Full Version: Active vs. Passive Power levels?
fr0st
Just a general question...
In terms of spl (loudness) do actives require the same amount of power per speaker to reach the same SPL as a passive with one amp at the same power?
e.g a 3x50rms powering a set of 3 ways vs. 50rms through a passive crossover to the same three speakers
Macca
Generally in a passive crossover, each speaker is going to be getting a small amount of the supplied power, in an active set up, each component eill get a seperate power channel,
so with that in mind you get more power per speaker in an active set up than an a pasive set up.
one other thing to mention is each speaker in an active set up generally need one channel on an amp..
eg 2 way passive means 4 channels
a 3 way active set up would be 6 channels
Damon
There is certainly some associated power loss by using a passive filtering system of resistors, capacitor and coils. While many people claim that it is as much as 3dB of lost power (half!), the fact is that passive components vary in their type, arrangement, and number of power-robbing components used in theior construction.
While this is a nifty question in theory, in practice it is almost always a moot point, as you are actually comparing 50WRMS with 150WRMS of total power that is needed to be purchased. In most cases, it makes sense to retina the passive crossver and simply buy a bigger 2-channel amplifier.
fr0st
Insertion loss in a passive crossover is genrally about 1.2db (higher when you increase the roll off).
If you don't take into account the crossover loss each speaker would recieve 50wrms at the frequency specified by the rolloff points of the crossover, so to get the same in an active system 3x 50wrms channels are needed to drive the 3 individule speakers to get the same result as a passive?
Thats how I figured it...
It also depends on the frequency range - at, say 100hz I'd strongly recommend an active filter..
Also, when you start talking about very high power applications ie 300w+ per speaker, then active filters will also be more suitable..
Tha Hombre
Question: If for example i have a four channel amp (eg. 4 x 60wrms), should i bridge them to get approx. 150wrms per channel running passive, or run the 2-way active? Which would produce more power? What is more effective and why?
I would bridge the amp because it will result in more headroom (power) before clipping.
Provo
Buuuuuuuuuttttt....then your signal isn't as clear and clean with some amps...and the way the music is reproduced is changed a little.... righhhhhttt?
mick007
bbbuuutttt.... Passive x-over are designed by the company who makes the speaker. Why not use it. 4 x 60wR.M.S. will only be good if the signal could be bandpassed not just lp/hp.
I don't see the need when the people who make the speakers sit there for weeks goingm hmmmmm... how do we make this product sound as good as possible that we would then go hmmmmm.. I can do better then the guy who biult them???
And how many speakers can take 150w R.M.S. anyway?? Not many.
Mick
roughcactus
very good point however...using individual channels to each set of drivers does give you a little more flexibility to tune your system...but is it worth all the extra $$$ for the little bit more flexibility...
Probably Not...
Sure the signal won't be as clean, but can you hear the difference? Probably not.
Macca
Are you building an SQ car or have knowlage on active crossovers?
if not i wouldnt really reccomend them, there very hard to get right and you need external crossover box's in most case's so it wouuld be cheeper running passive bridged
Rockin
I am going to be putting an active front stage in my next car, I know it's going to be harder to tune but I see car audio SQ as a hobby and the more things to fiddle with the better.
I can also add a 9.5inch Dynaudio for a 3-way front stage using my active crossover when I go insane.
Mr Neil
just remember with an active crossover the signal is processed before it is amplified, and therefore has no resistance to the speaker
Actually, this brings up a point.. When you are building a custom front stage, it is much easier to use active filters rather than passive filters. - Since speakers are a reactive load, if you assume the impedance is at is nominal amount, when designing the crossover, it will end up making the speakers sound horrible..
audible
the passive crossover insertion loss rule of thumb was 0.6 decibels per step, or per 6db per octave, so 1.2 db for 12 db/oct, 1.8 db for 18 db/oct etc.
remember what damon said, that this is just a rule of thumb, approx value only as the end result really depends in components and design of the passive cross over.
the arguement of the passive cross over was designed for the speaker so its the best thing to use doesnt work.
the truth is that the manufacturer wants to seel the product complete. so that you, the buyer can un box them, hook up to a single amp and start listening. its also a warranty issue as well. if you used the supplied x-over, then the speakers where "protected" from the wrong freqs for the speakers.
if the manufacturer supplied the speakers "as is", with out any x-over, they would open them selves to potential waranty issues from dumb bunnies who didnt read the instructions, and wired them straight up to an amp.
supplied x-overs with speakers does not mean that they are the best thing to use with them.
better quality speakers have cross overs with them that are good, being designed to match the speakers characteristics but the fact remains that they are still a compromise no matter how good they are because a speakers characteristics changes over time and while they are working.
speakers impedance is only nominal. they may be 4 ohms while sitting in you hand, but while they are playing, can go anywhere from 1 - 40 ohms.
actives ignore the speakers characteristics totally. the right signal is going to the speaker in the first place so it does not need to be modified, in theory. as long as the active is set up properly.
disadvantages with active? where do i start? expensive, complicated, bulky, rca cables everywhere, in efficiency.
lets say you have three speakers per side up front. each had a 50 watt amp, so you got 3 50 watt stereo amps. in a sense, you have 50 watts total power. because the tweeter amp is only working at high freqs and the potential 50 watts of power below 3-5 kay is sitting there wasted.
what you are doing is splitting the load of one amp over 3 amps.
so, after all that bull crud, which one sounds better? now that is hard to answer. both have flaws, compromises. it really depends which compromise is better than the other. personally, there is a lot that can go wrong with 3 sets of amps, rca's and a extra powered item (the x over) in the signal path that can all introduce noise.
set a active up right, and i think it owns, but there is so much that can go wrong with active.
not to mention the complexity and expense.
get your hands on a decent set of passives and take the easy known quantity path. i reckon its worth while. passive is just not worth the hassles for what is a arguable benefit.
mick007
Audiable:
How can the x-overs in a set of slpits not be any good? Why do you think that for some reason you know that speakers change over time but the people who build them don't??
Why would they not set speakers up correctly??
Now if the speakers changed over time, wouln't you have to adjust your active setup as well??
So your saying that when your bandpassing the active fronts that you can put it within a 3-5hz gap on all six channels?
Now wouldn't the amps x-overs have to be as good OR better then the x-overs supplied or their would be no gain?
I am definatly NOT SAYING that I am right, this is my understanding and pls feel fre to correct me.
Mick
Dr DJ Choss
I have a fully active system, every speaker has it's own channel on an amplifier, the only exception being my subs as they're mono to the Soundstream amp.
I band pass all speakers except for the four tweeters- two in front and two up back.
Previously I have used a number of combinations of passive and active, I liked the Hart two way passives as well as the two sets of Clarion three way passive crossovers I tried. The system lacked real power in SQ terms, not volume terms.
I have not completed my rear stage, but the front is in and it's as per my system explanation below.
I now believe that if you are serious about SQ at a decent volume level, active is the way.
People who know me, know that what I've changed and how often I change it is stupid and expensive, but having done so, take it from me...
ACTIVE SOUNDS BETTER !!!
[ July 03, 2003, 09:18: Message edited by: R ]
pwoida
It is difficult to manufacture high Q(low loss)inductors which gives rise to the insertion loss of passive filters. Components such as inductors and capacitors also introduce phase variations.
By using active filters you don't need to use inductors, only capacitors and resistors. This means high power handling, low loss filters can easily be built. Infact these filters can have an insertion gain.
Also lot of speakers are limited in power handling because of the inductors in their crossovers.
While a lot more effort I definately think active filters are superior.
Whats even better is digital crossovers. These allow infinite cutoff slopes and no phase distortion but are even more expensive.
