what's this dolby II 3.1 T-Bro's been talking about? i'm curious as to what it is in comparison to 5.1.
what processor and speaker requirements are there?
[Edited 1 time by shiny_car on 28 September 2002 at 21:34]
hehehe
quote:
Originally posted by ubugger:
I think t-bro's idea is to change his h/u and use his existing centre speaker, etc, to allow d/d without rears, as this drags the stage backwards, and, honestly, how many of us listen to music in the MIDDLE of the band?!
there are very, very few cars in australia running DPL2 5.1 (let alone 3.1) but it will increase with time. you can go to www.dolby.com and click on the "surround in motion" link to see what DPL2 is like for the car. anyone coming to Final Battle is welcome to have an audition of my own vehicle to get a taste for its potential - i can switch instantly between 3.1, stereo, and time aligned stereo, so you can get a feel for the qualities of each format side-by-side.
quote:
Originally posted by T-Bro:
this is a format invented by Dolby Laboratories called "Dolby Prologic II" and all it is, is a decoding format that lets you play regular stereo CD's (or video, or anything 2-channel stereo), but the decoder then splits up the stereo into left, center, right, rear left (surround), rear right (surround) and subwoofer (the point one). so in effect, dolby prologic II takes ANY stereo recording, and converts it into 5.1 (very similar to DVD 5.1).
), is a nifty alpine PXA-H510 dolby digital 5.1 processor. it doesn't have dolby prologic II from what i can gather, but does offer alpine's proprietory "bi-phantom capability" to feed the centre channel from stereo info. doesn't sound as schmick, but hopefully still effective.
i guess if i wanted to i could use the onboard amp inside the headunit to run the rears with a switch inbetween each, just for demonstrating 5.1 surround in the car. in fact, if/when i ever go into multimedia, i may do this very thing because i can see potential for 5.1 surround with in-car movies and games.
- the best option is to use a midrange of similar tonality to your left/right channels.
quote:
- as for location and aiming of the centre speaker, i found that up on the dash facing up isn't that good
- as for processing signal for the centre, this is the tricky part.
) however my original advice regarding dashtop location remains. this will put the centre significantly off-axis rolling off response and creating reflections that will amplify higher frequencies - the result *may* be a thin and hollow centre image that is easily localised (at leat that is what my experiment found in my car). that, and the dash top will place the centre speaker significantly higher that your left/right speaker arrays, so it will be harder to trick you brain into having all three blend. im sure you will get a good result, but it may just be harder - thankfully your alpine centre processor has gain and EQ adjustment so it will make life easier when you have to tune it up
i guess if its possible, experiment with minor angles and EQ'ing so that you can use the windscreen reflections to your advantage to spread the image out a little. you may lose some defintion, but it will melt into the soundscape more evenly.
so you can play CD's, tapes, FM radio, VHS movies, games etc, and the DPL2 decoder splits the stereo up into 5.1 channels. so its very versatile, and ensures you can use all your favourite software with the new system. its basically analogue 5.1 surround for everything
turn off the rears and its 3.1 with very similar characterstics as a good stereo setup (ie, ideal for music). go to www.dolby.com for more info Prologic II in general, and also its application in the car.
gotta say for the first time, i am actually toying with the idea of multimedia due to the potential offered by 5.1 surround for movies - but mostly im interested in 3.1 for music.
quote:
Originally posted by Slaz:
is that speaker to small to reproduce the centre channel enough to be worthwhile??
Have you spoken to Clarion Australia about your little experiment? I can't imagine any better example out there that truelly highlights the benefits of this headunit, anyway, thats just a quick thought.
. I'll be doing some ringing as soon as I get to work, and get access to some free STD phonecalls,
From there I'll confirm exactly what this particular store has on its demo boards. The name however eludes me at this point of time, its a relatively well known store in Canberra, located in Fyshwick, I'm sure all the Canberra guys know what I'm talking about.
for my application a 5 inch was as big as i could go. but what ive found interesting is that the 5 inch boston pro centre works wonderfully with the 6 inch boston pro L/R drivers, in that the 5 inch has a richer and a little more detailed midrange which seems to complement the warm midbass of the L/R drivers. in effect, a quasi 3-way setup
just grab a spare set of tweets, hook em up, and put each tweet on the dash the exact same distance from the nearside listener as the original tweet (do for each side). then post the results!!!
but i suspect that the centre speaker packages aren't that cheap themselves, i think i priced one once at around the $500 mark
