Full Version: DB machine on gold coast
BA5513
Can anyone tell me where i can hire/use a Db machine on the south end of gold coast? My mates would lov to have a personal shootout to see who will go the loudest. I would just love to have an idea of how loud i go.
I love ///Alpine
Call Incar
SPL KINGS 2001
153.4dB Loudest Sedan
158.5dB Loudest Single Woofer
160.8dB Loudest 4 Woofer
166.2dB Loudest to Date
BEYOND AUDIO distributors
Bodyjar
Come to maroochy car comp finals! probly cheaper than hiring one... or the Minden car show at the begining of next month?
Phil, you have ur own RTA now?
GCCS also have their own meter which reads more closer to the official dB drag meters
System Includes:
Pioneer DLS HERTZ XTANT Phoenix Gold
www.members.sounddomain.com/bodyjar
1st Place, Drag Combat 2002, 1 Woofer class
PuRpS
how would u no you have never been on a the db drag meter
ring incar atleast hes a fellow CAA'er
- 2nd S3-4 Supernats 2001 -
- 1st SS3-4 Final Batle 2001 -
- 1st H W D SCS 2001 -
- 1st 601+ & Loudest Over All Summernats 2002 -
- 1st SS3-4 Wagga 2002 -
- 1st 601+ GLO 2002 -
- 2nd SS3-4 SAS 2002 -
- 1st SS3-4 MAS 2002 -
- SPL KING MAS 2002 -
What's the big who-ha about the dB drag meter?
AJ made a best ever with his old set-up in Qld of 157.7 and made 156.9 at FB 2001, he typically made high 156s and low 157s at ever comp leading up to FB 2001.
I really can't see any major difference between any of our Audio Controls and the Term Pro used by SCR.
I'm waiting for the new version of Term Pro (due Nov), so I'll find out myself!
SPL KINGS 2001
ripped
what about the linear x meter, they are suppose to be a even tougher meter then the termpro ones...
going on pig75's kriss meter (which he said was 1db lower then 2001 FB meter), the ones up here (MCS/northfield )are about 2-3db higher then the ones down south...
2002 Holden Astra
HU: Blaupunkt Miami Beach
Front Stage: Orion XTR 6.2
Front Amp: PPI 2360 2x90
Subs: 2 x Audiobahn 1200Q
Sub Amp: JBL 1200.1
Dead Last at Drag Combat 2-3 Woofer class
Winner at BAS 161-260sq inch.
KraSE
linear x r a very tuff meter.
Team Tycoon - Dollars n dB's
PuRpS
they are hell tuf like 5 to 10 db harder
Bodyjar
Basically because the meter Phil uses reads about 4dB louder than FB scores... thats why... well I beleive it does anyways... basically, I can't see how I can get 147 from my sub, so i'm bringing myself down incase I do ever get to an official comp (not likely at this rate) and score real low... Also, Autobarns termpro reads 5dB lower than Phils source meter (maybe dodgy, I dont know) also GCCS's Audiocontrol (recently calibrated) meter reads about the same as Autobarns...
System Includes:
Mr.m3
ring GCCS at bundall they have an audiocontrol (55921755)prob have to make a booking
"viagra eyedrops":for when you want to have a hard look at yourself!
Quote Bodyjar: "Basically because the meter Phil uses reads about 4dB louder than FB scores"
AJ made a best of 157.7 in Qld and then 156.9 in Sydney, with 2 old, borrowed subs, after we fried 2 showing off!
How is our meter "4dB" louder???????????
SPL KINGS 2001
mistersparco
PHIL, quote directly from that nice email you sent me.
"Andrews Civic won SPL King 2001 at SAS final battle, and had a best score in 2001 of 157.7 at BAS 2001.
Since the rebuild, he has posted a best score of 160.8 off only 2 out of the normal 4 amplifers."
May i ask, what did this car run at a northfield hosted comp after the build (one held at willowbank), i can't remember the dB, but i know it wasn't over 160.....
I'm no maths genius but my calculator told me that 160.8dB - 156.9dB = 3.9dB. Now if you ask me thats pretty close to 4db hey phil?
Or maybe the comparison you need to be making it that 157.7 was done at BAS and 160.8 was done on the meter that you use...... DO I NEED TO SPELL IT OUT!!!!!
Hyundai Excel (130DB)
Up Front - JVC
Front Stage - Hertz
Sub - 1X Orion HCCA 15
Amps - Crossfire &
Weconic
SPL - 145.5db
[Edited 1 time by mistersparco on 22 September 2002 at 09:28]
how hard is it too believe?
with the 2 amps, they probably ran them at a lower load = same power, and 4 or so dB was gained from a better install
SPL KINGS 2001
161.0dB Current Amateur Record (set 2000!)
[Edited 1 time by Incar Phil on 22 September 2002 at 11:46]
Thanks Bassaholic.
AJ ran ONE amp at Drag Combat, due the long series of dramas we experienced with the MTX 1000D (CCS have since replaced them with brand new 81000Ds, thanks guys).
OK, Mister Sparco I'll type slowly so you can understand it!
Four 8 ohm subs in parallel, makes a nominal 2 ohm load, which at 56Hz rises to 5.4 ohms.
ONE (1) MTX 1000D onto a 5.4 ohm load, makes around 650Wrms, and gave mid-high 150s at DC with the new build.
Now, take the same load, and bridge a PAIR of MTX 1000Ds on. Each amp then actually sees 1.35ohms, making (on paper) 6dB more power.
Now back to the original point Mister Sparco came in on, I said the Qld meters, wether it be Northfields', Marcoochy's or ours all read with 1dB of each other. AJ'S CIVIC, WHICH WE USED TO WIN SYDNEY AUTOSALON FINAL BATTLE 2001 SPL KING, CAME WITHIN 0.8DB OF HIS BEST EVER QLD READING, ON THE SYDNEY METER.
So, I don't see how the Sydney meter can be 4dB lower than Qld's. We proved it by kicking ass and winning SPL KING 2001 (again!) with AJ's old set up, with tiny 3.5 cube boxes and single 6" ports!
Mister Sparco, I realise that having a go at me is now somewhat of a CAA tradition, but at least get your facts straight before you try. You seem to forget, that everytime INCAR take our big hitters to a comp, we ALWAYS go home with the trophy, regardless when, where, or what meter it's on. LOUDEST is always LOUDEST.
PS if you thought our old cars were loud, you're not going to beleive what's coming!
SPL KINGS 2001
Ear bleeder
so mister sparco you are saying they all are wrong because you get smoked by some on Phil's creations
Bodyjar
Calm down guys... I just voiced my thoughts... MrSparco doesnt compete directly with Phil's cars in any way, so its not like he;s annoyed by losing, because, well, he's never lost to Phil as they dont compete against each other...
Anyways, how bout this conversation concludes and we wait till we get an official dB drag meter up here huh? oh wait... we won't will we? As Angelo said we would get 2 events this year, how many did we get? hmmm... ZERO?
System Includes:
static existence
Mr.m3
You got more information...How much?
Cheaper with groups? etc
Headunit: JVC KD-SX985
Mid bass: Kenwood KFC HQ 718320w 7x10's
Amps: Jaycar 100wRMSx4, Kenwwod KAC 628 100wRMSx2
Subs: Pioneer 12" TS-W1201C
Neons: 2x strobes,2x pulsing,2x antenna type and 2x12"
Bodyjar
We will be holding a Test and Tune night/day next month for a fund raising event for FB. It will be on the weekend of the 27th of October. More details will be given soon. So instead of paying $25/ half hour at a store, why not come to this It will be for a minimal price, with unlimited runs You'll also get good advice form the members and the store owner involved and a chance to meet the other members and talk audio!
System Includes:
ripped
which store is it going to be at? will it have enough room for all our cars?
2002 Holden Astra
Sub Amp: JBL 1200.1
Bodyjar
It wil be held at ******* and yes, there will be enough room!
System Includes:
BA5513
Sounds good bodyjar, im in
why cant you tell us where it tho?
I LIKE ///Alpine
Bodyjar
Because its a bit of a secret for now... I have to finalise everything first, as it involves other states aswell :D
EDIT: For John, it will be in the Brisbane area, don't worry! just wait
System Includes:
[Edited 1 time by Bodyjar on 25 September 2002 at 16:03]
phil mini man
ill be in for that im playing with some gear at the moment heheheheh also hueting my head at the same time though to many numbers involved
ps on a different note any one on the northside got circular saw etc as i dont have my own gear at my new place and cant be phucked going home to build some boxes
any help is appreciated
