MorTus
Looking at those specs.....the "general" SQ principal of tuning close to Fs applies.
It is prob a bit marginal for porting but should work quite OK.
The big issue is gonna be to deal with the port length you will need to tune low in a smallish box. I'd be inclined to use a single enclosure with the 2 drivers in it to help out, maybe 80 litres tuned 30 Hz with twin 3" ports about 320mm long. port speed a little high, but not too bad and you could add a flare to keep it nice and quiet.
You could go smaller but the ports get longer and IMO the thing will simply sound better in the bigger enclosure if you can find the space.
Hope that helps. Will go nice and deep too
HU - Alpine CDA-7876RB
TEAM AUDISON
