Full Version: Rear loading....
NUTTTR
As everyone knows, i've had a nightmare trying to mount my alpine type r into my boot because of height restrictions (have only 279mm high worth to fit the sub into...) Now, i tried it today, no way will it fit (i haven't built the box), so i thought of rear loading, but i'm after sq, not spl, and the box was going to be a ported one as it is, sooo, my question, will a rear loading ported box (65L-70L box with 2x5" slot port, maybe) the group delay and all, will it be that bad?! I mean, i'm REALLLLLY running out of options on how to mount my sub, the big magnet gets in the way.... I would have tried other "sq" subs, but they all are too big also, and aren't what i want
Help me!
Aaron
P.S. The sub was going to be mounted on the outside of the box to see the sexxy magnet/motor
Noise producer - Clarion DRX9675
Noise Increasers - MTX 500D - Pioneer GMX-944 - Bridged to the front stage
Making Noise Heard - CDT Audio HD Splits - Pioneer Coax (Bah!)
Low Bumpy Noises - Alpine Type R - Sealed 1 cuft(Going to be 2 if i need it)
-Team SQ, A Reality Not a Dream :)
-Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
swatson
why not mount it the otherway and put a window in the box so you can see the magnet?
92 KH Laser S
Head Unit: Soon to be JVC KD-LH2000 MP3
Front Stage: Infinty Kappa Perfect 6.1
Front Stage Amp: Jaycar Response 2x150 (Temporary ~6 months)
Now i need to pay for the HU and an alarm and i am set for 6 months while saving for a sub
MISTA_BISHI
Yeah man that sounds like a good option just get some 20mm perspex. And put a nice red (i think thats the color of your volvo) neon in it to high light the sub
Marc.
The Member Formerly Known As SPL23Q!1997 Mitsubishi Mirage
Rebuild In Progress!! NEW INSTALL!
SQ ALL THE WAY!! Making The Most From What Ive Got!
JVC H/U,Pioneer Bullet Splits & Co-Axiels,
Fusion FPW-1200 Sub,FP4-500x Amp,FP2-1000x Amp,
FX-40 Crossover/Equalizer with 8 VRMS output.
Maybe intergrate some Earthquake Crossovers in too!!
Compeletion Date 17-18 Nov (Final Battle)
GOT RICE BITCH???? I DO!!!
NUTTTR
It's not a matter of mounting the sub, which way, etc, the real issue is the fact that it doesn't, fit under the parcel shelf, at all, no way does it fit any way other than the cone facing up or down... Thats a bit of PITA, but it's more the issue if the rear loading will affect sq that much... I mean, i wanna make it ported and sound good... but... i can only mount it rear loading..... no other choice... unless i change subs
I dunno what to do now....
Sonic Nirvana
Well my L7 is rear-loaded and I think most will agree the SQ is kinda "up there".
You do have to be thoughtful about it, but rear-loading and SQ are not mutually exclusive.
HU - Alpine CDA-7876RB
TEAM AUDISON SQ WITH ATTITUDE
if it fits, i would've thought having the sub fire upwards to be fine. and either have the port firing upwards or rearwards.
good luck
/////ALPINE audison DYNAUDIO »»»morel polkaudio OPTIMA Stinger LIGHTNINGAUDIO
NUTTTR
Hmmmm..... Interesting idea.... it *might* fit... It'll make a DAMN narrow box...... how much room does there need to be between the sub and the top of the boot?
Aaron
the[K]id
Actually, rear loading should be good for SQ, as the wave won't have distructive interference.
Weaponx: "Im starting up a new team, its team "Craig David" "
bluemini: "weapon, have you been in to daddies medicine cabinet today??"
Cyberpunky: "forget the specs, and just listen to what is watt"
Ali G: "Let's increase da peace, and keep it real"
Team Digital-Is-A-Marketing-Gimic Member
Team Tycoon - Dollers n dB's
Team Gates - teamgates.org
importsfreak
I agree with shiny car, have the driver firing upwards (not sure where to aim your port though). Thaz what i'm doin but with a sealed box
Car sound systems are not rated by their performance or sound, it's rated by how many chick's u pick up goin along chapel!
1990 Toyota Cressida
Clarion Head unit
Clarion 6.5's x 4 150w's
UPGRADING ASAP
TEAM X-Treme Prime Member
quote:
given the height of the sub is 178mm (from back of mounting flange to backplate) + 17mm (from back of mounting flange onto front of sub/surround) = 195mm = 7.7"
then allow 18mm mdf plus ~2" behind the backplate of the sub and the wall of the subbox = total ~10"
i'd allow at least half the height of the subbox (so ~5") between the sub and the underside of the parcel shelf. so you'd want at least 15" to play with.
but i gather you haven't got that much.
you could consider a wedge shaped box, with the sub predominantly firing upwards, but angled down a bit towards the back of the car.
good luck
BlackIce
I did a whole heap of testing with the subs in the Magna.. firing into the cabin or straight up ended up with bad booming and a very muddy sound. I've ended up going for a rear-load for the sake of smoothness and clarity of bass.. Food for thought
WF Festiva: Clarion, Kenwood, Rockford Fosgate, StreetWires Small, Blue, Different
TR Magna: Alpine, Orion, Rockford, SoundStream, StreetWires Big, Maroon, Different
Idle Problems ? Clean your throttle body, IAC & fuel filter
Acceleration Issue ? Tank of PULP with 1 cup Metho & Spitfire
More Power ? Foam filter, Sports muffler, TypeR Badge
Busted Clutch Racing "Second ?"
