SomeFReaK
Sep 25 2002, 06:27 PM
I am looking at getting a mono block amp. At the moment i get a massive voltage drop when i play music (voltage at the amps drop from 14.4V to 11V)
Would it be worth my while installing 0guage from the battery to my distro block in the boot?
Also could i still use my 4ga earths, or would i need new ones???
Would it be worth my while upgrading my batterys ground??? With 0ga?
SomeFReaK
2001 Hyundai Accent GS
Soon to be Hyundai Accent GS-t
Currently listening to - Soundtrack from xXx
http://freakcentral.devgeeks.org
Accent forums online http://forums.devgeeks.org
My Band (Weezal) http://www.weezal.com
advance
Sep 25 2002, 06:59 PM
If you are experiencing voltage drops at the battery with your current wiring, then upgrading to 0ga won't help.
If you did install 0ga wire, you would also have to upgrade the grounds to 0ga. (power and ground should be the same)
Before upgrading to 0ga to the distro block, have a look at upgrading the 3 main system charging wires under the hood.
Alternator to Battery
Alternator to Ground
Battery to Ground
once these are upgraded you 'should' notice an improvment. If not you might want to look at a better battery and/or alterator too!
SUB: Digital Designs
AMPS: MTX
STUFF: JAYCAR
KraSE
Sep 25 2002, 07:03 PM
i don't think he would run 0 to his amps. more likely to a DB and 4awg to his amps which would be fine and able to keep his 4awg earths
Team Tycoon - Dollars n dB's
a little Beyond Audio and a little Power = BUUURRRRP
Andu
Sep 25 2002, 07:04 PM
Grounds should be kept the same size as the power wire so yes upgrade the grounds at the same time.
dude your only pulling 56A max with your Jaycar amp and ur volts are dropping from 14.4V to 11V?? Get a new battery for sure bro. whats the stock Accent's battery? I would check but my mum is out with her's... like 300-340cca or something?
Car: '90 Nissan Pintara (sedan)
Headunit: JVC KD-SX750
Fronts: TotalRecoil Carsplit.6
Frontamp: Alpine MRV-T301
Sub: 2x DVC 4ohm 12" Alpine Type-R
Subamp: Lanzar 2000D
SPL: 139.5db (140db+ next time easy)
"If its not quick, may aswell make it slower"
Andu
Sep 25 2002, 07:13 PM
quote:
Ah true true... But bro when u get your monoblock just have 2 runs... leave your current 4GA for your little amp and fat sexi ass 0GA straight into your monoblock... distros just look pretty, and just add resistance. less interconnects the better
Mr_Bob
Sep 25 2002, 07:17 PM
upgrading the cabling could help, what cable is running to the amp atm?
how long is the run?
V/I=R
3V/60A=0.05ohm
a 3V drop can be caused by a resistance of 0.05ohm if you're drawing 60A.
0.05ohm could be found in a 8gauge cable, trying to carry 60a over 5m, maybe.
it migh tbe a combination of that, and small resistances in your fuse holder/battery terminals and cable connections.
when you are experiencing these voltages drops are your headlights dimming too?
measure the voltage at the battery (put multimeter probes onto battery terminal posts (not terminal claps) and see if the BATTERY voltage drops.
if the voltage at the battery drops below 12V then replace the battery.
otherwise there is no need to. your battery will not help to sustain 14V.
if the voltage drop is only at the amp, upgrade your cabling.
'96 Mirage, currently resembling a tin can
TEAM AUDISON
KraSE
quote:
0awg ain't that big. 3/0 is
Andu
Sep 25 2002, 07:31 PM
Hey we are only trying to get his 12V, with no voltage drop from the front to the back of the car... not to Taiwan
correct me if i'm wrong though?
SomeFReaK
Sep 25 2002, 08:28 PM
Hmm, I am getting dimming headlights etc. I was gonna upgrade the battery aswell as the 0awg. Hmm, i wish i had my old amp so i can see if there is a voltage drop at the battery (i think there is...)
SomeFReaK
ripped
Sep 25 2002, 08:32 PM
thats some pretty hardcore voltage drop you're getting. as mentioned before, check for voltage drop at battery and at the amp's terminals... if there is a greater then 1v difference, then think about uping the wire.
i think the only time my voltage dropped below 12v was when i was playing sine waves, not bloody music...
2002 Holden Astra
HU: Blaupunkt Miami Beach
Front Stage: Orion XTR 6.2
Front Amp: PPI 2360 2x90
Subs: 2 x Audiobahn 1200Q
Sub Amp: JBL 1200.1
Dead Last at Drag Combat 2-3 Woofer class
Winner at BAS 161-260sq inch.
ripped
Sep 25 2002, 08:35 PM
what amp are you running now?
2002 Holden Astra
Sub Amp: JBL 1200.1
SomeFReaK
Sep 25 2002, 08:44 PM
I am running my modded Jaycar 2 X 150 to my splits and nothing to the sub
Still saving/shopping for my new amp
SomeFReaK
ripped
Sep 25 2002, 09:20 PM
huh? you get that much voltage drop playing music through splits?
2002 Holden Astra
Sub Amp: JBL 1200.1
SomeFReaK
Sep 25 2002, 10:15 PM
NO, i HAD that much voltage drop running the 2 jaycar amps
Just mesured my battery, 8" X 6.5" X 8.5" high, no optima for me
SomeFReaK
Dude the Odyssey Dry Cell ES12V1000 should fit in your car at $372.00 it will double your CCA rating
ES12V1000
Max Pulse Current - 1000 Amps
CCA Rating - 600 a
Reserve Cao - 91 min
Capacity (20hr) - 42 ah
Short Circuit Current - >2600 a
Length - 199 mm
Width - 168 mm
Height - 188 mm
Weight - 16 kg
Metal Jacket - fitted
Max Torque - 6.8 Nm
Artic Ice VN Commodore, 17inch ROH wheels, Full Body Kit
SomeFReaK
Oct 4 2002, 11:15 AM
Yeah i noticed them in the online store
I will have to get one when i have some $$$.
Also went to my local JB's last night, they will do 1/0ga for $15/m
SomeFReaK
SomeFReaK
Oct 4 2002, 11:16 AM
Oh and 0ga battery terminals, fuse holders and DB's are expensive, might have to source a home made one
SomeFReaK
Oct 4 2002, 08:00 PM
SomeFReaK - did you check KraSE's wire thread?
might save you a bit of $$$
the[K]id
Oct 5 2002, 05:58 AM
I can't see if anyone mentioned it, but get extra 0awg, (or 00/000 of you can afford it) fo redoign battery, alternator, and alternator grounding runs. Those are the big weak spots in small cars.
Weaponx: "Im starting up a new team, its team "Craig David" "
bluemini: "weapon, have you been in to daddies medicine cabinet today??"
Cyberpunky: "forget the specs, and just listen to what is watt"
Ali G: "Let's increase da peace, and keep it real"
Team Digital-Is-A-Marketing-Gimic Member
Team Tycoon - Dollers n dB's
Team Gates - teamgates.org
