hobzta
Mar 8 2003, 06:31 PM
I am chasing some opinions as to what front stage amp I should use.
I will be running the Clarion SRS1750HX 6.5inch splits in the front stock locations (bottom of front doors behind door trim) and sound deadening the doors.
The 2 amps that I am tossing between are the V-Net 450 (4x50WRMS) or V-Net 2100 (2x100WRMS).
The amp will be deadicated to running the front stage only, atm it will just be those splits, possibly could be an upgrade to a 3-way front stage with 8's, 6.5's and tweets in the future.
Which would be the best way to go ?
zayne
Mar 8 2003, 06:36 PM
Ive got a VNET 2100 running my Infinity splits up front. Not a bad amp. Does put out a fair amount of power.
hobzta
Mar 8 2003, 07:28 PM
power wise they will be about the same (the 450 when bridged will prolly be a tad more)
I'm mainly talking about power -vs- channels ETC
Sonic Nirvana
Mar 8 2003, 08:47 PM
Unless you have a reason to use 4 channels, go the 2100.
HU power is fine for rear-fill.
Foe subs, a dedicated amp is MUCH better than 2 50watt channels bridged.....
hobzta
Mar 8 2003, 08:48 PM
yeah that's my plans critter.
the rear-fill will run off the h/u, I will ahve 2 dedicated sub amps, and the dedicated front stage amp
Mar 8 2003, 09:09 PM
what's your budget and are you limited to these 2 amps?
you'd probably want around 60+WRMS on tap per channel. if not a clarion, but you also want top value, look at either coustic or cadence. from there you could step up to an alpine V12, hertz, PG tantrum or audison SRx.
hobzta
Mar 9 2003, 12:00 AM
yes it is these 2 amps shiny I thought you would have remebered by now, I am goin all Clarion (j/k's)
Mar 9 2003, 04:46 AM
hee,hee, ok, how about the better series APX201-2 2x50WRMS amp? should be nicer than the VNET models.
dasherhalo
Mar 10 2003, 02:40 AM
Get the two channel. If you're planning on upgrading to a 3way front set-up, then you can add another amp specifically for the 8's later.
While a bridged 4 channel might work well ATM, I don't think 4 x 50 will provide the grunt for a bi-amped 3way system.
hobzta
Mar 10 2003, 12:04 AM
I thought about that, but my sub amps will be the V-Net 4150's and I would prefer to keep them all in the same series for the install
