Maybe not SERIOUS issues, but important nonetheless
Now, my issue is this.Imagine for a moment that you have a set of very nice midbasses (7") that sound/image EXCELLENT... you've got a xover with a 60db (yeah, 60db) slope... You have the knowhow to modify the xover incase the tweeters you get aren't the right ohmage, therefore changing the xover point... Now, would you take:
Option 1: Buy Dynaudio MD100 tweets and modify the xover to get the right xover point, (i like the sound of these tweets btw!) and have a 2 way f/s... Cost: about $360 for tweets (pair)
Option 2: Get a set of 4" Morel Dotech splits, use the current driver+ very modded xover's to make what would be a really nice f/s... Cost: $309 just for the splits+xover+tweets...
I *think* Marc has this set up, correct? Using the supremo tweets and an 8" driver instead? Hmmm....
Install wise, i think i'd mount the tweet and the midbass in the kickpanels (ECU needs to be moved, PITA but doable) and the 7"s in the front doors, MAYBE ported using the door as a chamber, OR creating a 5L sealed box on the bottom of the door using the trim and MDF (from my calculations there should be *just* enough room to make it flush and use mdf to create a 5L enclosure..)
What are peoples thoughts? My system is REALLLLLLY starting to come together and even in it's current not working properly state, the imaging is "getting there"....
In case Marc reads this - Offer some advice :P
THanks all
Aaron
Noise producer - Clarion DRX9675
Noise Increasers - MTX 500D - Pioneer GMX-944 - Bridged to the front stage
Making Noise Heard - CDT Audio HD Splits - Pioneer Coax (Bah!)
Low Bumpy Noises - Alpine Type R - Sealed 1 cuft(Going to be 2 if i need it)
-Team SQ, A Reality Not a Dream :)
-Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
