T-Bro
Jan 29 2003, 12:51 PM
A question out of curiousity:
What is your favourite subwoofer crossover point (for SQ purposes only) and why?
Out with it!
roughcactus
Jan 29 2003, 12:56 PM
usually about 65-70hz and with a steep slope....harder to localize bass with a lower crossover point also i find it minimizes the slight bumb you get at about 90 hz plus which can make your system sound somewhat boomy.....i usually high pass my fronts at about 80 to 100hz to notch out that that problem area
jambo
Jan 29 2003, 01:28 PM
Around 60Hz with front stage either not high passed at all or as low as they go. Really brings bass to the front and eliminates that good old boomy frequency that can take your head off
Mickee
Jan 30 2003, 02:03 AM
Subs - 80-90 Hz LPF
Splits - 65 Hz HPF
Both with 24db/oct slope
NUTTTR
Jan 30 2003, 02:12 AM
f/s ~80hz
sub ~63-65 or something, i like it looww
rolli
Jan 29 2003, 11:22 PM
I have always used 90Hz as a start point, and played around until I get it right.
Front not trying to go too low and sounding cr@p, sub nice and smooth, and the bass sound not in the boot, or as mentioned 'boomy'.
"Play people, thats why they put buttons and knobs on inanimate objects" (forget where that quote is from - some movie)
vanboy
Jan 29 2003, 11:43 PM
low end cut off is 30 and high is 100. you can do that with isobaric. ;P
the box(es) has/have to be as far away as possible and pointed away to sound sweet tho...
fs @ 100hz at 18db (still testing it atm)
sub @ 80hz at 12db (it cant go any lower probably
Jan 30 2003, 03:36 AM
70Hz with a 12dB/oct LP filter was what i had my previous setup tuned to. worked nicely. and it's actually a very narrow bandwidth with my sealed setup; the sub doesn't go very low, with anything below 40Hz rolling off dramatically.
new subamp has steeper 24dB/oct over, so could afford to go a little higher, but i still plan on starting with 70Hz. combined with rear-facing sub (new box) and better amp, hopefully it will be even better.
i guess lowish LP filter settings require a good front stage that can work with a similarly low HP setting. all in the name of more midbass upfront and improving the upfront subbass effect.
ripped
Jan 30 2003, 11:54 AM
i have mine on 50hz for both the sub and fronts. sub gets 24db slope, fronts get 18db slope.
T-Bro
Jan 30 2003, 01:39 PM
thanks for the responses
well i have just recently changed to a 50hz LP setting for my subs, and am very impressed with the warmth but more importantly, more seamless integration with the front stage (ie Bass Up Front, or BUF). it almost sounds like there is a sub inside the dash, which i love. the subs are thus much harder to localise (and this is all without time alignment, forward firing).
i notice alot of you like the 70-80hz LP range, i used to use this too (well i still do for doofing around town, but not for SQ). i just found that with the sub's up that high, it was harder to get them 'up front', though it certainly *can* be done, and ive heard systems where it was achieved superbly. i guess it depends on the front speakers used, and how they are mounted etc.
someone mentioned using NO high-pass for the front speakers at all, to get them to play lower and thus draw the bass up-front. has anyone had any problems doing this, in the longer term? obviously the speakers power handling would be reduced, but there are alot of 6" drivers i imagine would be up to the task. im willing to try it, but would like to hear from those who have trialed it for a while without damage to the drivers or any audible bottoming-out.
Sonic Nirvana
Jan 30 2003, 01:51 PM
I use 80Hz HP front and 70Hz LP 24dB on the sub, but I'm in the process of changing that for SQ.
bassmekanik
Jan 30 2003, 08:09 PM
for sq i like 80 both ways
for just showing off bass 160 as that allows speakers to play loud without breaking up and low to mid volume booming as low as i can get it i used to have my subs at 40 hz and speakers full range
Jan 30 2003, 09:48 PM
I use 50Hz Lp on sub and 60Hz Hp on fronts. Even though Im using 24 dB slopes in both I still prefer a little underlap (gap). I find this gives great BUF and doesnt compromise speaker power handling of fronts.
The other issue, as someone already raised is that Im running 8s up front so going down to 60 isnt a problem. I wouldnt go any lower though as its not needed and as stated will effect power handling.
Sonic Nirvana
Jan 31 2003, 11:21 AM
Not prepared to put 8s in my front doors tho'.
No risk that ultimately it's the way to go....
trev
Jan 31 2003, 01:20 PM
MMMM, I run my Boston Pro's full range and have the sub cut off at about 60 hz don't remember the slope but its pretty steep,
everything runs of a mtx 6304 so I guess the fronts are getting about 110rms
the setup sounds so good, all the bass sounds like it originates from the front ,
I don't recommend many ppl try this unless their
fronts can handle massive amounts of power
as it will destroy them.
BTW T-bro I have had 350 rms into the pro's with the cut at 80hz with no probs either.
Regards,
Trev
T-Bro
Feb 1 2003, 02:14 AM
cyberpunky: great minds think alike im running 50hz LP for subs, and 70hz HP for front stage, and like you said this provides good BUF affect and the crossover gap isnt a problem. however i use 12db/Oct slopes.
so anyone have any experience with running front speakers with NO high-pass crossover (ie full-range) in an effort to improve BUF?
T-Bro
Feb 1 2003, 02:22 AM
hey trev!
so you run your boston pro's full-range, and it sounds great huh? too cool! your feeding them significant power too (mine get about 50wrms but i also have a centre speaker and ambient tweeters so i have to share the power around). so you dont have any problem with the Pro's bottoming out or anything?
your right, the Boston Pro's can handle 400w so they are more up to the task of handling sub-bass than alot of speakers. Boston Acoustics actually sells the Pro 6.5 LF drivers for use as standalone bass drivers, in adition usage as mid-bass/mid-range drivers which they are usually used for, so supposedly they are up to full-range operation.
anyway, if it really works and the speakers still sound clean and deep, i will give it a try
Feb 2 2003, 02:56 AM
sub 50hz
mids 100hz,
would love some mids that went lower or if i could get these to go lower but they just dont like it
Walkinshaw
Feb 3 2003, 05:57 PM
Sub 63Hz LP 24db/oct
Fronts 63Hz or 80Hz Hp 24db
Ive run my MBQuart 6.5's full range before with probably arround 120wrms into them, only with extreemly low bass(under 30hz) at very high levels have i heard them bottom out, other than that they cry out for more power. Like the bostons people have put 200+wrms through the Quarts with no problems.
Once i get my 8's installed up front i will run 63hz Hp @ 24db, or arround 75Hz Hp @ 12db
T-Bro
Feb 10 2003, 05:32 PM
just a follow-up post:
i tried my Boston Pro 6.5's full-passed as an experiment. as a result, greater up-front mid-bass and even sub-bass was evident, providing more weight and noticable low end extension. while the power handling was still good at high volume, the speakers did sometimes bottom out/unload when pushed really hard - this was cause for concern, as obviously there are times when we all like to go nuts with the volume.
but the end reason why i decided not to leave them on full-pass, was that they became loose and flabby, losing their tight, clean output that i like. this lack of control forced me to return to high-passing them where their bass extention was tighter, edgier and more refined.
not to be defeated, i found a solution elsewhere - my boston pro 5.5LF centre speaker has been running 110hz HP as it is a 5" but i decided to see if it could go lower to 70hz. it did! and maintained full control but with greater mid-bass output and punchier attack.
so with all 3 front speakers HP@70hz i have now found satisfaction
Mr_Bob
Feb 10 2003, 09:36 PM
dude, you'd probably find that with more amplifier power on tap, and a more robust amp design/internals that the mids will sound less flabby at full range.
maybe we should add that to the list of experiments if you decide to take up my offer of the VRx experiment
[ February 10, 2003, 19:37: Message edited by: Mr_Bob ]
T-Bro
Feb 11 2003, 03:37 PM
hey mate!
well, im not one for amplifier worship as is known BUT i am open minded, and would be willing to patch in the vrx to see if significant and welcome improvements are evident. with some help it would only be an afternoons undertaking.
that said, my system has been commented on as having extremely fast transient attack in its current form, due mostly to my selection of speakers and headunit, but also that im running (like 98% of people) transister amplifiers which generally exhibit this (valve and tube amps on the other hand, generally give up some transient attack for a more liquid and silky response).
anyway, as my system will be at the top of its game (i hope!) by March CAASQ, i would be willing to then do an in-car amplifier test to judge any improvement/changes. and im sure there will be some change, my interest will be if its welcome, appreciable and in accordance with the $RRP of the component.
ps - the same amp (kicker ix404) i use for my front stage, i also use for my subwoofers in bridged-mode, which are low passed at 50hz (ie play low to very low bass) and they do not bottom out at full (non-clipped) volume - so it makes me think the loose and flabby sound of the full-pass 6's is more a result of their size, rather than the amplifier.
who knows!
Civic_DD
Mar 3 2003, 03:04 AM
So what procesors do you guys use to set your cutoffs so finely? I am looking at investing in something nice but i dont know where to start. Can anybody help me out?
T-Bro
Mar 3 2003, 12:29 PM
i use the crossovers in my headunit, and also those in my amplifiers.
70hz low pass. My front stage lacks midbass
i lack heaps of punch
PartyJase
Mar 5 2003, 12:16 AM
sub LP at 65hz 24db and splits HP at just over 60hz (bout 62hz i think) on 18db slope.
great midbass and integration up front altho sub sometimes overwhelmes the upfront bass but there is also slight difference in my frontstage power and sub power.
KDog
Mar 5 2003, 07:28 PM
960Hz @ 48dB/octave LP
Mr_Bob
Mar 5 2003, 11:32 PM
Kdog, you realise that runing such a high LP filter on your sub will drag your soundstag rearward?
unless of course, you've mounted your sub in the footwell or something..
i can't imagine it'd sound good either, did the car audio shop set that for you?
pingpong
Mar 5 2003, 11:53 PM
typo?....im pretty sure k-dog knows what he's doing
anyway 80hz sub (24db/oct) and when i get round to putting in the rubicon and setting the x-over (thanks again gmhvns) everything im imagining a 90-95 hp is where i'll be
Mar 6 2003, 12:17 AM
For SQ, 50hz.. for loud daily driving, 80hz..
Mr_Bob - You'd could be suprised..........
Brucee
Mar 9 2003, 07:17 AM
100hz(my HD got 0-200hz),18db slope(0-24 slope),LP, i oso feeling not right by putting the crossover at 100HZ, but its sound just right to me
BlackIce
Mar 9 2003, 10:16 AM
100hz.. the front stage has too big a "gap" otherwise. IMO anyway
Also gives some very interesting bass positional effects you wouldn't otherwise get
T-Bro
Mar 10 2003, 01:14 PM
well this weekend i experimented with a new approach, LP the sub at 120 Hz, but also use a 30 band EQ on the sub to custom shape its response. EXCELLENT RESULTS. i know it sounds terrible, but the upfront impact and weight is superb, the EQ really lets you blend the mid's and subs together. only bad thing - it sucks for hard booming
hogesJZZ30
Mar 10 2003, 08:15 PM
well ive got my subs low passed at 125 Hz, as my HU only has 50, 80 or 125 as options. I have my fronts running full and rears highpassed, not sure at what freq tho. ive tried lots of different combos of settings while driving around (im a pizza driver, not much else to do!!) and have found this setup to give the best compromise of tight, punchy bass, and still maintaining a decent soundstage up front. once i get the time/money to sound deaden my doors/boot and get a new FS amp im sure i will reevalutate my settings.
Ive had my splits running full range pretty much all the time, if im playing something crazy bassy ill hp them at 50, but thats about it. mine are also getting only 50rms at the moment, but i had them bridged for 100w before i got my rears, they were more bassy with 100w, and i couldnt notice any distortion/bottoming out of the speakers even at very high volumes.
jez
Mar 10 2003, 11:25 PM
hey dudes what's the theory behind using a hpf of say 60hz and a lpf of 50hz - that means you're losing 10hz of range, right ? which I would of thought would be pretty important down that low.. I have mine setup to overlap by about 10hz atm, but will give it a shot tomorrow - but still.. hmm
pingpong
Mar 11 2003, 12:46 AM
cause its not like a barrier, filters err taper off, so when you add the two tapering off, it kinda adds to one....errr
LP---- /----HP
now if u add the two slopes together, it kinda gives a flatish bit in the middle...i cant explain it properly....probably bassA will
T-Bro
Mar 11 2003, 03:12 PM
exactly, crossover filters are not brickwall filters, they roll off gradually, so the 'gap' is actually filled in by the roll off
[in reality, brickwall filters do not exisit, it is an impossibility, all filters must roll-off, all you can control is the rate/steepness of roll-off]
Mar 11 2003, 05:31 PM
That is correct, the crossover frequency is actually the -3dB (or -6dB depending on alignment) point, so assuming the 2 speakers are at the same level you would set the crossover point with a small gap if they are the -3dB points, or at the same frequency if they are -6dB poins..
Of course if the frequency response of the speakers is not flat around the crossover point, then some extra overlap or underlap may work better..
[ September 18, 2003, 21:52: Message edited by: Bassaholic ]
jez
Mar 12 2003, 03:19 AM
hmm interesting idea guys - thanks for your input. I gave it a burl and managed to pick up a fair bit of mid-bass - but i reckon the majority of that was because i went from around an 80hz split down to a 50lpf/60hpf. I didn't really think my splits would go that low and still sound composed, but they've come through nicely and i'm damn impressed. I reckon the best bit though is that it didn't cost me a cent which is bloody amazing for car audio!! I guess the next step is to go to a fully active front stage.. mmmm tempting thanks again!
Bodyjar
Mar 12 2003, 03:49 AM
I've got my sub LP at 80hz, splits HP at 50.... My splits can handle it, so I say why not
I want more midbass....
T-Bro
Mar 12 2003, 12:16 PM
everyone wants more mid-bass
