Ivestar
Apr 30 2003, 12:11 PM
i am trying to build a sound quality system and i am in the planning stages. I am looking at buying a second hand EQ but dont know too much about them.
My question is do you require an EQ for each output from the head unit?
i ask this because the EQ i am looking at only has one pair of inputs and outputs.
Tha Hombre
Apr 30 2003, 08:59 PM
Firstly, welcome onboard!!
I think before you start buying equalisers, processors, etc, buy some quality components and focus on installation. An eq is then only really necessary to finetune your system. If you invest in a below par eq, your system can and probably will actually sound worse than without it.
If the eq that you're looking at buying only has 1 set of RCA inputs and outputs, then it'll only be cable of running perhaps your front stage amp, or sub amp. So, yes, you will have to get another eq if you want to fully equalise your system. This is all very complicated and especially costly. Perhaps look at getting a top of the line headunit which will have all the eq features, plus time alignment amongst other things. This will most likely end up being cheaper, and imo sound a lot better rather than running one (or multiple) eq's, esp. cheap ones.
So what kind of sq system are you planning? Let us know what kind of equipment you're thinking of getting and how you plan on installing it.
Then a lot of the guys (and girls) on CAA can help you out.
Good luck with it all.
Dom
Sonic Nirvana
Apr 30 2003, 10:23 PM
Yep.
Get the basics right first and set-up and install properly.
An EQ device is really the icing on the cake.
Where the system takes you as you develop it may surprise you (hands up!!) and the EQ you look at today is likely not the one you would have when the system is together.
And trust me, hang around here and get "the bug" and thec system WILL change from your first ideas. All part of the fun
For example, in 18 months I'm on the same HU, second splits, third tweeters, second front amp, third sub amp and third subwoofer(s) (total of 4 enclosures).
And I still haven't got an EQ.....well not until Alpine releases the PXA-H700 anyway. But now I know what's needed to finish it off.
And the system is SO much better than I imagined when I started.
Worth keeping in mind.
Dr DJ Choss
May 1 2003, 12:42 AM
sometimes a good way to find out how your system sounds is to put someone in you car who knows MUSIC.
let them play their music and ask for their thoughts on how your system compares.
then, if it needs an EQ, go shopping with what your requirements are...
[ April 30, 2003, 22:43: Message edited by: Dr DJ Choss ]
ellifant
May 1 2003, 12:57 PM
what sort of stuff are you looking at buying??
pioneer make some good headunits with 13band eqs in them. jvc make some with 7band eqs and they are nice :-) (enough to give a good sound.)
but if you want top performance (comps etc) you'll be looking in the 28band+ range.
here's some rough figures:
RF symmetry epx2 (stereo w/ 28band eq card) $800 2nd hand
audio control dqt (DIGITAL stereo 30band eq + 2 parametrics) $1200 NEW
Alpine pxa h700 30band? by 5 channels+ time alignment and stack of other crap. about $1500-1700 NEW
so eq's aren't cheap, but well worth it. ONCE you've installed your system and IF tuned by a professional. but the most important thing is high quality components. no point in decent eq unless u have decent headunit, speaks, amps, cabling, batts.....
let us know how you go.
some friends and i have competition SQ stereos (money traps) and swear that the final tweaking is not possible without the black magic of a decent eq. but it all depends on what you want out of your system.
one of the cars (focal speaks, 13band pioneer head, alpine amps) got a 34/40 for sq without a 30band eq. so install is major element to sq.
Good luck
Wayne
Ivestar
May 1 2003, 01:26 PM
Thanks for your help fellas...
But i think i choked, i wen't out and bought a 2nd hand PG eq230 - 30band equaliser, proabaly abit prematurely, and maybe a bit over prived $500, without getting your advice, but live and learn.
On the positive side, i dont intend to go halfhearted with this and i am looking at spending a lot of time and money on the equipment and instalation. i intend to use an RTA and an osciliscope to set the crossovers, gains and equaliser, however i would like to do this myself.
I have about 4K to play with (not including the EQ)for my comonents, wires and instalation materials.
This is what i am thinking of getting:
H/U: Alpine 7894rb
Splits: focal 165k2 or k3
Front amp: Audison LRx 2.250
Sub: JL W3v2 - d4 12"/ PG Ti12D
Sub amp: Alpine mrd-m300/m500
with bargining i think i can fit everything into my budget, however my budget is quite flexible.
What do you guys think? All input/ideas on the system would be very appriciated.
ellifant
May 1 2003, 01:33 PM
that eq will be fine. just remember too spend a lot of time and effot (=$$) on the install. angles are everything. and don't bother playing with the eq until you get everything sounds its best without the eq.
have a good go at tuning it your self, and then right down all your settings, and take it to a experienced pro with an rta and get them to tune it, compare your figures to theirs... and whether or not it sounds better ;-) (i can give u the number of some really good tuners with rtas etc...)
you should get a really nice sound out of the equip youve chosen. providing its installed properly.
let us know if you want any other advice/help.
claf_43
May 1 2003, 01:37 PM
you listed some very nice equipment their
Ivestar
May 1 2003, 05:29 PM
is there any way i can get my hands on an rta other than buying (eg would i be able to hire one from a car audio store)?
claf_43
May 1 2003, 05:41 PM
as far as i know they do it for you
Ivestar
May 1 2003, 06:20 PM
yeah, i was goning to do it my-self but getting access to the rta is difficult. i guess it would proabably cost the same to get them to do it. Any idea how much?
Bodyjar
May 1 2003, 07:40 PM
Go to any of the big car audio specialists in brissy, they should have RTA's, I know Northfield and Gold Coast Car Sound and Custom Image do anyways. You can book time on them, and usually costs around $30 for 1/2 hour.
XHELL
May 1 2003, 09:16 PM
Originally posted by Ivestar:
I wen't out and bought a 2nd hand PG eq230 - 30band equaliser, proabaly abit prematurely, and maybe a bit over priced $500
This is a quality EQ but a good install should mean you won't need all of that equalisation. That isn't a bad price, its about 30-40% of the RRP....
Sonic Nirvana
May 2 2003, 07:24 PM
That system is full of good choices, can't go wrong and that EQ will be a good compliment to it.
I would suggest the PG subs as tho I haven't tried the W3v2's, the Ti12D's are really excellent in my system and look soooo pretty
magus
May 2 2003, 11:25 PM
Add things only if you realy need to because somtimes a eq can be more damaging if installed and tuned incorrect.You can have a system that stages fantastic and is full of warmth and muscle without it.
Not saying that they do nothing but you have to have a good sounding system first because it wont magically fix a poor set up.
T-Bro
May 3 2003, 12:04 AM
the TUNING of equalisers is of paramount importance, more important than your choice of equaliser. if you do not have patience, attention to detail and a fastiduous and personality - and also a few months to trial different 'curves' in the real world - then forget it. i have at least 3 friends (you tossers know who you are! ) who own decent EQ's, yet they sit around doing nothing, set to zero, because they dont want to tune them.
my advice is, dont worry so much about the science of it or which EQ to buy - but whether you personally have what it takes to tune one right or would be willing to learn and experiment. oh, and if you think you can get a shop to do it for you with simply a 'meter' while you go do the shopping - well, lets just say that it isn't the meter who will be driving around the system for the next 2 years listening to it
a well tuned equaliser is a BLESSING, i reply heavily on mine (will be adding another shortly) to get everythying working together. once you experience an equalised system, you wont want to go back. good luck!
Sonic Nirvana
May 3 2003, 10:36 AM
Given you already have the EQ, then my obswervations are these:
Install the system without the EQ first, as ideally as possible, with some provision in placement/cabling etc for it later on.
What I am saying here is that you don't want to somehow rely on the EQ to work around a problem. Use it as icing on the cake and you will get the best from everything and the system will work to its best as a whole.
mirage
May 3 2003, 01:21 PM
The way I see it is any system can benefit from a well setup EQ. You can get a good sounding system without one, but you can never correct for the speaker placement, response and cabin shape anywhere close to what an EQ could help you do. It comes down to whether this bothers you or not, or whether you can hear the difference or not.
He will have a matching line driver to go with the eq, which will both boost incoming signal and remove RCA leads for the front stage. The EQ can be run in defeat while setting up the system as best it can be, then it can be turned on and tuned to fix any inherent flaws.
Ivestar
May 4 2003, 02:01 AM
ok, so to get the best out of my system, first i need to make sure my install is perfect. This is no problem for me as i see this as a hobby and i enjoy spending the time getting things just right. secondly, only use equaliser to "fine tune" the system.
Q: is it more important to get a flat RTA reading for SQ comps or one that curves to my taste? Or shout i not bother with the RTA and just tune it by ear?
Your advice has been really fantastic on this topic guys, Thanks.
vanboy
May 3 2003, 07:50 PM
he he. i love that question. i have argued for hours with stoopid poofs (you know who u r) about this. when u go to a car show, they will judge u'r car according to what their ideals are. not yours. you will have many presets (not sure of what u'r eq is like-have never seen any other type than the model i got :/) to cater for different applications, eg one for metal, one for techno, one for spl, one for sq blah blah blah the list goes on. hope u have better luck than i did trying to find someone with an rta to set-up u'r system. no-one wanted to deal with me as i wasn't one of their customers. sad isn't it. i look forward to flogging the ring off them at the ingham mcar show next year. (almost local event)
good luck.
May 4 2003, 02:52 AM
definitely don't tune for a 'flat' RTA response curve. it will sound poor compared to 'tuning by ear' to suit your tastes.
the benefits of an RTA are only to demonstrate the large peaks and troughs of your system with your EQ set to 'flat'. by identifying the big peaks/troughs, you can then go about experimenting with evening them out.
use of a high quality test disc (eg: IASCA test discs) will help, as will 'trained' and experienced ears.
as mentioned, first set the system up with the EQ 'defeated/flat', then fine tune it with the EQ.
good luck
