Full Version: Tweeter positioning
MrMike
what i want to know is where should the tweeter be in relation to the woofer (am talking about splits) i ask this because i have heard numerous sets of splits with the woofer in the door and the tweeter mounted above the dash on the pillar and something doesn't sound right to me
i would have thought the closer the tweeter is to the woofer the more accurate sound you would get, am i wrong???? if not can anyone explain why nearly every set of splits i see are mounted the way i described above???
sorry about the long post.....curiosity got the better of me
MrMike
H/U: Sony CDX-M670
Amps: Kicker IX404, Pioneer GM-X722
Speakers: Clarion 4'(indash), Clarion 6x9s
Sub: (Soon to be)Alpine Type S 12'
Car: 88 VL Commodore
Mr_Bob
they should be close together as possible, but some people like ot mount them high to raise the stage height.
'96 Mirage
Rockford RFX9300
Being installed: Focal 165W3's Vrx 2.150 & 1.500
TEAM AUDISON
I think you see so many because many ppl dont know that much about it and so do it how they see others do it.
Putting tweeters up high doesnt really raise the stage height, as a stage is more then just treble.
Anyway I always try and kleep tweeter within a handspan from woofer(6-8 inches max) as other wise you get noticable sepration from high freqs to lower freqs which I am not a fan of.
"Electricity is for more than powering windmills" Ali G
"Out beyond ideas of wrong doing and right doing there lies a field. I'll meet you there." Rumi
"forget the specs, and just listen to what is watt" Cyberpunky
All your base are belong to us! ;)
Like to know more? click here
TEAM ANY TEAM
TO VISIT MY SITE CLICK HERE
Sonic Nirvana
I had my first set of tweets on the inside of the door mirror sail plane because it didn't leave holes in my door trim, and I think that's it for many.
Take 2 sees them ~16cm from the mids, much better-integrated. I had to "bite the bullet" and make a couple holes, but I'm glad I did.
HU - Alpine CDA-7876RB
TEAM AUDISON SQ WITH ATTITUDE
as discussed, it's often a compromise between optimum position and practicality.
for optimum:
*as close to the midwoofer as possible and same distance from listener's ears (as midwoofer as well): reduces 'separation' and 'phase' issues to improve imaging; co-incidence speakers and coax's have an advantage here
*angled to lift soundstage: roughly aimed at headrest of seat on opposite side
you'll need to experiment heaps with different locations to find what suits your car and installation. most people do this using long speaker wires and blu-tac before mounting them permanently. and having them in the kickpanel areas seems to work nicely for most.
worth doing a 'search' on the subject as it's been discussed a lot in the past.
/////ALPINE audison DYNAUDIO polkaudio OPTIMA Stinger LIGHTNINGAUDIO
[Edited 1 time by shiny_car on 02 September 2002 at 10:45]
BlackIce
IMO keep all speakers for any given "stage" as close together as possible, otherwise you end up with bizzare imaging effects. Voices behind you that suddenly jump infront.. things like that.
WF Festiva: Clarion, Kenwood, Rockford Fosgate, StreetWires Small, Blue, Different
TR Magna: Alpine, Orion, Rockford, SoundStream, StreetWires Big, Maroon, Different
Idle Problems ? Clean your throttle body, IAC & fuel filter
Acceleration Issue ? Tank of PULP with 1 cup Metho & Spitfire
More Power ? Foam filter, Sports muffler, TypeR Badge
Busted Clutch Racing "Second ?"
OP
I had my first tweets in my sails as I had no idea, but now they're down near the mids, although not permanent as I haven't found the best spot for them yet. My sails have nasty holes in them now, but its all for the music right?
vti-2
Cyberpunky has summed it all up. IMO, those that you see with tweeters mounted higher up are either deaf or have limited mounting options. My cousin used to have tweeters mounted in the dash before he upgraded to decent splits in door pods and after 5 minutes i usually left the car with ringing ears. He used to leave the car grinning (that sums up his hearing).
It's a matter of experimenting although i think you are better off mounting tweeters close to the midrange.
Honda - The Power of Dreams
Honda Integra VTi-R
System in progress: Alpine, Audison, G-Spot, Hertz, Morel, Optima
Custom SQ system will debut at MAS 2003
Hutch
Here here. Tweeters belong in the middle of midbass drivers, ie Kef Uni-Q,(the only ones who ever got it 100% right, as far as imaging goes) failing that, chuck em in the door or kickpanel as close to the midbass driver as possible.
Steve Hutchison
Hutch
T-Bro
OMG - somebody who actually knows the legendary KEF Uni-Q 160Q drivers! i own a pair but i no longer have them in my system. the _only_ true co-incident drivers in car audio, but alas no-more. they sounded orgasmic, and imaging was tight and defined, with a wonderfully rich and transparent midrange. while i ended up changing them, they were some of the most live sounding car speakers i have heard. however, their laid-back 'english' sound eventually saw us part
but these were the speakers that made me a co-incident / co-axial believer
Custom SQ System
Source: Clarion DRX-9675z - Front Stage: Boston Acoustics Pro 6.5's - Centre Channel: Boston Acoustics FS50 Midrange - Ambient Satellites: Boston Acoustics 3/4" Kortec Tweeters - Processors: Audiocontrol EQT's - Subwoofers: Earthquake BR12's - Amplifiers: Kicker IX404's - Power: Stinger 1 Farad HPM Capacitor
Sounding sweet and taking it to the street
Anonymous
quote:
I have this problem(I think) My splits are noway near mounted for optimium SQ. I have My woofer flat in the door and my tweets on the dash angled toward the interior light.
When you lean towards the middle of the car(just infront of the H/U) its sounds like they are singing on top of your head very strange.
I forget what the original post was about, so this was probably a total waste of a post
Shane
System Underway
H/U - Clarion DB415
Front stage - JVC CS-HS601
Rear Fill - JVC CS-HX622
Amplifier - Proton D275
Subwoofers - MTX Thunder 6000
Sub Amp - Jaycar 2x150 rms x2(one for each sub)
KLuB KuRRI
Fumpa
quote:
i got a mate doing the same thing, but he has 6x9's as well so every high hat is like a damn knife in my ear.... and he LoVeS it!. jus makes me apprieciate my system more
tweet position= as close to mid as possible. not jus where looks good. you listen to 'em more than you look at 'em
MitsubishiMagnaTR'92
12W3vsKicker all smiles dis end-o-town
T-Bro
you're experiencing the sound come from above you because your tweeters are so high and so near glass. you are actually hearing reflections of the tweeters soundwaves bouncing off from the windshield.
the first time i experinced this phenomenon was during a major system overhaul i was doing, all i had were a pair of 6x9's in the rear shelf ti listen to until the install was done. i remember that at certain frequencies (up high generally), it actually sounded like the sound was coming infront of me and to the sides - even though the only speakers were in the back of the car. it soon became obvious that it was reflections i was hearing thanks to the glass.
so this again supports the rule of themb, to be careful with high tweeter locations near glass. they will usualy play against you, but sometimes can be used to your advantage.
Custom SQ System
Winno
They should be exactly where they sound and image best.
Experimentation is the best way to find this location.
Yes, there are some basics that you can follow and are a good point to start from but playing around with things will show you what you can do better.
WINNO
2002 NZ Pro Street Champion.
Nakamichi MF-51 changer, DAC-41 20 bit dac, CD-45z h/u
Alpine ERA-G320 processor
Phoenix Gold ZX-450 power amp
Boston Pro 6.5 components
Infinity Beta 10 subs
