Full Version: Monoblock recommendations?
Einschwein
Hi everyone,
Can anybody who's had experience with a 2001 s12l7 give me a recommendation as to an appropriate amp?
I'm considering an mrd-m500 as they are cheap, but as other options I'm considering the lrx 1.400, jl 500-1 and lanzar 1200d.
I'll be running a d4 sub with vc's paralleled in a sealed box. Which of these amps would be best for SQ?
I'll be running hybrid 5s as front stage off an lrx 2.250 when i get the cash but for the moment i just want to make a start with the sub as my front stage is tolerable atm but i want to have some bass.
Car: Mazda Capella Supercharged Diesel (Not too slow and cheap to run)
H/U: Sony CDX-4005 (It was cheap at the time)
Amp: V-Net250 (To be used for rearfill later)
Sub: None atm considering s12l7
Fronts: Cheap 4" splits off H/U (soon to be rearfill)
Rears: Stock (Disconnected as 5wrms speakers are a joke)
Mr_Bob
what's your budget?
for ~$2-3000 (i think...) a Vrx1.500 at 2ohm will give you 1000WRMS to play with, which is what the S12L7's are rated to (from memory)
Critter runs his off a JL 500.1, which gives ~620WRMS (i think) into 4, 2 or 1ohm load.
i think his amp was considerably under $1000
'96 Mirage, currently resembling a tin can
TEAM AUDISON
Sonic Nirvana
Cannot say well enough about the JL 500/1, excellent amp: tight, clean, strong, efficient (doesn't tax the electrical system near as bad as the A/B amp that preceded it). Also very flexible amp for set-up.
The LRx 1.400 would be a good choice too. The others would be good, but I would pick from those 2.
HU - Alpine CDA-7876RB
TEAM AUDISON SQ WITH ATTITUDE
quote:
all these amps are very good. and indeed the alpine is excellent value. another good value amp to look out for would be the new coustic class D ones: coustic amps .
of those you list, i suspect the JL would provide the best performance and grunt. the technology packed into that chassis is impressive. and critter's system is testament to it's abilities.
good luck
/////ALPINE audison DYNAUDIO »»»morel polkaudio OPTIMA Stinger LIGHTNINGAUDIO
RM Audio
D class Pfffft!
This is a SQ forum and your talking raw muddy power!
Shame on you Shiney!
If your going to use an LRx later why not keep it matched?
The LRx1.400 is 350 @ 4 650 @ 2 and 900 @ 1 Ohm.
RRP $1039 - CAA Members $935 with a free 4.5m RCA lead.
And they are very clean!
To quote a recent release from Audison.
"We could have taken the digital path, it is much cheaper and easier to construct however, it did not meet our requirement of absolute sound quality."
Phil Kent
Australian Importer/Distributor:
Audison - Amplifiers
Hertz - Speakers and Multimedia
Morel - Audiophile Car Audio & Home Cinema Speakers.
Audison Cable - Cables of the Highest Quality & Purity
AZ Audicomp - Advanced Installation Components for Professionals
http://www.rmaudio.com.au
[Edited 1 time by RM Audio on 23 September 2002 at 18:32]
quote:
Originally posted by RM Audio:
D class Pfffft!
*goes into corner to hide*
you can at least spell my tagname correctly!
Soundwerks
DLS Ultimate A6 RRP $1399
Class A/B Monoblock
500 @ 4ohm, 870 @ 2ohm, 1000 @ 1ohm
DLS D1000 RRP $999
Class D Monoblock
350 @ 4ohm, 700 @ 2ohm, 1000 @ 1ohm
Contact me for further specs or stockists.
Paul
Premier Distributors
DLS Car Audio (WA)
Brown Bread (WA & SA - dealers wanted!)
New products comming soon!
<A HREF="mailto:protech@iinet.net.au">email me</A>
Einschwein
Has anyone heard both the jl and the lrx running a similar sub to give an opinion as to which sounds better.
Is there any audible benefit from the class ab or does the jl still achieve good cone control.
both will offer excellent cone control, no probs there.
theoretically, the audison will provide a cleaner, less distorted signal. however, there will be much more to the overall SQ than just the distortion/class topology. so the amps may infact sound fairly different, but possibly not coz of the class AB vs class D configurations.
IMO, you will be very happy with either of these amps. they are both excellent.
if the 'power supply' to the amp is of concern (eg: small alternator, old/small battery, thin powerwire, etc), then i suggest the class D will offer better results given that it will require less power to perform optimally (by virtue of being far more efficient).
if you're more a purist, and have the powersupply to back it up (you won't need anything outrageous, just good condition car and at least 4awg powerwire to run both your amps), then consider the audison.
but for me, a big reason would be to cosmetically match both your amps so use two audison's.
