Full Version: Best Speakers without an amp!
BlackRain
Guys,
I'm looking for some advice on a pair of rear speakers for my car. The rest of the system consists of 6.5inch front splits (running off a 2ch alpine amp), and a 12inch JLW6v2 in the boot (with a mono alpine amp).
I dont want to put a third amplifier in my car, however, i do want some good sounding, QUALITY speakers for my rear fill that will run purely off my head unit (a Clarion DXZ-835MP putting out 53W max/18W RMS x 4).
I do realise that running off the deck will be very limiting, but I'm just looking for the best within these constraints. Also, if it was a 6" speaker that would be preferable because it would fit in the factory mounting holes on the rear parcel shelf.
Thanks in advance guys. Cheers
[ August 25, 2003, 22:29: Message edited by: BlackRain ]
eMitch
Hey there! NICE sub
What is your budget. Considering the equipment you are using, I would be suggesting some of the Hertz 6.5" coaxials that are avialable from the online store. They produce great SQ and should suit your need adequately. They are about $150 by memory!
Cheers...Mitch
BlackRain
Budget isn't really an issue for me. Plus I guess the fact that they need to run off a head unit alone will in itself set me a budget, because the higher end speakers all need amps to run properly.
But thank you for the suggestion Mitch, I will have a look into the Hertz speakers. Any others??
poeee
Hertz make very efficiant speakers
mick007
Go JL 6inch co-ax. JB Hi-Fi have them on sale in melb reduced from 220 down to 170 and I picked a pair up with a mate for 135. Better then most. Probably best speaker for that price.
Mick
Psycronic
Jaycar 6" coaxials with the titanium tweeters are very good and only $160 a pair
BlackRain
Thanks for the advice guys!! One more issue I gotta throw in.
My car's standard speakers are 6inch Clarions (I'm assuming entry level stuff). Will there be a noticeable difference between the speakers being suggested (Hertz, Jaycar, JL Evolution TR series) and my current ones if they are only running 18WRMS?
I guess the real question I should have asked at the beginning fo the thread is: would it be worth it to upgrade from the stock Clarions to any of the above mentioned woofers? [edit - sorry, i mean speakers].
[ August 26, 2003, 19:35: Message edited by: BlackRain ]
micha3l
if its only for rear fill i dont think you should bother personally.
i disconnected my rear speakers yesterday and i think it sounds better without em. But if u amped the fronts and had the stock rears running off the head unit i think it would sound fine
eMitch
Well in that case, if you already have stockies in the rear, I wouldn't bother upgrading personally!
Cheers...Mitch
