Full Version: SQ Capable???????
WPN323
Ok this is the stuff i have, would i qualify in the SQ department with the crapE i have.
Head Unit: Pioneer DEH9450M
F/Stage: Hertz HSK165 woofers (Audison Lrx2.250)
Morel Supremo tweeters(AudiosonLrx 2.250)
Rears: Hertz Hi-energy co-axes. 6 inch
Subs: 2 PG Ti 12' in sealed box to specs
Sub Amp: JL 1000/1 monoblock
F/Stage amps: As stated above
Aerpro 1 Farad cap.
What do you guys think of setup?
What would you change?
It depends entirely on the install - it is hard to make a reliable judgement without far more information about the rest of the variables..
WPN323
I don't doubt that, but considering install was top notch, my car is a mazda 323 86, and i have already done a whole lot of sound deadening. I wont be doing the install though.
Do you think the stuff i have is eligible for it?
pingpong
well assuming that the installers dont do a "dasherhalo" on you, those are some very nice parts easily high end sq material to work with imo , and hopefully the install will bring together the sum of the parts into one nice package
should be good
though sq to me is not about the size of your wallet, but the size of your smile every time you listen to your favourite cd, so it dont matter if its $200 worth of stuff or $2000 as long as it makes you happy
craigt
no doubt the gear you have is top rate, buy unless its installed right, you might as well use STD. speakers
NUTTTR
My personal music tastes match that setup rather well, i personally was not a huge fan of the audison lrx amps, but they are bloody good amps, everyone else who uses them tells me i'm a nutter Which is true, still, a good install will make that setup sing really well, only upgrade i could see you "needing" at all might be better mid basses later... however, thos HSK's pull their weight VERy nicely
Aaron
dasherhalo
Heheheh, I’m famous! …… for all the wrong reasons
Avoid my pitfalls.
1. Make your wishes known, and write it down. Critical!!
2. Make sure you don’t pick up the vehicle in a rush: take a lot of time to go over every aspect of the install before you leave.
I like the component list you’ve got there: there’s no reason that can’t produce top-notch sound. If you get good results, let me know! I might be persuaded to install all my gear into my ’85 Laser instead!!
WPN323
As for the MIDS, i will be upgrading them for sure, either with HV1600 or Space 6's of the Hertz range depending upon application.
i also installed my Audison lrx2.250 today and boy what a huge diff it made, very happy.
The supremos, well they'll be goign into my XR8 only because i dont wanna piss fart around with them if you know what i mean.
