Full Version: My setup
foxey
Hey guys
I am currently installing the following gear into my car:
Alpine CDA-7998r
Alpine SPX-F17T 3 ways
2 Alpine SWR-1241D DVC Type R's
Soundstream Reference 644s 75*4 rms
Soundstream Refernece Class A 10.0 1000*1 rms
Firstly, sorry for the length of this post, but i have a few q's . Both the amps are class A, so they should be perfect for my system as i'm planning on designing it purely for SQ. What i want to know is should i bridge two channels per side of the 644s to the splits, to get around 300wrms per side, or should i run them in a dual amp config, so 75w to the midbass and 75w to the midrange and tweeter? Any help is appreciated. Also what is a good value sound deadener. I know that all it does is add mass to the panels to stop them vibrating, and that bunnings sell a product VERY similar to Dynamat. Do you think it would do the same job?
Brad
PartyJase
try doing both configurations with the front amp and then stick with whichever one sounds better.
from looks of things u have a good start to a great sounding car.
and ur post isn't really that long at all.
honour77
Originally posted by foxey:
Hey guys
Alpine CDA-7998r
Brad
its a little hard to say whether you should bridge for more power, or instead run each driver off a channel and dump the passive crossovers. I had the same dilemma when i got my subamp and freed up the 4 channels on my orion. So i gave them both a go. In my case, it was the bridge for more power rather than the active setup which worked for me. But i stress, you have to try it for youself since our drivers/amp/environment couldnt be more different.
Remember to watch the gains and crossovers points very very carefully when you run active, esp with regards to your tweets, or you'll blow them. I suggest a good test tone cd. Start with low gains/high crossover point for the tweeter and slowly work your way up the gains and down the highpass point for the tweets until you're happiest
But offhand, from my little experience, i would suggest you run active provided running active, you are still feeding your front speakers at least RMS power + about 20% overhead. If running active means running below RMS power, chances are bridging will work out better i think. Like in my case. Power before crossover. May the force be with you
Oh yeah, dont aim too low for the tweeter highpass just because your tweeter can handle it, cos the overall sound will still suffer. Driving 62.5W to my Morel MT2 tweeter, it could easily handle 1900Hz highpass at 12db/octave without distortion on test tone frequencies below the crossover point at max listening volume BUT once i powered up the midbass drivers, the sound was awful. it was like the whole front stage was being played by the tweeter, which made the overall effect hollow and lifeless although distortion free(after all , its only a 1 inch tweeter). Provided your tweeters are up to the task, i dont recommend crossing over below 2500Hz. My passives crossovers highpass at 3000Hz on a 6db/octave slope and i cant find fault with it really. I liked the sound best at this point. And with 250W x 2 to each channel bridged, it sounded fantastic.
BTW the slightly increased THD from bridging is not a factor in this. There will never be an audible difference. Just in case you're wondering. The increase is usually from something like 0.08 to 0.2%, something like that(unless you got a crappy amp, and youre amps arent crappy!). Only the best ears out there can hear about 3% distortion or more. I wouldnt worry about it
[ May 07, 2003, 16:55: Message edited by: honour77 ]
dasherhalo
Cr@p. I just typed a huge reply and then IE shut down. Damn Microshaft!!
Hey bloke: niiiiice amps!! I've had a huge list of SS amps, and I love 'em, even if the Class A is more marketing than fact....
You don't need 300 watts to get a great front stage. I'm using the SS Renoir, which is only 50x2wrms, running a set of quality split, and volume is *no* problem.
Do you have bi-ampable crossovers?? If so, this would be the first set-up I'd try. If not, I'd recommend the bridged setup for ease of installation.
If the crossovers aren't capable of being bi-amped, you'll have to make sure you've got the crossovers in the amps/headunit to actively cross the frequencies, but that would be option #3 in my opinion.
Or you could buy my SS Balanced crossover and BLT and show off more chrome in your boot!!
By the way... did I say Niiiiiiiiiice amps!!!!!
dasherhalo
[quote]Originally posted by honour77:
[/quote]BTW the slightly increased THD from bridging is not a factor in this. There will never be an audible difference. Just in case you're wondering. The increase is usually from something like 0.08 to 0.2%, something like that(unless you got a crappy amp, and youre amps arent crappy!). Only the best ears out there can hear about 3% distortion or more. I wouldnt worry about it[/QUOTE]
Not disagreeing with this at all, but from a different point of view, I've always been a fan of running full range speakers off amps in their native environment, ie, 4 ohm stereo. Leave the bridging for sub duties where it really doesn't matter about a little bit of distortion.
That amp isn't a feather weight to begin with. Give it a chance without bridging it first up: I don't think you'll be dissappointed.
yeah, the SPX xovers can be configured for bi-amping/wiring. makes for a semi-active setup: 4 channels to run 6 drivers via the passive xover (excl inbuilt active HP filter set around 80Hz).
these splits are rated to 75WRMS, so doubt you'd reap a benefit from running the amp bridged.
