The Latest from the Australian Mobile Electronics Industry Celebrating 10 years ... 2000 - 2010
Mobile Electronics Australia: stereo power wiring.....not working? - Mobile Electronics Australia
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
stereo power wiring.....not working? help help help help please!!!!!
#1 User is offline   02-kq-lasr Icon
  • 0 - 25w RMS
  • Group: Members
Posted 30 July 2010 - 11:23 AM
hey guys,
im not new too wiring up subs and amps, but somethings wrong in my system atm.
heres what happened.
im trying to wire up a few monitors in my boot and i was gonna wire them up to the capacitors wiring too test if they work.
as i was doing it at night and in a bi of a rush to test them out, i wired up the + and - the wrong way around. after i blew a fuse and replaced it (in the power cable from the battery) and after trouble shoooting it for the last two nights i cannot seem to work out what the issue is.... i dont seem to have power running too the boot anymore? i wire in the cap and nothing... i wire in my amp... nothing.
is it possible to burn the wire running from the battery?
the car still works and everything, i just cannot seem to fuigre it out?
is there some real easy way to fix this?
is the capacitor completely stufed from wiring it the wrong way?
thanks for any help.
im still reasonably new to car audio, but i wanna learn. the best way to learn sometimes is trial and error..... lol
This post has been edited by 02-kq-lasr: 30 July 2010 - 12:05 PM
#2 User is offline   shiny_car Icon
  • MEA MVM '08
  • Icon
  • Group: Admin
Posted 30 July 2010 - 12:09 PM
Do you have a multimeter (or even a test light) to check voltages?
I think it's simple enough. I would:
1. disconnect the cap altogether for testing purposes to rule this out as a problem
2. measure the voltage at the amplifier power terminals
If 0V, then obviously there's a power delivery problem:
*blown/faulty fuse
*bad connection: at battery, wire to fuseholder, fuse to fuseholder, at amp, groundwire to chassis
Easy enough. Once you've confirmed or fixed that power to the amp, THEN you can work on the capacitor.
Alfa Romeo GT Galleries (weekender): Car Gallery I Gallery II Gallery III | Stereo Stage I Stage II Stage III Stage IV Stage V Stage VI
MEASQ Expert Class & Show Class - Runner-Up National Finals 2009
Alfa Romeo 155 Galleries (daily driver): Car Gallery I Gallery II Gallery III Gallery IV Gallery V Gallery VI | Stereo Stage I | Stage I cont | Stage II
/////ALPINE F1 . morel . sinfoni . OPTIMA . Stinger . Dynamat
Alfa Romeo 156 Galleries (2001-2006): Stereo Stage I Stage II Stage III Stage IV Stage V
#3 User is offline   02-kq-lasr Icon
  • 0 - 25w RMS
  • Group: Members
Posted 30 July 2010 - 12:20 PM
can the wire get burnt?
if it sparks on the ends could that end up effecting the end too? like make the tip burnt nad not have a good conection?
thanks for ya help!
#4 User is online   Luke352 Icon
  • 1500 - 3000w RMS
  • Icon
  • Group: Moderators
Posted 30 July 2010 - 01:57 PM
Have you got a multimeter or test light, as without these basic tools it is basically impossible to test for power. A cheap multimeter is only about $10-$15 from Jaycar, d*** Smith or Supercheap. No some sparks won't kill your connection. Firstly though before you do any work on your cars electrical or stereo you should be disconnecting the battery.
So the process is.
1. disconnect battery
2. check all fuses (this includes checking across them with a multimeter not just looking at them)
3. check across all connections with a multimeter
4. repeat process 3, checking all you earth cables
5. failing this take it to a professional
[SIZE=1]
HU Eclipse CD7000
F DLS UR36's
F Midbass Morel HCW8's
Subbass JBL W15Gti
Powered by ZED Leviathan
#5 User is offline   spc Icon
  • Heya
  • Group: Members
  • Interests:You.
Posted 30 July 2010 - 03:11 PM
View PostLuke352, on 30 July 2010 - 02:57 PM, said:
d*** Smith
Poor guy gets his name edited!
Dont just stare at it, eat it.
#6 User is offline   shiny_car Icon
  • MEA MVM '08
  • Icon
  • Group: Admin
Posted 30 July 2010 - 04:15 PM
Wire and terminals can burn...if they heat up enough. But a fuse should protect against that - that's the idea!
But a poor connection could be made worse in your situation.
#7 User is offline   sneh Icon
  • 25 - 250w RMS
  • Group: Members
  • Interests:Auto Electrics & Car Audio
  • State:ACT
Posted 30 July 2010 - 06:00 PM
http://www.mobileelectronics.com.au/forums/public/style_emoticons/default/smile.gif
by the time a wire of that thickness burnt through, anything around it would be well and truly on fire :)
#8 User is offline   tunerequired Icon
  • 25 - 250w RMS
  • Group: Members
Posted 30 July 2010 - 07:20 PM
cheap wiring kits can contain cheap fuses that actualy dont protect against anything, in rare cases.
above is the correct method for testing your system and it is highly unlikly but not impossible to have burnt the wiring, tsk tsk when stuffing around with ANY powered wire you should always disconnect the pos batt terminal while working on it ( including just a simple wire) than reconnect terminal to test.
car audio wiring blamed for 69% of all car fires since 1996. foolish moments by people when playiong with power wires and crappy install ACTUAL cause of 69% of car fires.
dont stress by that above comment, i saw a audio installer with 25 years experiance burn out a customers car with a silly mistake, still chuckle when he tried to tell the customer it wasnt his fault
posted by ********:
pls help, got a sucking sound on passenger side
posted by *****:
girlfriend?
#9 User is offline   artuc Icon
  • 25 - 250w RMS
  • Group: Members
Posted 31 July 2010 - 09:07 PM
Have you checked the amp fuse ?
2004 Ford Courier Spacecab TD
#10 User is offline   08yannch Icon
  • 0 - 25w RMS
  • Group: Members
Posted 01 August 2010 - 01:09 AM
get a multimeter and check check check. i just got a new one the other month for $10 but didn't have a conductivity test :( so i say spring for the $15 one lol conductivity test can really make your life easier for testing circuit boards but u don't need it, and dont bother with the $200 ones they are over kill.
just set it to DC volts and test the battery, battery earth, inspect power wire for damage, test end of power wire to body, test rear earth point if applicable, and with out looking at the set up u have i don't know what else to test with out pulling stuff apart. *note remove cap just to rule that out
lol d*** smith. i was trying to tell a seller my email who_gives_2_craps@hotmail.com *note craps = s h i t s
Page 1 of 1
