GTS_t
May 3 2003, 01:31 AM
I've narrowed my choice of sub down to a Boston Pro 10" 4ohm or an IDQ 10 v2 2+2ohm.
As I'm yet to have the opportunity to audition either sub I've had to form an opinion based on their reputations.
I intend to run the sub, off a bridged 400WRMS amp, in a sealed box firing forward through the back seat armrest hole.
Can anyone here, preferably someone with experience of both subs, help me to decide which one and/or recommend appropriate box sizes?
LongWay
May 3 2003, 07:01 AM
I had the exact same setup except with an IDQ12- had the 12 in a 1.1ft3 sealed box with 400rms and had it facing forwards.Very nice indeed... Only thing better was when i added the second sub and more power I personaly would recomend the I
DQ sub
claf_43
May 3 2003, 10:16 AM
I just bought two Boston pro 10" subs with 600wrms on tap for each and these things go deep (.75 cubuic foot)
Sonic Nirvana
May 3 2003, 10:26 AM
Both excellent subs when used properly. You will be very happy with either.
Go on price/looks IMO......
GTS_t
May 4 2003, 12:54 AM
O.K. the pros and cons as I see them: Both subs have excellent S.Q. and work well in a small box,the IDQ may have slightly more output on my amp but the Boston should ultimately handle more power if I upgrade it. The Boston is the looker but costs a bit more and wouldn't even be seen in my install unless I spend more money putting a glass back in the box. The Boston is available now but I'll have to wait a few weeks for the IDQ.
From about ten really good subs, for one reason or another, I have managed to narrowed it down but I'm finding it difficult to separate these two.
T-Bro
May 8 2003, 02:36 AM
as a related issue, boston recommend pretty small enclosure sizes for their subs (1 cube for 12's). my question is, do you HAVE to use such a small enclosure, or is it permissable to use a larger one?
claf_43
May 7 2003, 03:19 PM
the bostons dont go very loud but their SQ is great
GTS_t
May 7 2003, 04:20 PM
On another thread RetroPimp said his gf has a pro 10" in a 1.8cf box and it sounds great. On the other hand the guys I've talked to that sell Boston seem to recommend .5cf like Boston do. Boston recommend amps from 50-1100WRMS so I think they would be good in a larger box so long as you don't give them too much power. I was thinking .75-1cf for 400-500WRMS but I'm just guessing. What do you think claf? What do you mean they don't go very loud? Compared to what?
Sonic Nirvana
May 7 2003, 04:48 PM
You can certainly use larger than recommended enclosures for almost any driver, in a sealed box so long as you don't exceed the Vas spec (bad).
More box basically = more bass low down + bit more efficiency at the expensive of some power handling.
ie more output from larger box requires more excursion so it excursion-limits earlier.
The total bass output is basically the same, but you move the output profile downwards where more excursion is required.
And that's why recommended boxes are smaller.
GTS_t
May 7 2003, 08:06 PM
Hey Critter, how are the P.G. Tis going? Do you think I made a mistake crossing the 10" SVC off my list? Would they go louder than the Bostons,IDQ?
Bodyjar
May 7 2003, 08:16 PM
There is a civic that has done 150dB with 2 pro's in a small sealed enclosure... so they CAN go loud...
But I would go the IDQ's because of the price factor...
claf_43
May 8 2003, 11:21 AM
i feel their lacking somewhat compared to some other subs, dont get me wrong though their still great. its just that i have had 4 type R 12" subs and a kicker L7 15" solobaric so my definition of loud might be a little different.
But im not after that anymore and just want SQ, my gains are set on zero and i love it
Sonic Nirvana
May 8 2003, 11:44 AM
If you want SQ loud in an SQ instal, the PG Ti's are Da Biz I reckon, given enough power to reach Xmax.
The PG's have 18mm Xmax where the IDQ's are like 12mm and the Bostons 10mm from memory.
I say "given enough power" coz my JL is 600 watts for the pair and I have a hard time getting much excursion out of them even when punching very hard and loud without any sign of clipping.
