  • Group: Verified Trader
  • Interests:Cars, Audio, Digital & Analogue Electronics
Posted 30 July 2010 - 01:11 AM
That means they will come on and off with your park lights, it seemed to me more like you wanted to run them whilst your headlights weren't on?
If that is the case, then it may work to grab a NC (normally closed) relay, and connect the coil to the positive of your park lights, and ground. The 12v source for the DRLs should come from an ignition ON source, not ACC ideally. Then when you turn headlights on, the relay engages, turning the DRLs off. The rest of the time the DRLs just get powered through the relay. If you want manual control, put a switch after your fused connection to the ignition ON wire, and connect the other side of the switch directly to the DRLs positive, bypassing the relay.
MEA SA SQ+SPL Competition - first in SA!
New members welcome, novice, intermediate & advanced classes.
Get involved in MEA SA's first sanctioned competition!
Posted Image Posted Image
VX Commodore - Build thread | CRO5DUP Racing KE70 Corolla | Beep Beep - SPL | Always disconnect your battery before working on your system!
#11 User is online   peaandham Icon
  • Group: Members
Posted 30 July 2010 - 08:28 AM
you wouldnt happen to have a diagram of how to wire it the way you said it would you big v?
TE Magna
#12 User is offline   sneh Icon
  • 25 - 250w RMS
  • Group: Members
  • Interests:Auto Electrics & Car Audio
  • State:ACT
Posted 30 July 2010 - 12:50 PM
Why overcomplicate things? Why would you want them to turn off when the headlights are on? You dont drive around with your parkers on do you? They DRL's are LED and draw SFA current, no need for a relay, just wire them parallel to the park light circuit, across the globe holder. Then they will come on with the parkers. with a fuse on the power wire if you want to be 100% safe.
if its a late model car, the parkers for left and right will generally have a seperate circuit each, so just pull the parker bulb out of one side, if its an older car, pull both out so as to avoid backfeed through the filament, then connect the clip of the test light to earth, then probe the pins in the holder and figure out which is the power feed when the test light glows when the parker switch is turned on. if youre using a multimeter to do it, black to earth, red to pins, then look for 12v with parkers on.
This post has been edited by sneh: 30 July 2010 - 01:02 PM
#13 User is offline   Stone Icon
  • 3kW Power House
  • Icon
Posted 30 July 2010 - 12:53 PM
He doesn't want them on with the parkers, that's why the relay (described by Big V) is using the parker circuit to turn the DRL off.
This post has been edited by Stone: 30 July 2010 - 12:54 PM
#14 User is offline   bobo333 Icon
  • 1500 - 3000w RMS
  • Group: Members
  • Interests:loud noises
Posted 30 July 2010 - 02:01 PM
with mine i just plugged them into where the parker globes used to be... but do you want them to be off when the parkers are on? if so do it how big V said...
i totally started this whole audi light phenomenon, now everyones doing it :(
SA's first sanctioned Sound Quality comp, some of MEA-VIC's best coming over to compete, Novices most welcome
Posted Image Posted Image Posted Image Posted Image Posted Image
^^^ click teh pixorz for epic build threads ^^^
#15 User is offline   Komodo Icon
  • aka ~Sparkles~
  • Group: Members
  • Interests:Brewing beers and cider, Sustainable living & of course audio!
Posted 02 August 2010 - 10:42 AM
You wanna come to noble park - every dickheads got them.
I "think" I've done this right. (although I havent played with relays for a while and the only diagram I have is pretty complex to work out whats going on.)
Feel free to correct my diagram if I'm wrong.
Attached File  relaydlr.JPG (35.78K)
View PostBIGW, on 03 August 2010 - 05:12 PM, said:
Sounds like she needs some rod.....
View PostMarc, on 25 May 2010 - 08:22 PM, said:
I have no idea what you are talking about?
Page 1 of 1
