Full Version: speaker cable - much difference in sound?
daniel price
just wondering how much difference speaker cable makes in the overall sound for hogh end systems. basically comparing standard (decent gauge) cable at roughly $3-4 per metre against higher quality cables available.
from experience has anyone noticed much of an increase in sound (quality or otherwise) when they have upgraded their cables???
thanks for any help, Dan.
None, nothing, zero, naught, nil, zilch, nada, zip, zippo, didly squat.
STIK79
I wen't from crappy wires that came with the DLS ultimate pros (about 22g!) to decent home audio speaker wire I had laying around and there was NO difference - this thing is, at speaker level you're talking high voltage / low current so the speaker wires don't need to be of huge gauge (well ok small gauage large diameter )
and don't believe any marketing talk of silver mixed with copper being superior allowing for high frequencies to be transmitted better, it's merely that - marketing talk.... krase had and excellent link about cables
Jetstream
Speaker wire is speaker wire, depends if you want the warm fuzzy feeling inside.
So long as the guage of the wire doesnt restrict the flow, there wont be any difference at all.
Subatomic
hmm i used the amp remote wire 4 speaker wire cause i was out of speaker wire does it really matter??
http://sound.westhost.com/cables.htm
is that the one I have a few ones
nemesis
its been bought up a number of times whether speaker cable diameter will make a difference, whether brands are better than others etc etc. end result was nah not really, usually just gives you a nice fuzzy feeling as Jetstream put it
though that being said i just installed the speaker cable into my car for my front stage, decided i wanted to keep with buying good quality gear and wanted that damn fuzzy feeling while i was at it i opted for Stinger 12ga cable, completely overkill, overpriced and not gonna do diddly squat as nearly anyone will tell you...but i've always agreed with the perfect ideal of removing as many 'weak links' as permissable so spending an extra $10-15 on speaker cable to run something worth 100 times that much in the future doesn't really phase me...up to you really is what im saying, but its just my opinion
Winno
Maybe, but you have to ask if the rest of the details are also taken care of. Even then, you may notice a difference and then again, you may not.
Best thing to do is to try it yourself and rely on your ears instead of someone elses.
Macca
I just bought a 30m roll of speaker wire from jaycar for $20 24 guage, probebley the best value out there, but i havnt looked too hard hehe
vti-2
I think there is a chart or something that shows what gauge cable to use with certain power ratings etc. I can't remember where i saw it but if you follow that chart and use decent grade cable (OFC or whatever) you are bound to have close to perfect sound reproduction. Don't forget, you need to make sure all the other links are of the same quality, distro blocks, connections, earths etc etc are all good quality in order to achieve 'sonic perfection'.
Otherwise, regardless of how much you spend on cable (or any other part of the system), the sound will sound crap anyway.
Blitz
roughly what gauge would you guys say for 80 watts fronts ?
salt3d
quote:
Originally posted by SUbaTomIC:
[b]hmm i used the amp remote wire 4 speaker wire cause i was out of speaker wire
salt
claf_43
Wirings is just for showing off, 22g wire will power speakers just as good as 12g
16awg is as much as you'd need.
Dr DJ Choss
here's a good article for a car stereo mag to do- a test on all the fancy and non-fancy bits and pieces you can get from a couple of bucks to thousands...
imagine the frantic lawsuites and so-on from Stinger and Streetwires (to name two of many) when all is revealed...
Subatomic
salt
ROFL i do that 2!!! at this time i was out of remote wire but had heaps of speaker wire.. hmm completely forgot about that
Gatecrasher Republic
I auditioned a lot of home audio lately and speaker cables make a huge difference, i don't know about car audio but I don't understand why it would be any different
Was this doing double blind testing, or not?
You may be suprised..
golf_bht
Well If you have enough xperience with a decent home system then you should be able to differentiate a sh;t cable from the good quality one straight away. you can always quote me on that. I had been listening to hi-end home system since I was born because my dad was a hardcore audiophile. my 23 years experience can proove me on that
audible
funny this topic. just last week i was mucking around with speaker cable for my home theatre set up, and did a back to back listening test on speaker cables.
i wandered into jaycar for some bits & pieces, and ended up ordering the 2.5 metre pre made prenium speaker leads worth 89.95. i got them because of the huge insulation on them, and quality terminaltions. i figured with all the cable i have behind my av cabinet, the insul would help.
my old leads where off the reel 14 guage twin clear insul, i think from jaycar originally as well. i had fitted the ends of these with neotech banana's, but i soldered these to the leads instead of using the grub screws.
gear.
b & w dm602 series 3 front speakers.
denon av-1802 theatre amp.
(all other speakers disabled for test.)
software.
crouching tiger track 28. the sorrow ending.
tears for fears - women in chains.
star wars sound track from cd. episode 4. music only.
new jaycar 90 buck leads.
i found it very hard to tell the difference with these leads. but, there was one. the new jaycars bought a slightly crisper sound to the highs, and fuller attack and second/third harmonics. on the drums of track 28 crouching tiger, i could hear the strings of the chello clearer which was the most notable difference compared to my old leads.
as a extreme test, i grabbed some real crap cable i had laying in my store room. 16 guage white insul crap and i used the banana terminals screw downs to terminate.
this really shot my speakers down. highs became coarse and irritating and introduced slight sibulance and destroyed the harmonics. totally.
track 28 chello sounded like a tom cat on heat.
i thought i would loose my warranty if i continued using the crap cable any longer!
conclusion. i probably wasted 90 bucks. mainly because my old cables where not so bad i guess after all.
but the point of the exercise shows that you need good quality speaker leads. ample guage, good insulation and above all, proper termination.
also that warm fuzzy feeling played a part. using cheep cable with $2,000 + worth of amp/speakers just doesnt feel right.
[ May 22, 2003, 16:33: Message edited by: audible ]
In your 23 years of experience, have you ever done a double blind listening test with different cables?
battousai
i think the home audio market is vastly different because of the nature the equipment and the components used to poduce the equipment.
Much of them is higher grade and will be more sensitive to carp accessories like crap speaker wire. thats why home audio mags do cable testing (blindfolded or no blindfolded)to assess the nature of different wires from different brands.
not all copper is the same grade and not all silver is the same grade. There will always be a difference depending on the ability of your equipment to register that difference.
Most car audio equipment cannot match the quality of home audio and it never will. Therefore maybe in car audio there is no difference but hey, not everybody's hearing ability is the same right.
I use stinger wire. even though its expensive its got two layers rubber protection which i need cause the insides of my car there are a lot of sharp rivets and screws which scratch the outer coating of my wire as i install the speakers. I just don't want bare copper wire popping out thats all. dunno bout the sound though but shouldn't make much difference cuz my dyns in the car ain't gonna match the sensitivity of a BnW.
