quote:
Originally posted by Tegboy:
I was going to tune it to the cabin resonance frequency, is this bad idea. I thought this was the best way... is there a better way?
yes, you'll find that because of the way the box, sub and port react it will be louder if you tune a certain amount below *resonant frequency* it will be louder
also, if your amplifiers are particularly powerful (or you are running below their rated nominal level ie 2 ohm instead of 4 ohm) then you may have a good chance if frying your sub if you play a tone for too long
the best way to find the loudest tuning is to start tuning low and slowly shorten the port until it is loudest..
now you may be thinking, what if I just plug the numbers into *insert box design program here* and see how low I should tune. Well, unfortunately, the frequency response plot is not accurate enough for an SPL box and generally you should tune a bit lower than where it peaks (somtimes there is a flat peak that complicates things somewhat)
when designing an SPL box I look at all of the other graphs to guess an approximate tuning frequency and I'd usually try a few hz lower rather than a few hz higher
(but if you don't know what you are looking for, it will just confuse you more - any recommendations that I'll ever make with a box program are just educated guesses)
