Full Version: Angelo Kanci Information
Marc
Hey guys, does anyone know if there a webpage with any information on his SQ setup ?
Or Cyberpunky, can you give a brief decroption of the components used in it ?
Manager - Car Audio Australia
Advertising / Marketing / HTML
Sound Quality System:
- Vehicle: 2000 Mitsubishi Lancer VRX - 4 Door
- Head Unit: Clarion 9675z w/ 6 Stack Optic Fibre Link
- Front Stage: Total Recoil 8", Dynaudio MD140/2 3.5", Xtant XiS2.6 1"
- Rear Fill: Come on, be serious
- Crossovers: Custom 2 way Passive by Audioart & Technologies
- Subwoofers: Hertz Air Mille 3800 15" Infinite Baffle
- Amplifiers: Butler Tube Driver Blue 2150, Butler Tube Driver Blue 4150
- Power Delivery: Generic USA Made 1F Capacitor, Odyssey 600 Dry Cell Battery
- Lighting Effects: Neostream Neons, Flexiglow Cable
Angelos not a nethead so no web page.
He used an Alpine 7939 deck(as a transport) feeding via digital out to an apogee DAC, He also used crystal line noise gates for perfect scilence between tracks. They actually disconnected the speakers when tracks fell silent.
He had numerous Soundstream amps(4 I think), all rubicon series. He used focal (Home speakers) 9s with his veritas horns(radian driver) for midbass. He used USD 1/3 octave mono eqs(2of them) and a USD 3 way crossover
He used 2 15 inch CV strokers in an AP membrane set up for sub bass. An audio control MVC to control volume as digital disables volume control when using outboard DAC. All wires were Streetwires even down to the remote turn on wire.
I could go on but that gives you a good idea. The system was worth around $100,000 not including the install as he did that him self.
He is now about to embark on a 5.1 system for the car with some very trickey features but Im sworn to secrecy on what they might be. It will be something possibly even better then his old stereo set up
"Electricity is for more than powering windmills" Ali G
All your base are belong to us! ;)
Like to know more ?
my site
bBoy dARktEk
Cyberpunky,
how did u think the 2 15's held up in the SQ system?? did they hold up with real fast beats well?? do u think they would blend in nicely if say i was using 8" midbass??
thnx mate.
>>>'75 LH tORANA<<<
>>UNdER CONStRUCtiON<<
NAK CD-45Z
FUSION FR2-500X
MTX, AEPRO CABLES
of course they sounded good!
he (as punky said) had them in an AP set up, they were probably also crossed ofer low, and so the 9s up front did most of the work
I'd say most beats are mainly midbass anyway (besides techno 909/808 style kick drums)
I've found that EQing in the 120-180hz range tends to make a kick drum much punchier
HEAT KILLS! Don't let Mr Heat near your subs and amps!
AP membranes are first order design and so have the best transient response you can get. If you use 15s in higher order boxes, like ported or bandpass, you will loose transient response, and even sealed boxes are second order so wont match AP for transient response.
AP is only suitable for low Q drivers and his Strokers are .21 Q making them ideal for AP membranes.
Like to know more ?
my site
bBoy dARktEk
well yeah of course it would have sounded good.
my question was related to how they would sound with 8" midbass. i think i just worded my question wrong.
>>>'75 LH tORANA<<<
NAK CD-45Z
FUSION FR2-500X
MTX, AEPRO CABLES
I have always designed systems by an old rule that states your sub should be no more then 2 sizes bigger than the biggest speaker in full range set up IE if using 8s up front then 12 is 2 sizes bigger, if using 6s up front then 10s are 2 sizes bigger.
This is why I dont think ppl should use 2s or 15s with 6s upfront as you dont get a smooth transition thru midbass section. I wouldnt suggest using 15s at all unless you ran 10 midbass units up front, but many ppl use 15s with 6s and are happy, but as Im into pure SQ then it doesnt work well for me.
If you play for example, a double bass that slides down the bass notes, you will get an even transition with sticking to the 2 size rule, but you wont if you use a sub 3 or more sizes bigger than fronts.
This is because the centre of the subs out put is too far away from where the fronts start to drop off leaving a hole. When you get it right the double bass just gets lower and you cant tell when fronts stop producing bass and sub starts.
Anyway Id suggest 12s with 8s and thats what I use in my system and the transition is perfect. Angelos car was also perfect but the focals are almost 10s and being a very hi quality speaker, they blended great with the 15s, which by being in a AP set up, had ruler flat response. He might not have got it to work as well if the 15s where in a sealed or ported set up.
Like to know more ?
my site
Slain
quote:
hmm i wish id known that before i started on my system
1968 Ford Cortina Mark 2 220 (Rare 2 door model)
System is more aimed towards SQ but aiming for 135db.
Head Unit: Pioneer DEH-1350B CD Tuner
Front Stage: Pioneer TS-C1625 6 inch "Power Blade" Splits
Front Stage Amp:*Probarbly Jaycar 2x84WRMS
Rear Stage: Who needs it?
Subwoofers: 2 8 ohm 12 inch Oz Audio 300L (Special SQ build run)(in transit)
Sub Amps: Weconic VX-4475 4x75WRMS (bridged to run 2x200WRMS)
Lighting: *Definatly Neostream Neons.
Wiring: *Stinger Hyper Series.
For more info on my car go to My Website .
I have that info at my site, but obviously cant do much more than that http://www.hotkey.net.au/~cyberpunky/audio...s/my_rules.html
Its the first thing I mention in the subwoofer section
Like to know more ?
my site
Slain
hmm yeh i read your site a bit but didnt remember that
Doesnt matter as after i get a 4 channel amp im gonna get a set of eights
Jimbo
I have a a write up feature on his car in INCAR mag..
comprehensive article... pity i dont have a scanner
but Cyber summed it up
* Clarion 9255
* a/d/s 336.IS
* PPI Flat Piston Pro12
* PhoenixGold ZX450/500
Dr DJ Choss
could this car be Australia's best???
kittan
Punky,
Can u tell me more about AP? and interested to learn.
U mentioned subs should be 2 sizes up. I am running 12" with 7" midbasses. 2 1/2???
Regards,
Kit
Macca
Well, i have noticed i have a nice blend with my midd bass / sub bass, with a particular Jazz song i have, a nive bass solo, which slides right down the octive ending in deep sub bass, slides well from the Oz 6.5"s to the Alpine 10" sub, the other great thing about this is you can tell when the bass sways from front to rear :S in my case not enought bass up front
dasherhalo
Woohoo!! CP's back and posting some REAL content!
Hang on - *date check* December 2001!!!
I know I'm a fence-sitter that hangs back and waits for other to put excitement in my life, but I was getting slight wood there for a minute....
[white lie]
I'd say it was regarded as Australia's best when it was competing. Nothing could touch it. It was right up there with some of the best in the world
tuneman
nothing like a good set of HLCD's!
aperodic membrane enclosues have the fastest kick drum response of any enclosure, would have sounded awsume with the strokers just don't expect to get any spl out of them as they are purely a SQ setup.
i guess with enough tweeking,time and money you can achieve great sq with a mixture any speaker sizes
Marc
Most certainly the best SQ car Australia has ever seen, and probably will for still some time.
Hey, talk about dragging up old threads
Look at the original post date
whoa! a blast from the past.
yes I'm back but as ppl now post what I would say, I post a lot less often, which is great
Kit here is some info on AP mats
http://www.maximacar.com/aperiodic.htm
http://www.elitecaraudio.com/install_clini...odic_Enclosure/
Peace
[ September 13, 2003, 01:32: Message edited by: Cyberpunky ]
KraSE
one day time and money will allow my to build my SQ warrior. I have the gear lined up minus amps/hu/eqs etc.
Veritas Horns waiting driver upgrade
4 8" veratis sccu bass mid bass drivers
1 18" inhuman built with sq in mind
all to go in "big gal"
http://www.wn.com.au/krase/biggal/imagepag...ages/image9.htm
One day one day
Hutch
Just to reply to tunemans comment in relation to AP set ups not having any SPL ability. This is a commonly held belief. Speakerworks in Orange CA, the makers of USD products built their Buick Grand National with two USD 15's is an AP box with each running of and Alpine 3545, about 400-500 rms I think, and it used to post SPL scores around 148-150 regularly, 15 years ago. So, while AP is the ultimate SQ sub alignment it can also get loud, given the right woofers and amps.
sosofast
One day one day
dude did i see you yesterday driving my autobarn on princess hwy??
[white lie]
i'd doubt that, he lives in Perth...
Also, didnt Angelo's car post reasonably high SPL scores for a SQ car??
Angelo never entered a SPL contest but did measure it once for fits and giggles. He only did 150 which is OK for an SQ car with AP mats that cant go loud (Im told)
Rattlehead
How does this car rate against other SQ cars around the world?
He got the cover of Car Audio and electronics mag in the USA which gives an indicator of how highly this car was regarded. It scored the highest scores ever recorded in IASCA in this country.
It was built thru Angelo consulting constantly with Richard Clark and hence his choice of components like the horn drivers(radian), and Apogee DAC(same as mine ). This is the same DAC RC used in the buick.
Anyway we will never know how it would compare side by side with cars from the US but it sure wouldnt be disgraced by any means, and may have even beaten some of the best cars there. Who knows.
cyberpunky
Dr DJ Choss
Í for one am eagerly awaiting his re-built to 5.1 style.
Maybe Marc could do something along an all time Top Ten SQ feature in the car audio mag? Only problem is disputes though. I nominate Angelo.
Rich
[ September 21, 2003, 22:11: Message edited by: R ]
angelo kanci
Hi its Angelo ! Finally got a computer spent toooooooooooo much money on car audio. I'm happy to answer any questions i can. Please remember a lot of my car was secret because even though i was in amature class i wanted to beat the pros. Since im not competing i'll share any info. The car is still crusing but only done 5,000 kms since 2001. I'm considering selling it and finding it a proper home.
TEGBOY
^^^ Angelo finally made it!
raziel
angelo
does the car still have the same setup ? or did cyberpunky's rumoured 5.1 system ever eventuate ?
someone needs to scan and post the incar article (or something similar) so I can get to read it (never did see that one) - thanks
I recall seeing the car - but can't remember if it was at an iasca event in sydney or melbourne (brain is very fuzzy going back that far) I think I've been to way too many car audio shows over the years smile.gif
Marc
Welcome Angelo... you are well overdue around here. You'll see I started this thread chasing information on your system over four years ago, and only now am I getting anywhere near! LOL
I'm running a 7939 (may have been owned by you at some stage I am led to believe), and I also had the same Veritas / Radian HLCD's as you but sold them at a later date. I now have the Veritas HLCD's with standard compression drivers and am quite happy with them. Incidentally I bought a E36 also simply for the fact that I knew they would fit in thanks to you smile.gif
Having some problems at the moment getting the PPI DAC to Sync with the Digital output, but then feeding into a Audiocontrol MVC. Using Diamond Audio D7 amplifiers and a Diamond Audio 12" TDX subwoofer. Its slowly getting there but biggest issues at the moment as I said are the DAC firing up, and EQ. I am using a modified Behringher Stereo 15 band but having noise issues with it so it's bypassed for the time being.
angelo kanci
Hi everyone. Still learning. 5.1 tried it but l believe my sounds better as original. Upgrades putting ALPINE fold out screen and seperate dvd player where my 7939 and climate control was.relocatind the climate control to the center consol. Added orion deq30 but ran 130 YES 130 wires to tha ashtray for control 4 zones . SPL, SQ, OLD MUSIC(NO BASE), TOORAK CRUZING.
How much voltage output on the PPI DAC ? Apogee has **** loads remember back in1996 it was $8000 now there only $1600. The EQ sounds as you have a ground loop. R the EQ and amps XLR ins and outs? If not there is your problem. Thats WHY i have soundstreams. Next ALWAYS test all equipment out of the car before you even consider using it in your car. REMEMBER i learnt a lot from the pros in proffesional sound reenforcement . They applied their knowledge to a very missinformed car audio crowd , and made a lot of money. There is the plan FIRST then use the knowledge and YOU WILL WIN. I am not concerned by brands but what and how they bo it. I will scan my mags sooon.
Remember my horns have a 1.5 inch throat and HUGE radians or are they? They have to be crossed very low mine 300 hertz or else you will comprimise center vocal.but if the compression drivers are small you will **** them. Mid base has to be the biggest 9 inch MY SPL on horns and midbase 128 db. They WILL deafen you its not like 128 of bass. Mids crossed as low as possible 80 hertz. The box for the midbass is the sill panel which has been sealed to give 1.5 cubic feet. NOONE knew that !
Ask and i'll help. :hehe:
BUY THE WAY how the hell do you add all the details of your system?
Veritas horns 1.5 inch
Focal midbass 9 inch
Strokers 15 inch
ap mats
Alpine 1005 cva ( import american BLACK )
Alpine dvd ( import american BLACK )
Noise gate
Orion DEQ
USD (rane EQ )
USD (rane xover )
Brax caps
audio control MVC
Apogee DAC
4 SOUNDSTREAM AMPS
Custom fuse blocks
Streetwires power cables and speaker wires.
AND SORRY BUT 0.10 cents/meter interconnect wire
blanketman
Great to see you on here Angelo
i dont know if you remember me (bruce mate the fibreglasser)
but hope to see you around some time
(i got the USD Pro 15)
KAL SPL
Any chance you can post some pics of the car as it is today ?
Hey Angelo, great to see you here...it will save me answering for you...well what I could anyway lol bout time you got a computer bud biggrin.gif
Punky
fatboyj
hi angelo. how do you think the strokers rate compared to today's subwoofers (eg. re xxx, dd0, brahma)?
that just made my day (and it's only 8:30am biggrin.gif )
welcome abord Angelo!!
i like what you said about using the Soundstream amp's that you had to use them cause of the output voltage on the Apogee. most people on here buy amp's based on how much magic poweder is inside it, yet you achived what you did buy getting and amp that did what you needed it to do.. not cause of how rare it is or any other reason..
angelo kanci
QUOTE (fatboyj)
Subs have beeeeeeeeeeeeen around for a long time . If you were to use them the way i do (AP matt) and low Q value and high power ability they will sound all the same. My subs play flatttttttttttttt 25 to 80 hz , whether the windows are open or not.
QUOTE (Bobby_Digital)
Hi. Thanks mate. So true. Ive been always amazed why people select products. Education is a powerfull thing and i say it as it is. Unfortunately i upset a lot of sale reps. My equipment might have cost a lot BUT they were selected for their attributes. Believe me i spent **** loads more before the BMW. Sorry i try to hard to be perfect and my install points proved it.But me myself and i were the hardest judge ! Car audio is a business but have alwaysssssssssssssssss offered to help anyone who will listen to me.
QUOTE (KAL SPL)
Im new to the computer ! My mate has to do it .
QUOTE (blanketman)
Hi buddy
Doesn't anyone use their names. Do i know them ?Maybe i should call myself
THE PENNY HAS DROPPED :hehe:
Hey ANgelo...no ppl use nic names for a few reasons..one being so ppl cant look em up in phone book and come around and steal there stuff lol
cyberpunky = Bruce
PartyJase
angelo do you see any benefits in using AP mats for 9s as midbasses?
also with the 1.5cu ft sill boxes - did you work that size out using software to get a qtc of 0.7ish? where were your 9s actually mounted?
angelo kanci
Yes using ap matts is Very good with midbass. There is a hell of a lot of information in that frequency covered by them. Mine are in the front in the kick panels and the air behind them ports into a sealed sill panel. They can work in the rear quater panels but harder to do. With mid base it is very important to have very close path lenght differences.
The enclosures have to be VERY small . No programs needed.
You need heaps amp power.
Anything else just ask.
Most people use small midbass and rely on subs but it will be boomy.
My mid bass get the most amp power ! 500 rms each side.
I dont like them in the doors you get phase problems. Thats whey i bought the BMW b/c they have the biggest kickpanels than any other car , neary 15 inches !
Tiger
QUOTE (angelo kanci)
How about making a small fibreglass enclosure in the front doors. Would that change things?
Or sound deadening and sealing the doors is plenty enough?
Tiger the phase issues are due to them firing across at each other and the distances involved. Kicks and even floor mounting avoids this. As Angelo points out, its hard in kicks due to space, but obviously thats one of the best posistions if you can do it.
Tiger
So obviously building out on the doors and getting them to fire in the direction of the passenger's face on the opposite side would fix that problem. I know it's restricted if you want to stay within the door cavities.
PartyJase
asking about the software and qtc was in reference to ur focal mids - not AP mats. should have made that clearer. because 1.5cu ft seems a pretty big enclosure for a midbass even a 9. was this due to the specs of the focal driver, or were you seeking to replicate an infinite baffle situation by having the biggest encolsure possible?
using ap mats in a midbass situation- if the mat is place on the basketside of the driver, is it sufficient to completely seal the front wave from the rear? will some leakage lead to a large loss of midbass?
why didn't you choose to use ap matts for ur mid drivers as well as the subs?
angelo kanci
QUOTE (PartyJase)
Correct on second i wanted to replicate an infinite baffel with the mechanical control ot the matt. WELL DONE :thumb:
yes the matt can and i did put it on the basket . The seal is completed by mounting the speaker on a pod.
For better control of the speakers.
Remember a certain amount of sensitivity loss in ap matt and equalizing is required BUT the responce is out of this world !
Withe themechanical control results are very predictable and constant. It doesn't matter if your windows of doors are open !
QUOTE (Cyberpunky)
Well done thanks mate :thumb:
