Full Version: something is wrong
eunos2envy
ok i have a problem i have 2X 12 inch fusion
spec's are
fjl1211
Distributer:Fusion
12" Jonah Lomu Subwoofer - 1300 watts - 300 oz Magnet Structure - 3" Black Alloy DVC Voice Coil - Impedence 4 Ohm - Free Space Res: 28Hz - Efficiency 89dB - Frequency Response 21Hz to 1.2KHz
and i have a fusion powerplant 1404 amp rated at 100 rms each channel and its a 4 channel, i'm running each channel into each coil, is that right so far but it sounds **** like not loud enough i got told to make the box as big as i can and i did can some one please help me the box is not ported but is partition, my one jaycr vemon's runing 80RMS sounds better than this!
Head Deck: Pioneer 6450 (Thanks to mooks66)
Front:Fusion Powerplan Splits
Back: Friends singing
Sub: 2 X 12" Jonah Lomu Subwoofer
Amps: 1X Jaycar 4X50RMS to run front and rear
fusion 1404 to run subs need to upgrade not enough power
quote:
it's quite possible the amp is no where near powerful enough for those subs.
i don't know much about fusion stuff. maybe you can find some more specs:
*RMS power handling of subs
*Qts, Vas specs of subs (presumable Fs is 28Hz)
*size of the box you're using
*car and position of box
is this a permanent amp for them? coz it doesn't sound ideal; it's not capable of producing its best power output when each channel runs at 4ohm (instead of 2ohm).
are the gains set properly?
later...
/////ALPINE audison DYNAUDIO »»»morel polkaudio OPTIMA Stinger LIGHTNINGAUDIO
nemesis
you mean you have one channel of each of the 4 on the amp going to one voice coil of each of the 2 subs? you'd have to be real careful how you set that up, plus as shiny suggested 100rms is nowhere near enough for those subs
Pioneer,Soundstream,Total Recoil,Rockford Fosgate,Alpine,Stinger,Dynamat and Odyssey
...Who need's a back seat anyway?
team SOUNDstream
[Edited 1 time by GMHVNS on 15 October 2002 at 10:07]
Slain
thats no way near big enough! the reason the jaycar sub sounds better is it doesnt need anywhere near as much power. I would be pumping 1000rms per subwoofer if it was me. Lomu subwoofers are big and beefy and un-efficient so they need a heap of power to get ogin
Marc A
1968 Ford Cortina Mark 2 (Rare 2 Door Model)
1998 Suzuki Across
///ALPINE Oz Audio Pioneer Infinity MTX KENWOOD AERPRO
- 134.7dB with 100rms of Weconic Grunt!
- PROUD SUPPORTER OF THE CAA SPL PROJECT
- CAR AUDIO Magazine - A date is set! Late October!!!!
- No More Milky Bar Kid, I'm The Copy / Paste Kid!!!!
Team Gates
eunos2envy
is it ok to run just one VC on a DVC sub??
the[K]id
You can, but it will have several effects, mainly:
The T/S specs will change (you need a different box)
And you get half the power handling.
Generally, not recommended doing it.
Weaponx: "Im starting up a new team, its team "Craig David" "
bluemini: "weapon, have you been in to daddies medicine cabinet today??"
Cyberpunky: "forget the specs, and just listen to what is watt"
Ali G: "Let's increase da peace, and keep it real"
Team Digital-Is-A-Marketing-Gimic Member
Team Tycoon - Dollers n dB's
Team Gates - teamgates.org
