Full Version: Single Woofer SPLs
Andrew_SP20
I'm about to build a box for my single Kicker 15" L7 for some SPL numbers and i'm putting the question out to all or of you as to what are your biggest single woofer SPL numbers and what sort of box / sub combo was it? (basically this post is an extension of Andu's post)
I'm hoping for around 147db...
MEMBER OF SINISTER MOTORSPORTS CLUB
- RIDE: 2002 Mazda Astina SP20
- SOURCE: On Order - Kenwood DPX8020MD
- FRONTS: Boston RC 820's
- SUB: Kicker S15L7
- AMPS: MTX TH6500D, MTX TH4244
Walkinshaw
141.3
XTR15s
2cuft sealed
400wrms
Falcon+LPG
you should blitz this score no probs
CDA7969R XTR800.4 RSD216 XTR15S HCW8
C A A . S A . C O M M I T T E E . M E M B E R
icebreaker
Well i did 141.8dB with 2 12's in a box.
that was about 8cubes. Which was about 2-3 cubes to big. And 700W RMS per sub.
I'm about ready to build a single woofer box giving 1 12" 1400W RMS.. And i'm hoping for 145dB+
So we'll See.
Adam did 147 with 1 TR off the shelf SVC 12"
and 150 with 1 TR 15" off 1400W RMS.
In a box approx 3-4 cubes with dual Aero Ports (Trumpet Ports). In a small Barina.
audison »»»morel Clarion{Image Dynamicsz PPI OPTIMA Stinger
Proud Member of: Team CAA | Team Gates | Team Image Dynamics
CAA Extreme Car... It's not an idea, It's a Reality...
Bodyjar
Single 12" Hertz HS300 woofer
2.3cube slot port box
1 Nissan Pulsar all street 1-2 legal
145.7dB
Also, lanzar_au has the aust record, single DD9515 in a wall in an excell. 158dB
System Includes:
Pioneer DLS HERTZ XTANT Phoenix Gold
www.members.sounddomain.com/bodyjar
1st Place, Drag Combat 2002, 1 Woofer class
Andu
139.5db
12" Alpine Type-R
Response 2x150wrms
57L box tuned @ 35hz
nothing to get excited about... I would of liked to crack the 140 mark with the single setup
Car: '90 Nissan Pintara (sedan)
Headunit: JVC KD-SX750
Fronts: TotalRecoil 6" mid-bass + Cerwin Vega tweets (fried the TR tweets)
Frontamp: Alpine MRV-T301
Rears: Pioneer 4" 3way coaxials
Sub: 2x DVC 4ohm 12" Alpine Type-R
Subamp: Lanzar 2000D
SPL: 139.5db (140db+ next time easy)
"If its not quick, may aswell make it slower"
WeaponX
Jar,
Mate has that 158 (Lanzar's) been confirmed on other Meters apart from Incars??, any other comps???.
TEAM DD "In the Lanes, takin names"
No more Amps, got scared of all the competition and ran away!!
Best 158.4db on TERMPRO (SAS 2002)
ripped
i've seen lanzar_au's excel do 155+ on a non incar meter running 2 amps
2002 Holden Astra
HU: Blaupunkt Miami Beach
Front Stage: Orion XTR 6.2
Front Amp: PPI 2360 2x90
Subs: 2 x Audiobahn 1200Q
Sub Amp: JBL 1200.1
4ga wiring, and using RCAs now!.
Bodyjar
quote:
Originally posted by WeaponX:
Jar,
It's not INCARS meter, but Custom Image who work with INCAR a lot... same thing though... And I dont think he's hit that high on others, but does 155's or so consistently on other meters...
Also... At BAS last weekend, I'd like to increase my PB
147.0dB off the setup above, bar the amp was changed to an Alpine 1507 and was not scoped to find optimum gain/volume settings
System Includes:
osolow
151db
1 15" Shocket Xtreme Quad 1ohm
500watts
8.7ft^3
185in^2 of port
ripped
shocker extremes hay... so you guys can get shockers, or did you import them?
2002 Holden Astra
Sub Amp: JBL 1200.1
Dead Last at Drag Combat 2-3 Woofer class
Winner at BAS 161-260sq inch.
lanzarau made has made a best of 158.5 on a very cold night, after 11:30pm at one of our night comps, after extensive tweaking.
He made over 156 several other times, with just 2 amps, on various meters.
Nathan made around 148 off a single 12" and one amp.
We've had other cars make in the 150s off BMF XTs and Strokers recently.
There's not much point in building single woofer cars under dB Drag rules anyhow.
Most interesting are car's like Chief's INCAR Mira which are banging on 160 in SS 1-2.
SPL KINGS 2001
161.0dB Amateur Record, set BAS 2000
153.4dB Loudest Sedan
158.5dB Loudest Single Woofer
160.8dB Loudest 4 Woofer
166.2dB Loudest to Date
BEYOND AUDIO distributors
KraSE
quote:
why not
nothing rong with single woofers
Team Tycoon - Dollars n dB's
a little Beyond Audio and a little Power = BUUURRRRP
Mr_Bob
single woofer's rock, less wastage due to cancellation, more available space per woofer, for stronger enclosure (more room for thicker wood)and more box/port volume available.
more/easier efficient sub placement/angling.
'96 Mirage, currently resembling a tin can
TEAM AUDISON
KraSE
oh and 173.2 (certfied) in extreme 1-2 by team RWD in finland with a single woofer(dd 9515) is pretty loud and would more than easily keep up with 2 woofer cars.
quote:
Originally posted by KraSE:
why not
nothing wrong with them
but if you want to build your car as loud as possible within the rules, then more woofers may be louder
KraSE
yes true but not always as impressive
1. In a normal vehicle for day to day use 2 is better than one, same output less with excursion = cleaner bass.
2. dB Drag rules allow for 2 woofers
Sure it's cool to go loud off one woofer, but it sucks to go home in second place! Nobody remembers the second place getter!
SPL KINGS 2001
Bodyjar
Bah... u'r crazy Single woofers rock!
I will upgrade my score with a full street legal system...
147.5dB at Jamboree 2002 in freakin hot weather I will maintain my status as Australia's loudest Street single woofer car! muiauaahahaha, unless someone can beat it?
System Includes:
ripped
how about i run one bahn and give you some competition
2002 Holden Astra
Sub Amp: JBL 1200.1
osolow
Not available, simply not enough demand.
I imported it myself, as far as I know its the only Shocker or Quad coil sub in New Zealand.
Prepare to be shocked
Andrew_SP20
To all those doubters, I reckon there's always a point to building a single woofer SPL system when you set it up right and put all the effort in and you kick the **** of some big ego dude who's got a huge setup and heaps of power and can't keep up!
- SOURCE: Yet to Decide
- SUB: Kicker S15 L7 4
Sir BoomsAlot
well, I got 139.9 out of my 15" in a sealed box, which I wish to improve by porting.
but, we got 135.9 out of a Clarion Vnet 10" in a 2.7 cu ft ported box tuned to 30 Hz. 300 wrms at 52 Hz.
we are going to be trialing some more single sub enclosures so we can surprise some more people.
Sony CD player
Standard 4" upfront (soon to be replaced)
Response 4 x 100wrms
Rockford Fosgate 6x9"s
JL 15 W1
--== 139.9 dB ==-- 2.5 cu ft Sealed
Team Xmax - Xtend your surroundings
Clarkie
st 1-2 one DD 3512 of Kenwood amp @ 0.8 ohms 146.0db termpro(no testing done yate)Hope to do 150db went sorted.
Clarkie
NZ Record
st 1-2
150.7db
K/wood 12"DVC(x2)
K/wood D class
exup
1992 Daihatsu Applause
HU:Clarion DRB 3675
REAR: Clarion SRR6923
FRONT AMP: Yamaha YPA 400
FRONT: Alpine 1029S
SUB AMP: Clarion(Captec)VNet-2100
SUBs: 2x JL 12W0 - 42L each -sealed
LIGHTING: Blue LED's for floor, UV LED's for upper torso & Subs
[Edited 1 time by exup on 30 September 2002 at 19:09]
PuRpS
quote:
i would be more then happy to beat that score if and wen i can be bother to put twin peeks back in the car
sofar we have dun 144.7 with 1 bahn and 2 response 150x2 @ 1ohm on sum realy dodgey meter
- 2nd S3-4 Supernats 2001 -
- 1st SS3-4 Final Batle 2001 -
- 1st H W D SCS 2001 -
- 1st 601+ & Loudest Over All Summernats 2002 -
- 1st SS3-4 Wagga 2002 -
- 1st 601+ GLO 2002 -
- 2nd SS3-4 SAS 2002 -
- 1st SS3-4 MAS 2002 -
- SPL KING MAS 2002 -
What about Nathan's 147.8 from a single 12?
That's up there.
SPL KINGS 2001
158.5dB Loudest SS 1-2 (single DD 9515)
160.8dB Loudest SS 3-4
TEAM DD
[Edited 1 time by Incar Phil on 30 September 2002 at 21:52]
blownvt
I wouldve thought that in s1-2 where the major limiting factor is lack of available power (from the cars electrical system), a single sub setup would be better with the advantage mainly being the reduced cancellation
comments?
'98 Commodore VT S pack Supercharged
Clarion ADX5655Z DblDin HU
Focal Utopia 165w3s
Philips DAP4040 Amp
2 x Kicker ZR240 Amps
2 x JL Audio12W6 Subs (currently awaiting recoil)
Audiocontrol 24XS Crossover/PFM filter
RF 1 Farad cap etc etc etc
in S1-2 you generally have plenty of room for 2 12s and if you wanted to hit significantly over 150, you'd really want to use 2 efficient 12s a big D class amp and a biig battery
147 + 6dB ought to be loud for a street car
Daniel
ey! - i came second at Supernats and ppl remember me!!!! (esp the guy who came third!!)
1991 MX6 Turbo
Kenwood
MB Quart
Alpine (Selling my MRV-1005's) :(
MTX
Kicker (Sold my S12L7's) :(
2nd place: Supernats 2002 (Super Street 1-2)
148.2dB and Rising!!
DEF-YET
Umm i may be wrong but cant you only use the stock battery in Street.. ??
Mitsubishi 84' Colt "SPL-04U"
Small System: Kicker S12L7 - Crossfire CFA-602
Big System: 1 BIG SPL WOOFER - 2 x JBL 1200.1 (Coming Soon)
Coming Soon - Http://www.OzCarAudio.com
Image Gallery Co-ordinator - [email="Images@CarAudioAustralia.com"]Images@CarAudioAustralia.com[/email]
ripped
you can use an aftermarket battery, it just has to go in the stock location, and fit!!! so you can't cram one of those marine batteries under the hood
2002 Holden Astra
Sub Amp: JBL 1200.1
yes, big in capacity.. it still has to fit
DEF-YET
i must of read wrong :7
[Edited 1 time by N.O.S Boy on 01 October 2002 at 19:05]
the rule is something along the lines of - the battery has to fit in the stock location with no modifications of the battery tray
Bodyjar
That's up there.
We all up here in QLD know that Dave's meter reads approximately 2dB higher than Northfields meters
System Includes:
Nathan still went 1-2dB or so louder than you on the same night BJ!!
SPL KINGS 2001
TEAM DD
icebreaker
Hmmm almost sounds like a challenge...
146.6dB with power problems, and a 16 cubic in slot port...
so i need .9dB then huh
Proud Member of: Team CAA | Team Gates | Team Image Dynamics | Team G-Spot
Bodyjar
Errr... that was with my PG amp... with more power, I have hit 147.5 on NORTHFIELDS meter... which would equate to over 149 on Dave's meter who's laughing now?
System Includes:
ripped
thats it, i'm going single woofer for one of my three runs this weekend. it'll be interesting to see what this single 12 hype is all about.
2002 Holden Astra
Sub Amp: JBL 1200.1
icebreaker
Who care's about Dave's meter. or northfield's meter. The world of dB Drags is based on the dB Drags meter...
All other meters in terms of that competition scene are based on these.
I can go use an Audiocontrol that is prob 2-3dB higher also, if you like.
AJ
No way is there 2-3dB difference.
With my old set up I had a PB of 157.7dB in Qld.
I hit 156.9 at FB 2001 (on TERM PRO), after borrowing two woofers from a friend, AND running my street tuned ports.
AJ
Owner of SPL King 2001, Hot4s Issue 81 Feature Honda Civic.
160.8dB from 2xMTX 1000Ds and 4xMTX T8000 15"s
Visit: INCAR Audiomotive
icebreaker
As far as in know the Term Pro hasn't been serviced (rumour has it)
And the Audio Control is generally atleast 1dB up on the term pro, from what i've heard and found, in the past 6 months
[Edited 1 time by icebreaker on 06 October 2002 at 03:45]
Bodyjar
Well I've been on 2 Audiocontrols that have been 5dB apart! grrr... Dan, I know I have nothing till I get an official reading, but how can I if we never get any? QLD has the most comps out of all the rest of australia put together! (ok, maybe not, but it's dam close! we have 4 this month!)
We have a few cars in the 150's and kramys van hit a 157.9 today at MCS SPL Finals! wait till we get a wall in that baby! bahahaha...
System Includes:
if you want a 99% accurate reading, the meter has to be calibrated on the day
if the termpro hasn't been calibrated in a long time and has had plenty of use, then it most probably isn't accurate either
btw, the mics in termpro and audiocontrol are pretty similar
icebreaker
Yeah i feel for you guys. It is a real shame that they don't go there.
As dB Drags should be a National thing IMO, so as far as records, etc go. It doesn't really give the full picture.
And to add to that. I wouldn't expect the same numbers in Vic/Sa compared to QLD or Nth QLD. Considering the huge difference in the weather, esp if you compare say, our winter to your summer.
it would be good to see if go national officially.
