Full Version: 5x7 Splits under $700 - for BA XR6-T
Trough Lolly
as the title says:
i know Boston acoustic make sum nice 5x7 RALLY splits.
who else makes sum great 5x7's under 700?? thanx.
RTTZ
Why 5x7 ? You could get an excellent set of 6.5" splits for under $700 and enough left to get an adaptor made up!
Trough Lolly
because he doesnt want to.
5x7's only please. we dont wanna hack up a 45 grand car.
mick007
What about making a spacer for the six inch slpits? E.g. a 5x7 baffle and then cutting the whole out. Would sound better then the 5x7. Also the h/u on the XR is not that poerful, might want to look at upgrading that. I have the same problem at the moment with my EB. I still have the Kappa Perfects in it. But running the stock h/u they will distrot at about 1/2 volume. Might want to make sure you match the speakers to the h/u. All that siad, if 5x7's are your thing then Rockford make some pretty good 5x7's.
Mick
Mickee
I'm pretty sure Hertz make a pair of 5x7" splits in the High Energy series. Probably be around the $350-$400 mark. Hertz speakers have a very good reputation for their build quality and midbass abilities, although I have heard some people say the tweeter could be improved.
If you are keeping the stock head unit then you will be severely underpowering any good set of speakers you buy (ie. you'll get bucket loads of distortion) Have you considered adding a small 2 channel amp to the system? You just need to find one with speaker level inputs. This will improve the sound quality immensly.
STIK79
Good luck doing that Other than running a seperate HU to the factory one, word on the grapevine is you're screwed due to the tight integration of the HU into the factory computer system
i supposed you'd need to use a line-level-convertor and run RCAs off of that. but that still means the signal has passed through the HUs inbuilt amps, which is often a little dodge.
worth pulling off the door trims to see how hard is would be to change the plastic baffle to an mdf one to hold round speakers. probably very easy to do and greatly increases the options for splits.
mick007
Your'e right stick, I actually brought a series 2 AU XR6 due to not being able to intergrate with the BA h/u. I was more suggesting that this guy needs to 'power match' his speakers to the h/u, and not waste money. Line level converters can be used in it's place, but err..... not my cup of tea.
Also it is p^ss easy to make the mdf baffle to fit the 6 and tweet in the door. Eficient speakers are a must by the sounds of things.
Mick
beaver429
Limited range in 5 x 7, go with 6.5". Dyn 7" will even fit in the holes.
Trough Lolly
look ill clarify a few things,
the HU is gunna have the blaupunkt thingo installed that gives the car RCA's aswel as DVD,mp3,VCD and so forth.
their going to be amped. please can everyone just suggest some 5x7's? weve already thought of other stuff but there ARE jsut as good 5x7s out there. they will do just fine.
bob
The rca's on the blau adaptor are only for audio comming out of the dvd player itself. DW, line level converters arn't that bad, when your stuck with a headunit you can't replace.
I'll be doing the exact same thing.
fatcatsam84
gp the boston rally's with a Imaging kit.
They sound supersweet.
That's if they are set up rite.
Interceptor
i know this is off topic, but:
trough lolly, dont waste your time with the blaupunkt add-on, it's an overpriced peice of junk IMO
join www.fordmods.com and read these threads, i think you'll find them very helpfull
http://forums.fordmods.com/phpBB2/viewtopic.php?t=889
http://forums.fordmods.com/phpBB2/viewtopic.php?t=2410
http://forums.fordmods.com/phpBB2/viewtopic.php?t=4183
there's a few techies that have put a lot of time into adapting the BA headunits to other purposes, and have even got a laptop to display on the ICC screen, and they're not charging anywhere near what blaupunkt are
abbs
I have installed several sets of rally 5x7 splits into AU's & BA's, these are the best option for ease of install and excellent SQ for the money. In the BA we use 2ch Rockford punch amps because they have a very good speacker line in that works well with the standard unit, although the premium unit sounds better for some reason but it seems that you already have the headunit thing sorted! For the best results with the stock H/U look at some of Audiocontrols small EQ's, they have speaker level in to high volt RCA out's, these work great but are still no substitute for a replacemnt H/U.
[ December 17, 2003, 23:46: Message edited by: abbs ]
Magnat
5x7 Splits are not a Necessity.
JBL 8626E 2-ways are The Sweetest Sounding Co-axial I have Heard in along Time.
I am using them in All 4 Doors in my Mondeo and I love them. (Yes the Mondeo has the Same annoying Size speakers as the Ones in the BA front Doors)
Just Buy a Set of Alpine Type S or R ( Not Sure) 5x7s and add an Additional Tweeter to them.
