dsan
Mar 22 2003, 01:47 PM
Hi all, my sub has a slight lag when playing dance music and other music with loud beats and I have decided to finally look at fixing it (it was even more noticable after I installed the focals). I'm very happy with my system in most other respects but the lag has always been in the back of my mind....
Note: the system is intended for SQ
I have tried reversing the polarity of the sub but there was no change. I have just read a topic about using the time alignment feature in most high end HUs to delay the fronts long enough for the sub to appear in sync. I'm happy with my HU so I don't want to replace it so is there any way to do this without a high end HU?
gooki
Mar 22 2003, 01:52 PM
I believe if you use a 6db highpass filter (at a low frequency of say 120htz) on your front stage that should put them out of phase with the sub and create the desired delay.
Dr DJ Choss
Mar 22 2003, 01:57 PM
generally you delay your front and rear to allow them to run at the same time as the subs, with the rears a little late. but too much delay and you start to get headphone sound.
how much delay really depends on the car and it's system set up.
[ March 22, 2003, 11:58: Message edited by: Dr DJ Choss ]
Mr_Bob
Mar 23 2003, 02:02 AM
you can buy a time alignment processor, but they're not cheap. doing it passively wouldn't be fun...
dsan
Mar 23 2003, 02:13 AM
What about my sub amp? Could upgrading it boost the sub's accuracy and SQ? The Jaycar Response amps aren't exactly known for their SQ
Dr DJ Choss
Mar 23 2003, 02:20 AM
Maybe, but the box and the direction they face would have a greater effect. go for something small and sealed, or shove a few pillows in the one you've got now. Next time you're at the pub and a band's got a tight sounding kick drum happening, take a look inside the kick drum, you'll find a few pillows. Works for me too, even with a sub box that I can hide inside...
honour77
Mar 22 2003, 03:31 PM
i would still say go for a head unit with time alignment, its the most cost effective solution if you want bass upfront with minimal fuss.
I am using the bass focus function on my HU in addition to time correction for my front stage and i can tell you it makes a big difference.
I also reversed the polarity of my sub via HU, and it seems to improve slightly, but its quite a minimal effect so it may be all just in my head
Mar 22 2003, 04:02 PM
to improve the tightness try reversing the polarity of the fronts or sub, this might make them go inphase with each other. If there is no different, then they speakers are 90degrees out of phase.
By using a 400uF 100volt capacitor on the front speakers this will shift the fronts phasing 90degrees, effectively you will now notive a difference when you swap the polarity, one will be have tighter bass.
Another big thing is that the JL subs dont suit ported box's that much, so i would change to a sealed box if its ported. If the ported box is tuned high-ish (35hz) then the group delay would be high around that frequency. Reducing the tuning frequency to 25hz will reduce the lag on the sub.
Firing backwards or rear loading in a sedan can often cause alot of panels to vibrate liek the boot lid. These panels continue to vibrate after each bass beat, makign the bass sound loose like it is lagging. Deadening your boot should improve this also.
Firing forward will improve the tightness and get rid of the delay.
There are more expensive options such as buying a headunit with time delay but i would definitely try the above before you start spending lot sof money on new equipment.
Personally i would go with a small monoblock as your next upgrade, a 1ohm stable 400wrms coustic amp would blow the jaycar amp away and dramatically increase dynamics, volume and SQ in general
Mar 22 2003, 08:43 PM
yeah, altering the box may be the simplest and most (cost) effective method. what's the current box design?
dsan
Mar 23 2003, 03:28 AM
Sorry guys, I should have mentioned the box before
It's sealed, about 40L (hard to remember - I made it a fair while ago) and it fires into the cabin.
dsan
Mar 23 2003, 03:31 AM
It's hard to pick whether the beat of the sub is lagging or the bass resonating in the panels of the car make it seem like it is lagging. I think it is a little of both - one more than the other in some songs.
Mar 23 2003, 11:57 AM
the box seems ideal, and firing directly into the cabin will reduce any apparent lag.
is the front/baffle of the box 'sealed' up against the back of the seat? or does subbass soundwaves travel around the sides around the back into the rest of the boot too? it would be worth building some contoured mdf side-baffles to seal the box right up to the seat.
otherwise, i think you would get a significant improvement in subbass quality with a good monobloc subamp. however, it would be fairly costly in your situation because your 'D2' sub can only be configured for 4ohm or 1ohm. and entry-level monoblocs produce relatively poor power at 4ohm, and 1ohm stable monoblocs are expensive. so either way, you'd probaby need to spend about $1K for a suitable amp.
not sure there's anything else i can recommend here. you could try facing the sub in a different direction, say sideways, and see if that helps.
good luck
dsan
Mar 23 2003, 12:05 PM
Thanks for all of the help guys, I'll just put up with it 'cause I don't want to spend any more money on my current install (I MAY be getting another car in a few months so I will have to redo the install anyway). Although, a good subamp would be something I could always use.... I think $1k is a little out of my price range, any other suggestions on a suitable amp? Maybe something around $500-700?
How much is that 1ohm stable coustic amp that Maz mentioned a few posts ago worth?
Mar 23 2003, 12:28 PM
i would recommend it except it's in fact not 1ohm stable. it's only 2ohm stable. otherwise i'd suggest looking at it as it's excellent value around $600.
ripped
Mar 23 2003, 03:15 PM
try facing the sub back and see if it helps. sometimes doing small things help greatly
the[K]id
Mar 23 2003, 07:37 PM
I'd def look into moving the sub around. Rear wave reflection can easily ruin even the best of sub setups, esp killing the higher freqs of the sub range (getting into the beat area, rather than low hip hop note style). Try it facing as many ways as the box allows, also try each with the trunk open and closed. If it sounds better open, your getting bad karma, no, wait, bad cancellation. Have fun, and remember, SQ doesn't *have* to cost a fortune, it's always the little things in the install that really make/break the system.
Dave
Mar 24 2003, 12:27 AM
i just bought a cadence Z7000 (1500WRMS at 1 ohm) for 850 of the forum. u should keep ur eyes open there
